Can't fill up 360 with gas | FerrariChat
Discussion in 'Technical Q&A' started by vm3, Apr 21, 2007.
  1. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    When filling up my 2003 360, the pump handle keeps stopping every few seconds even though the tank is half empty. I tried varying the position of the handle but it keeps happening. What wrong?
  2. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    This might be a silly question but is it at all gas stations or just one particular one?
  3. donald
    donald Karting
    Aug 11, 2004
    197
    Dallas, Texas
    Don
    I have this same problem at most gas stations in Texas when filling up my 328. It drives me crazy. I think I read that this is common with older Ferraris but I assumed not a problem with newer models.
  4. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    It's been many months sice I filled the 308 with gas, but IIRC.... I have to not only vary the rate of fill though handle flucuation, but also not have the nosel fully inserted.
    There's a magic spot with both flow rate and length of insertion that gets the job done.
  5. PT 328
    PT 328 F1 Rookie
    4,003
    The only station where I can fill my 328 without any problems is Chevron. It makes for an interesting game while traveling. " Who can spot the first Chevron off the freeway? ".
    Dan
  6. 62 250 GTO
    62 250 GTO F1 Veteran
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    It may have to do with the angle of the nozzle. Air has to leave the tanks as gas goes in. If you block this air {there is a little mechanical part in the handle} the fuel pump will shut off. This happens to me in my cars from time to time if I don't have the handle straight or if I twist the handle while pumping. An older gent in a beautiful Chevy Nova explained that to me as we were tying up the gas pump asking questions about each others cars!
  7. ZINGARA 250GTL
    ZINGARA 250GTL F1 World Champ
    Jun 21, 2002
    17,499
    PA
    Ken
    Never had the problem with my '01 360 though I've had it once in a while with different cars, different locations. Annoying. Maybe someone can help.
  8. Under PSI
    Under PSI F1 Rookie
    May 13, 2005
    4,240
    Phoenix
    Jim
    I had a similar problem with my 996TT shortly after having service done on it. It turned out that during the service they had some how blown a fuse that controlled an anti-syphon valve on the tank. I don't know if the 360 has a similar valve but you may want to look into it.
  9. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,593
    Gates Mills, Ohio
    Jon
    Good info - and that makes sense, as I've had the problem in my Jeep periodically as well as in the 328. I would be surprised if Ferrari 360 fill necks are much different than any other cars.
    I use them just for the Techron in their fuels. But I've had good luck with their pumps not shutting off prematurely as well.
  10. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    Thanks for all your comments. It happened a couple of times at different pumps but not at another pump today in my neighborhood. I'll keep using that pump as much as possible.
  11. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    Thats what I was thinking.In my car at a particular gas station it takes forever to put gas in so I think that pump must be sensitive
  12. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    I had the same problem on my '79 GT4. I seem to have 'cured' it by rotating the gas nozzle 90 degrees to the left (i.e., so the handle is at the 9 o'clock position), but I think that has more to do with the orientation of the fill neck, associated hoses, and tank. YMMV on a 360.
  13. sammyb
    sammyb Formula 3
    Jun 23, 2006
    1,857
    Where wife tells me
    Sam
    Perfusion is absolutely correct...Essentially, if you rotate the handle so that the flow goes directly down the fill tube, it will work. I had this issue on my 328 GTS until I did exactly what Perfusion did (rotate couterclockwise.)
    It's easy to see how it all works on my Triumph TR3, which has a central gas tank and filler. Once the level of the tank gets near the nozzle, there's increased pressure on the flow, which in turn, shuts it off. If you are pumping right into a bend in the filler tube, it does the same thing. Since most American fuel fillers bend straight down, that's how the handles are situated for the pumps, but this actually means that on Ferraris, with the handle in the down position, flow is restricted.
    Sam
  14. jck
    jck Karting
    Sep 22, 2006
    184
    Santa Monica, CA
    James Kim
    Uuh, you are talking about cars, right?
  15. h00kem
    h00kem Guest
    Dec 15, 2004
    734
    Texas
    I have experienced the same problem on all of my F-cars ranging from the 348, 355,360 and 575. Must have something to do with pump pressure. Really makes it a pain to fill you having to go so slow!
  16. leead1
    leead1 F1 Rookie
    Nov 29, 2006
    2,828
    Florida
    Lee
    I had the same problem on my 2003 360 Modena. I just had to fill it up slowly. At some gas stations as the other poster mentioned the handle was to stiff to regulate and it was very difficult.
    Sorry I could not help more. FYI my F430 does not have that issue.
    Lee
  17. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    Thanks everyone. This seems to be a common problem with Ferraris. Now I won't waste money trying to fix a problem that can't be fixed!
  18. brunetti
    brunetti Karting
    Nov 25, 2006
    51
    Los Angeles
    Dana Brunetti
    it is extremely annoying and time consuming filling it up. Any tips to solve the problem appreciated.
  19. Slim
    Slim Formula 3
    Oct 11, 2001
    1,735
    Pacifica, CA, USA
    richard
    Since you're in California I assume the pump nozzles have the big black things around them? I've had some success on problem cars by pulling that part up as far as I can by hand and then sticking the exposed nozzle into the filler neck. Might want to carry around some disposable gloves.
  20. CavalloRosso
    CavalloRosso Formula 3
    Jul 12, 2007
    1,423
    Atlanta, GA/Vail, CO
    SVO
    Am I crazy or if you pull the nozzle out a little bit (i.e. not insert it fully) this problem should go away.
  21. docster
    docster Formula Junior
    273
    Oregon
    David
    I have experienced the same problem with my '03 360 Modena, at a variety of different station locations and brands, in Oregon, Washington, and California. I've tried manipulating both the angle and depth of nozzle insertion without apparent effect. Rarely, the slowest setting on the auto-shutoff will allow almost complete filling of the tank; most often, though, patient "teasing" the fuel in manually is required.
    This can be a particularly annoying problem here in Oregon, as state law prohibits self-service. However, it's very rare that the attendant won't look the other way while I do the refueling--in spite of potentially severe penalties written into the law. I've been told by station operators that it's $10K per offense!
    After a rash of "short fills" during early ownership, I've become pretty accurate at estimating how much fuel is needed from the fuel gauge. Still a PITA, especially when a station attendant has to be coaxed into manually filling it ever so slowly...
    dn
  22. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Dude, I've had this very same personal problem, not with the car though :)
    A man's got to know his limitations,
    HTH,
    chris
  23. m3power222
    m3power222 Formula 3
    Feb 24, 2006
    2,399
    Camas, WA
    Wilson
    My 360 had the same problem. Just have to fill slowley on the first notch. I've had some stations even on the slowest/first notch still put in too much pressure and auto stop. Those ones you'll just have to stand there and feather the throttle in:)
    I've heard mention of not putting in the nozzle all the way, bad idea. I tried that and when it automatically stops more then likely it will cause gas to overflow onto the paint.
  24. vteqe
    vteqe Formula Junior
    Mar 5, 2005
    664
    long Island, NY
    Sandy
    I have he same filling problem with my 84' 308 and my '70 Lotus 7. Moving the nozzle in or out has no change. The only continous fill is holding the tigger to about half flow.
  25. Spinne
    Spinne Rookie
    Jul 16, 2007
    45
    Vancouver BC Canada
    Steven S
    Also I find if you dont give it full flow it works better
