Can't find 328 GTS Hoses
Discussion in 'Technical Q&A' started by tfrancis, Nov 26, 2003.
  1. tfrancis
    tfrancis Karting
    Nov 3, 2003
    88
    Memphis, TN
    Hey Folks,
    I'm having a very hard time finding the following hoses.
    1. 118231 - Air Injection System (TAV 9) - 20mm ID / 30 inches length
    2. 118959 - Blow-by System (TAV 19) - 22mm ID / 38.5 inches length
    Both of these hoses are nylon braided hoses. Please let me know of a good source.
    Also, I'm wondering if I can replace the following hoses with silicon vaccuum hoses.
    1. 107982 - Air Intake & Manifolds (TAV 15) - 12mm ID
    2. 128305 - Air Intake & Manifolds (TAV 15) - 3.5mm ID
    Thanks,
    Tom
  3. 328GTB
    328GTB Formula Junior
    302
    Texas, USA
    Carmine
    Tom, if you find a source for these, please post it here. BTW, how did you obtain their corresponding length and ID?
    Carmine
  4. jbanzai
    jbanzai Formula 3
    Feb 1, 2002
    1,564
    Madrid, Spain
    Julio
    I had a hard time finding those hoses a while ago. I found them bulk in a heavy truck parts shop, they usually have bigger diameter hoses than most places. You will have to cut them to the right size, but that's all.
    Julio.
  5. tfrancis
    tfrancis Karting
    Nov 3, 2003
    88
    Memphis, TN
    In order to obtain the lengths... I took the orginally hoses and flatted them out straight and then measured with measuring tape. To obtain the ID... I actually measured the connecting metal pipe O.D. with a caliper. The true I.D. would be a bit smaller (-.5mm to -1mm) to ensure a tight fit.
    Also, I'm documenting all these hose specification along with resources I've used (pricing too) and putting them into a spreadsheet. I'll post all my information here later.
