Can't find a post for the 360 convertible top micro switch adjustment | FerrariChat
Discussion in 'Technical Q&A' started by mrpcar, Jul 12, 2010.
  1. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    I done several searches and couldn't locate the post.
    There was a post awhile back someone posted a procedure on how to get to the 360 spider convertible top micro switches for adjustment.
    My top operates normally, but when fully opened it is showing that the top is still open on my dash display. I suspect it is a microswitch that's out of adjustment. Remember reading a post regarding the procedure how to remove the small panels to gain access but can't seem to find that post anymore.
    TIA
  2. ferrarilou
    ferrarilou Formula Junior
    Apr 13, 2004
    513
    US
    Lou Menditto
    The microswitches (two that I know of) are under the winglet on the driver side. You can get to them if you stop the roof partway through it's open/close cycle. I've only ever had to clean them and lube the glides for the winglets. Not sure of a real adjustment procedure outside of basic loosening and fiddling, but it will be interesting to learn of one.
    Lou
  3. North East Auto Doctors
    65
    conn
    Adam Varney
    There are twelve switchs in all in that system including latchs
