CANT GET F430 OIL ON DIPSTICK | FerrariChat
Discussion in 'Technical Q&A' started by nwhite96244, Oct 21, 2023.
  1. nwhite96244
    nwhite96244 Rookie
    Jun 27, 2023
    40
    Northville mi
    Nick white
    Hey guys Tia. I have a 2006 430 w 3k miles. I have drained the oil and refilled with 9 quarts cold. Ran car to temp and added another 1.5 quarts and still nothing on the dipstick. Scared to overfill
  2. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,440
    Santa Clarita, CA
    Something should be showing on the dipstick with 10 1/2 quarts and the engine warm.
    Did you get it to operating temperature by driving it?
  3. wmuno
    wmuno Formula Junior
    522
    Wilmette, Illinois
    Bill Muno
    When you add oil, it drains down to the engine’s oil sump. The dip stick is in the oil sump. Since you added the recommended volume of oil, there are 2 possible reasons for your problem. The dip stick is not the correct one for your car (too short). The dip stick is not fully seated into the engine sump. I assume your car is on level ground.
  4. Rifledriver
    37,288
    When Ferrari states engine should be up to temperature they are speaking of oil temp. It is distinctly different than water temp.
    It should be above 185 degrees on the oil temp gauge. It makes a very big difference because oil has so much thermal expansion.
    I use an IR Thermometer and shine it down in the oil tank at the oil in the bottom.
    Rexcat458, RayJohns, 2NA and 3 others like this.
  5. swc5150
    swc5150 Formula Junior
    Jan 5, 2021
    738
    Wisconsin
    Scott Calderwood
    You are checking the level with engine running I hope? Dry sump is different from normal cars in that way.
    RobinMasters, 2NA and f355spider like this.
  6. Snapshift
    Snapshift Formula Junior
    934
    Centralia IL
    Lyle D. Pahnke
    Is there oil visible in the oil reservoir where the dip stick screws into? Sometimes with a fresh oil change, the level is so transparent on the stick you actually have to do a double look and look for the gloss level on the stick and compare that against the non glossy dry stick. What oil pressure is registering on the panel? How much oil drained out vs replaced? 10.5 is Capacity as you state. No leaks? was the oil that drained contaminated with anything. Im wondering if it is possible to have an air lock in the filter for some reason that is blocking flow and causing a low reading? Very strange on a 3K mi car. Please post a follow-up on your findings.
  7. fatbillybob
    Aug 10, 2002
    29,279
    socal
    google says 11.5l which is 12qts dry. Typical between lines is 1 qt so you are 10.5qts in and see nothing on the stick. That makes sense. I'd be adding more oil. Follow the WSM checking and capacity instructions.
  8. RayJohns
    RayJohns F1 Veteran
    7,941
    West Coast
    Ray
    Are you checking the oil while the car is running? As mentioned, it's a dry sump oil system, so not like checking the oil on your Toyota or Honda.
    Page 99 in the owner's manual.
    Ray
    RobinMasters likes this.
  9. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,233
    Georgia
    Wade Williams
    It is always a surprise to me when we get a question like this and all the great answers helping and ZERO from the OP after that.
    What happened? Did you find oil? Did you leave the drain plug out and now have a huge mess? Was it so clean it was hard to see on the stick?
    Come on, the world wants to know.
    LARRYH, tomberlin, Snapshift and 4 others like this.
  10. augustxke
    augustxke Formula Junior
    Feb 7, 2009
    412
    MN
    Bruce
    I have always checked my oil in the scud, with the cap resting on the neck at the proper temp. Last week I was told by a ferrari tech at the dealership, when the car was in for the brake fluid cap recall, that the dip stick should be screwed all the way down to get a proper measurement. With the oil measured like this they said my engine was over filled and they removed some oil. What do you think?
  11. RayJohns
    RayJohns F1 Veteran
    7,941
    West Coast
    Ray
    This is why I don't let people at the dealership touch my cars.
    Ray
    flash32 likes this.
  12. Snapshift
    934
    Centralia IL
    Lyle D. Pahnke
    The measurement will be correct if the cap flat spring bayonet lugs drop down into their respective slots and the cap gasket is resting on the sealing surface of the filler neck on the reservoir/aerator. It doesn't have to be locked/screwed in as long as the above parameters are met. I think that by stating that it should be screwed down obviates any potential error that might occur if attention is not paid to getting the cap to fully drop down on the filler neck. The error is about a half inch difference if the cap gasket is not seated on the sealing edge of the filler neck.
    RayJohns likes this.
  13. RayJohns
    RayJohns F1 Veteran
    7,941
    West Coast
    Ray
    Yeah, as Lyle says above there, the spring part has to sit down in the lugs / cut out area, but don't go screwing the cap down tight.
    Ray
  14. augustxke
    Feb 7, 2009
    412
    MN
    Bruce
    Thanks guys
  15. Ferrari Tech
    Mar 5, 2010
    1,233
    Georgia
    Wade Williams
    Some caps are 1/4 turn and some are threaded. My personal rule, just what I use and by no means is this to be taken as the way it should be.
    If it is a screw on cap, I add oil until it is just before minimum after startup. It will rise to almost max when hot. If it is a 1/4 turn, I have it seated and at minimum after start up. I have had cars come in that have nothing on the stick and it still has plenty of oil. I tell my clients that if they check the oil and the see anything on the stick, they will be fine. I have had too many over fill trying to "get it right". There is plenty of oil in these cars. I want my clients to drive and enjoy the car. I also let them know that if they loose enough oil to be an issue, they will know it, see it, smell it.
  16. nwhite96244
    nwhite96244 Rookie
    Jun 27, 2023
    40
    Northville mi
    Nick white
    No luck. Checked hot and have metal shavings in oil so something’s going on. Looking like I’m pulling engine and rebuilding over winter
  17. Snapshift
    934
    Centralia IL
    Lyle D. Pahnke
    Wow! after only 3K miles? can't imagine what would go wrong causing metal shavings after an oil change. Can you see anything in the drained oil?
    GL wi that mess. Please let the forum know the findings.
  18. tbakowsky
    Sep 18, 2002
    20,048
    The Cold North
    Tom
    Umm..you can tell you have metal shavings in the oil..but you have no oil on the dip stick?
    The 430 engine is pretty damn solid. I think you are doing something really wrong.
    hessank, Challenge and fatbillybob like this.
  19. nwhite96244
    nwhite96244 Rookie
    Jun 27, 2023
    40
    Northville mi
    Nick white
    lol id love some advice if you have any. Food for thought the car was in hurricane Ian and was brought to Michigan and had no water in oil or gear fluid. changed all the wiring and components to get up and running. idk where else the oil could be going it. it has oil pressure and doesn't overheat when running but does have a ticking noise on the passenger side. showing no codes beside exhaust/intake timing.
  20. RayJohns
    RayJohns F1 Veteran
    7,941
    West Coast
    Ray
    On my Toyota pickup, it was drinking oil like there was no tomorrow. However, ran totally amazing. I did several 1000 miles trip, no sweat. However, it was using 1 quart of oil every 350-400 miles pretty routinely. Where the heck is the oil going???
    I had run several compression checks on the motor and all the readings looked pretty decent across the cylinders. Motor was actually running very strong and gas mileage was excellent.
    One day, I was at Costco and the motor made a funny stumble and then recovered. It was very mild, but I thought "that didn't sound quite right". When I got home, I ran yet another compression check and this time one of the cylinders was down maybe 30 PSI below the rest. Oh, oh. I put a bore scope into the chamber and definitely something had gone through and banged up the piston a little bit and scored the side of the cylinder wall.
    I decided to pull the motor back part (I had rebuilt the top end only 4000 miles previously, but foolishly didn't bother with the short block because it appeared the previous owner had bored it +.020" over). Anyway, I pulled the motor apart and what I found was every upper compression ring on every piston was fractured into multiple pieces. One of the pieces had made its escape by digging a small hole through the piston ring lands. Wow.
    I ended up buying new pistons and rings and rebuilt the motor. During the rebuild I discovered that whatever rocket scientist had rebuilt the motor previously had installed the incorrect size rings. Yes, they did bore the block over .020"; yes they did buy new ACL pistons that were .020" larger.. however, apparently someone didn't understand that you also have to buy piston rings which are also .020" oversize. Whatever clown assembled the motor used STD rings, which of course were too small and thus did not maintain the right arc, black spacing nor the correct tension or ring gap. The result was the rings failed and fracture. Oil rings barely had any tension against the cylinder walls. Never seen that before; my guess is a shop bored the block over, then someone without any real automotive knowledge bought rings without realizing they needed .020" over.
    If your Ferrari is consuming the level of oil you are suggesting here, I think some failure in the rings would be high on my list of possible suspects. Either that or some failure in the crankcase ventilation system, which might be allowing oil to be burned steadily through the intake. Have you tried smelling the exhaust to see if you smell oil? Or maybe have someone drive behind you and see if any blue/white smoke is coming out under hard WOT runs?
    Ray
    Chindit likes this.
  21. Chindit
    Chindit Formula Junior
    Oct 18, 2008
    428
    Navarre, Florida
    Nick P.
  22. RayJohns
    RayJohns F1 Veteran
    7,941
    West Coast
    Ray
    Also check the plugs for oil fouling or any oil burned onto the plug / smell of oil, etc.
    Ray
  23. nwhite96244
    nwhite96244 Rookie
    Jun 27, 2023
    40
    Northville mi
    Nick white
    Plugs all new camera shows nothing out of ordinary. Oil goes directly into gearbox essentially but must be going somewhere else somehow
  24. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,440
    Santa Clarita, CA
    Are you saying the engine oil is going from the engine into the gearbox by itself? There’s no way it could do that. It would run out of the engine main seal in front of the clutch, then onto the ground.
    Not questioning you, because I see by your profile that you are a diesel engine mechanic. Just wondering what’s going on with your car.
  25. RayJohns
    RayJohns F1 Veteran
    7,941
    West Coast
    Ray
    Technically the lubrication system for the gear box and motor are two different systems. The oil separator / reservoir for the dry sump system is bolted to the top of the transaxle though.
    There's only so many ways out for the oil.
    Ray
