Can’t get past 2nd gear in 575M | FerrariChat
Discussion in '456/550/575' started by thomharrow, Jan 8, 2022.
  1. thomharrow
    thomharrow Rookie
    Jun 14, 2009
    26
    New Canaan, CT Vero Beach, FL
    Thom Harrow
    About a month ago I was driving and couldn’t get my ‘02 575M past 2nd gear. It’s an F1 w 14,000 miles. Reverse, 1 and 2 are fine, no noises, clunks or otherwise. Just won’t upshift past second. Oil level is correct and a new microswitch and oil pump have been installed.
    Any thoughts?
  2. tazandjan
    39,186
    F1 issue. When it happened to me, it was a loose potentiometer. Once tightened and the faults cleared, worked fine. Need someone with an SD2 or equivalent to diagnose and see exactly where the problem is.
    Ferrari55whoa and greg246 like this.
  3. Qavion
    Qavion F1 World Champ
    14,328
    Ian Riddell
  4. tazandjan
    39,186
    Ian- They are talking about the clutch position sensor, not an F1 potentiometer, although that sounds like what their original problem may have been. The F1 potentiometers are actually pretty easy to swap.
    Qavion likes this.
  5. Qavion
    14,328
    Ian Riddell
    Are there two bolt-on F1 potentiometers on the 575, not like the horrible single unit on the 355F1? i.e. selection potentiometer and engagement potentiometer?
  6. tazandjan
    39,186
    Ian- There are actually 6 potentiometers in the 575M, called solenoids in the WSM. EVF for the clutch, EV1 and EV2 for engagement, and EV3, EV4, and EV5 for selection. The first three are proportional and the last three are on/off.
  7. Qavion
    14,328
    Ian Riddell
    Ah, ok.. Now I'm with you. I've never heard the solenoid valves being called potentiometers before. Potentiometers usually convert position into electrical signals. Solenoid valves convert electrical signals into hydraulic flow.
  8. tazandjan
    39,186
    Ian- Who knows, I may have it screwed up.
    Qavion likes this.
  9. hwyman
    hwyman Formula Junior
    Jun 25, 2015
    329
    Canada / Los Angeles
    Not sure on F1 but I know on Egear the dealer computer could run the shifter through all the gears and record the readings of each sensor. Doesn't take much in these cars, on my Murci it was a slight binding caused by the actuator being a hair out of alignment. Honestly though it could be a switch, pressure issue... really anything
  10. dinos575m
    dinos575m Rookie
    Oct 28, 2019
    49
    Dean Pellegrino
    Thomharrow
    so what was the final fix? Thanks Dino
