Can't get rid of the check engine light | FerrariChat
Discussion in '360/430' started by Nickferrarif430, Jul 24, 2024.
  1. Nickferrarif430
    Nickferrarif430 Rookie
    May 15, 2023
    7
    Montreal
    Nick
    Little problematic with my F430 2006, I recently changed my Optima red top battery for the right Interstate MTZ-34R battery after getting multiple codes such as P1602,P1611, B1005, B100A, U1706. My Launch X431 will clear the codes but they will reappear on the next start. I'm started thinking that the clear DTC feature in the X431 doesn't clear the memory or that the health scan option is creating codes because it might interrupt signals (U1706). The car is running perfectly fine, with no issues whatsoever.
    Has anyone had the same issue?
    AandSC likes this.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
    Which ones are staying / reappearing ?
    If you don't do a full scan and just go into each modules and clear and re-read code - that should help
  3. Nickferrarif430
    May 15, 2023
    7
    Montreal
    Nick
    all of them
  4. jerbear27
    jerbear27 Formula Junior Silver Subscribed
    Jun 12, 2022
    299
    CT
    Jeremy
    When I scan with my x431 I get some canbus errors and a few other benign codes, but other than that, nothing unless something is wrong.
  5. Nickferrarif430
    May 15, 2023
    7
    Montreal
    Nick
    the problem is the check engine light keeps coming back....
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
    If the "P" codes reappear, i would check battery or fully charge battery ( theory here is the new battery maybe was sitting long on shelf and needs to be fully charged )
    jerbear27 likes this.
  7. Nickferrarif430
    May 15, 2023
    7
    Montreal
    Nick
    The battery is brand new, manufacture date is June 24. It would do that even right after removing the charger.
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
    I understand your point .. but it doesn't mean it isn't defective .. check voltage at battery terminals after being off charger for 12 - 24 hours, check while running, check while cranking - report back
    Also check voltage behind seat near ECU's
    Check connections .. maybe not tight
    If these lights weren't on before the old battery went south then it is the new battery or a connection that is causing it
    fstbiker likes this.
  9. Nickferrarif430
    May 15, 2023
    7
    Montreal
    Nick
    Perfect will do
