Capristo bypass valve | FerrariChat
Discussion in '348/355' started by Big Lebowski, Oct 18, 2013.
  1. Big Lebowski
    Big Lebowski Formula Junior
    Jan 24, 2013
    337
    Peach state
    Brownie
    After several months of slowly going insane from my rattling exhaust bypass valve I had the Capristo bypass valve installed (couldn't stomach the extra $600 for OEM). The rattling is now gone (hallelujah) but I was really surprised by how different the exhaust sounds. I have Fabspeed headers, high flow cats and Nouvalari super sport, all installed by PO. It was kind of surprising how much the sound changed. The sound is fantastic although a bit louder at idle than I would prefer which makes me wonder whether the vacuum pressure is working properly to close the valve.
  2. 0.0.1.99
    0.0.1.99 Formula Junior
    Jan 14, 2012
    424
    Carolinas
    Ken
    To correct the buzzing on my oem bypass valve, I had to perform both of the following:
    Step 1: Increase the pre-load tension on the bypass actuator rod (rotate counter-clockwise to lengthen).
    Possible fix for a noisy/rattling 355 exhaust valve - FerrariChat.com
    Step 2: Remove the bushing opposite the actuator rod (used a dremel), lose the ball and re-weld.
    http://www.ferrarichat.com/forum/348-355/391007-bypass-valve-has-balls.html
    The sound of the exhaust is so much more satisfying now that it is not in competition with the bypass valve buzz. The Capristo is the obvious replacement solution, just still overpriced, especially as compared to this repair.
    The fixes here take about 1-2 hours including removal and reassembly. Most local auto repair shops will tac weld the bushing back into place for $20 or so.
  3. CANDREAM
    CANDREAM Canada
    Nov 13, 2009
    407
    Burlington, Ontario
    Sadi
    The valve closes as soon as the vacuum builds up....which is a few seconds after you turn the engine on.
    if you floor it at idle, you should hear the difference when the valve opens...around 4k ish
    the biggest difference i found is the way the valve seems to open .....smoother ...although that is not necessarily the case as all is controlled by the ECU, but the noise comes on slower/more natural vs the oem valve...i am guessing this is due to the spring loading to open vs the oem way.
    of course no buzz which distroyed the beautiful sound at idle.....
    I am curious about the removal of the ball from the oem valve and why would that work/remove the buzz ,,,,when the bushing is the one worn ?
    Deadshort likes this.
  4. Genyosai
    Genyosai Formula Junior
    May 28, 2008
    501
    SC
    Nicholas
    Hey, 355.
    It's me... the PO lol!
    I had the Capristo on another F355 and I had to make sure that I had the solenoids connected properly because the Caprist works in reverse... using vac pressure to keep the valve closed, then bleeding off vac pressure to open it, hence the vac leak sound you should hear when you throttle it.
  5. Big Lebowski
    Jan 24, 2013
    337
    Peach state
    Brownie
    Nick, the initial Capristo turned out to be faulty. Got a replacement and it works fine now.
  6. Genyosai
    May 28, 2008
    501
    SC
    Nicholas
    Ahhh. Good news! I like reading your threads to see how she's doing. You're taking awesome care of her :D
    Enjoy.
