Capristo Exhaust on the 599 | Page 2 | FerrariChat
Discussion in '612/599' started by tailhappysg, Dec 22, 2011.
  1. g4titan
    g4titan Formula 3
    Feb 6, 2010
    1,196
    Around
    Nico
    Will know when I get her back from the shop, a couple of other things being tied up.
  2. papataori
    papataori Karting
    Oct 24, 2007
    181
    Nashville, TN
    Will
    Thanks for the info! I look forward to hearing about the droning...or hopefully lack thereof.
  3. Fiorano57
    Fiorano57 Formula 3
    1,689
    Ted,
    I kept the stock mufflers and installed Fabspeed secondary cat straight pipes...I also plugged the vacuum lines so the valves in the mufflers stay open all the time..I think it sounds great with NO drone inside or at highway speeds....Kevin
  4. g4titan
    g4titan Formula 3
    Feb 6, 2010
    1,196
    Around
    Nico
  5. Nicofr
    Nicofr Karting
    Dec 11, 2010
    103
    France - near Paris
    #30 Nicofr, Jan 27, 2012
    Hi, did you put the cat delete pipes on your car and these videos?
    I have the Capristo mufflers on my car, and I have the remote control for the valves, and the sound is really pleasant, with the choice to reduce it at low speed when it is necessary.
    I did not put the cat delete pipes (yet) and I don't know whether I will install them because I fear it could be too noisy, with drone. I will try perhaps.
    Any information?
    Thanks & Regards,
  6. Nicofr
    Nicofr Karting
    Dec 11, 2010
    103
    France - near Paris
    Hi G4titan,
    Which springs & sway bars did you choose?
    HGTE handling kit : 4 springs + the rear sway bar + ECU?
    H&R sway bars & springs?
    Novitec KW springs ?...
    Thanks & Regards,
  7. ted 191
    ted 191 Karting
    Sep 6, 2005
    223
    yorkshire
    chris heeley
    I've just done the same, sounds awsome, the tubi rumore was still giving quite a bit of droning noise even with the cats fitted. The sound is now fine for me, next up is lower springs and I am trying to sort gearbox ecu upgrade to HGTE spec, but UK dealers are clueless about this and want to replace the complete ECU at over £5000.
  8. g4titan
    g4titan Formula 3
    Feb 6, 2010
    1,196
    Around
    Nico
    I did the H&R springs and Sway bars... the parts are stuck in customs but should be here this week for final install next.
    Looking at ECU options but not high on my to do list :)
  9. papataori
    papataori Karting
    Oct 24, 2007
    181
    Nashville, TN
    Will
  10. locodiablo
    locodiablo Rookie
    Apr 24, 2006
    3
    switzerland
    Here's a video of my (2010) 599 with Capristo exhaust and cat delete pipe.
    [ame]http://www.youtube.com/watch?v=u6plSx-pvlo&list=UUUhRe0JbbsNKHLUvzAX7eBA&index=4&feature=plcp[/ame]
    PS: matt red paint is from factory :)
  11. crinoid
    crinoid F1 Veteran
    9,484
    LaCrinoid
  12. infinity
    infinity Karting
    Apr 14, 2005
    75
    The Netherlands
    Dries
    Might be i'm wrong, but it looks like only your third braking light is working?
  13. Nicofr
    Nicofr Karting
    Dec 11, 2010
    103
    France - near Paris
    Hello,
    Don't you feel that the sound can be annoying when you accelerate at low rpm? Do you feel more power too?
    I recognize the sound I have on my 599 too.
    I made installed the Capristo cat delete pipes 3 days ago (I had already the Capristo mufflers) and
    I confirm that the sound is really high, very castling in small speeds, and when you increase the engine speed ...
    This has awakened the heart of Enzo is in it too: I feel much more power
    Of course, you can close the valves of the muffler and it reduces the sound, but it's so nice to hear that engine
    Regards,
  14. locodiablo
    locodiablo Rookie
    Apr 24, 2006
    3
    switzerland
    @infinity....you're right, the brake lights are not working.But now work again...:)
    @Nicofr....yes, I feel more power too. capristo has measured 39 hp more on the performance test station.
    the sound is really loud. But the car is so well insulated that it is not a problem for the driver :)
  15. robert biscan
    robert biscan F1 Veteran
    Jan 17, 2003
    5,066
    Nashville and Palm b
    robert s biscan
    I have the capristo on mine and the sound is wonderful. I did the cats as well.
