Capristo Stage 2, Bypass Removal | FerrariChat
Discussion in '348/355' started by MM355, Mar 9, 2015.
  1. MM355
    MM355 Formula 3
    Apr 7, 2008
    1,152
    GMT + 3
    Hello,
    Typing this for a friend of mine who has a 96 f355.
    Currently has the OEM exhaust and a Capristo Stage 2 is on the way. The OEM bypass valves rattle and sounds nasty.
    Would it be possible to delete the bypass system when the Stage 2 Capristo arrives or does the Capristo come with new valves.
    We are planning to get Hyperflow catalytic as well.
  2. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,813
    Lake Villa IL
    Capristo makes an upgraded bypass valve (not included with the muffler) or you may be able to adjust the original so it doesn't rattle.
    You can delete the valve but I personally would not. (and you would need a work around for the post valve thermocouple, not sure what that is)
  3. SpiceV8
    SpiceV8 Karting
    Apr 10, 2012
    77
    London
    #3 SpiceV8, Mar 9, 2015
  4. eyboro
    eyboro Formula Junior
    989
    Chicago
    Eitan
    #4 eyboro, Mar 9, 2015
    I have a bypass valve which I refurbished and adjusted to better than factory specs you will get no codes and the valve will open at around 2500-3000 RPM as opposed to 3500-4000 RPM and guaranteed not to rattle. with stainless steel O-rings. IF you delete the valve, You will get CEL codes for sure. Send me a PM if you're interested.
  5. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,813
    Lake Villa IL
    Isn't the rpm switch point for the valve solenoid/ecu controlled?
  6. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,917
    Richmond
    Pete
    Don't do it, your ecu will get the wrong feedback from your o2 sensors and screw up the mixture trim if you leave the bypass open all the time.
    The challenge cars had a bypass delete,but they spent most of their time running at wot where the o2 sensor feedback isn't used. I would never do that on a street car without moving the o2 sensors to before the y in the headers.
  7. adhesivo
    adhesivo Karting
    Jan 30, 2012
    94
    Los Angeles
    Miguel
    What does WOT stands for?
  8. Subarubrat
    Subarubrat Formula 3
    Apr 1, 2009
    2,072
    VA
    Scott
    Wide Open Throttle.
    Bobzdar is speaking the truth, by reducing the amount of exhaust passing the 02 sensors you screw up the calculations by altering their data. How much is the subject of debate, but it will alter the data.
  9. MM355
    MM355 Formula 3
    Apr 7, 2008
    1,152
    GMT + 3
    Thank you for the quick replies Gentlemen,
    I have just placed an order on the Capristo Bypass Valves.
    Will be running them with the Capristo Stage 2.
  10. Subarubrat
    Apr 1, 2009
    2,072
    VA
    Scott
    The Capristo will make you feel like you just bought a new car!
  11. adhesivo
    adhesivo Karting
    Jan 30, 2012
    94
    Los Angeles
    Miguel
    So does the Capristo valve do anything regarding sound?
