Capristo Twin Sound 355 M2.7 install | FerrariChat
Discussion in '348/355' started by redwedge, Oct 16, 2016.
  1. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    473
    London
    Steve C
    #1 redwedge, Oct 16, 2016
    Does anybody have any photos of a Capristo Twinsound installed in a M2.7 355?
    I can see that the design should increase flow as there is no merge point like the standard Y-pipe, but there's no way those two inlets will line up with the bypass take-offs on the manifolds.
    Have people had to have something fabricated to fit this? Or perhaps there's some other part sold by Capristo that's not pictured?
    Steve
  2. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,639
    Elliott Caras
    Are you certain its for a 2.7? As you say there are no way the secondary tubes would meet the header outlets are as they are up turned on the 2.7 headers.
    This looks like if the pipes were rotated or swapped they might mate to the 5.2 headers which have a straight outlet on the secondaries.
  3. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I've seen this posted before and don't understand how it will fit 2.7 or 5.2
  4. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Yeah I dont think its for a 355 if it was must be from a complete custom exhaust
  5. F355Bob
    F355Bob Formula 3
    I thought it does not use the bypass but has twin valves on either side of the exhaust.
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Perhaps but the two entry pipes are too close together
  7. F355Bob
    F355Bob Formula 3
    Those entry pipes rotate so they may not be at the correct angle in that picture. When they rotate they become further apart.
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Thank you, Bob
  9. nathandarby67
    nathandarby67 F1 Veteran
    Feb 1, 2005
    8,349
    Mississippi
    Nathan
    So what do you do with the upper outlet on the headers that normally go to the Y pipe?
  10. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,639
    Elliott Caras
    This is what I was saying in the first reply. Rotating the pipes might allow it to mate directly to the headers, I still think with the straight angle the pipe sits might not fit the upturned header outlets that are on the 2.7 header.
  11. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,639
    Elliott Caras
    #12 MAD828, Oct 16, 2016
    The capristo twin sound still uses both the upper and lower header outlets, it just increased flow by situating two bypass valves all the way down the exhaust path near the muffler and eliminating the bottle neck. A similar solution is used on 360 and 430 exhaust bypass setup.
  12. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,439
    Tucson, Arizona, USA
    Robb
    Taz has one. Hopefully he will see this and chime in...
    Robb
  13. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    #14 taz355, Oct 19, 2016
    If you turn those it might fit. Mine s the new design and thise pipes are now fixed with a mesh flex joint.
    Basically the exhaust bypass connects directly to the headers with a fairly straight shot out. It does not go to muffler and has no cats.
    The other header connection goes from header to cat then to muffler.
    The muffler itself also has threeo holes on each side, 6 total that also allow flow when the muffler sees to mich volume i think.
    Same as this without the connectors on the bypass but where the connections are it has a flexjoint.
    Youncan see the flex joint in the small upoer right pic of the link above
  14. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I think those pipes are also swapped end for end. If you did this then it might work.
    As said previously on the 2.7 the angle comming on bypass is turned up and in.
  15. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Those pipes need to be swaped side to side.
    Ie left pipe needs to go over to right side and when you do this you will see the angle will line up.
  16. Robb
    Robb Moderator
    Feb 28, 2004
    14,439
    Robb
    Grant's exhaust pretty much achieve's "holy ****, daisy cutter status with this and with the Gruppe M airboxes when he loads up next to you...
    I love my higher pitched sound 3, but yes, his setup will impress you and keep you laughing for a long time at how loud it is... :D
    Robb
  17. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
    I have had the original capristo exhaust for the last 12 years. This feeds into the Y piece catalyst via the original by pass valve.
    So looking at this new set up above, it deletes the top Y piece catalyst. Is that correct, no cats?
    So potentially with bottom straight pipes and this new system, there will be no cats on the car?
  18. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,639
    Elliott Caras
    Correct on all counts.
  19. redwedge
    Sep 30, 2012
    473
    London
    Steve C
    Thanks all for your input.
  20. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    Thats great, thanks :)
  21. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    As said above all correct but if you want it to meet emmisions just throw in the cats on the main circuit.
