Car Lift!! | FerrariChat
Car Lift!!
Discussion in 'General Automotive Discussion' started by trader12, Jan 19, 2008.
  1. trader12
    trader12 Rookie
    1
    Hi,
    I have a small garage 20 x 19. Which car lift do you recommend for the C5 Z06? I am looking for some car lifts If anyone has any info on what I should look for please let me know.
  2. UroTrash
    Jan 20, 2004
    40,488
    Purgatory
    Clifford Gunboat
    Welcome to the board, Trader.
    There are a few threads about just this subject already, a couple of them recent.
    You can click on the "search" button upper left and type in "car, lift", but that might be too vague. You might want to add someting like "4-post" or "two-post" to narrow it down.
    Now's time to duck and cover as the hand granades are in the air as we speak.
  3. toggie
    toggie F1 World Champ
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    Yes, lots of info can be found on lifts using the Search feature.
    Big issue is vertical clearance. With the garage door open, how much room do you have from the floor to the first obstacle?
    There are several good vendors to choose from. One of them is the Revolution / Rotary Lift.
    See http://www.revolutionlifts.com/ for more info.
    They have a nice "Ceiling Calculator" web page here:
    http://www.revolutionlifts.com/Ceiling.asp
    Good luck.
  4. cassand21
    cassand21 Rookie
    2
    Hi
    I would like to suggest you to have a look at Harding steels lifts; I had a quite good time using their lifts. You can look out for Auto Parking Lift As you have mentioned your requirement is for a small garage. It’s very important for you to take and consider before buying a lift that it should be in the dimensions suited to your garage.
    Hope this helps!!
  5. Gerry328
    Gerry328 Formula 3
    2,442
    Home
    Gerry
