Car shifts to Neutral | FerrariChat
Discussion in 'California/Portofino/Roma' started by bsamini, May 14, 2017.
  1. bsamini
    bsamini Rookie
    Aug 29, 2016
    5
    I have a 2010 Cali with 8K miles. I purchased the car last year with 5K miles. From 2010 to 2016, the car was driven very little. On 2 occasions (within the last 3 months), the car has -- on its own -- shirted into to Neutral while i was stopped at a red light.
    I know i didn't engage neutral in either case because i only one had on the wheel in both cases.
    Has any experienced this?
    Thanks.
    -bobby.
  2. munir
    munir Rookie
    Nov 23, 2015
    4
    After a few minutes it automatically shifts to neutral to protect the clutch. Nothing to worry about.
  3. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,815
    Also if you do not keep a certain amount of pressure on the brake, the car will interpreted that as a non braking input state and then begin the countdown to shifting to neutral.
  4. Motob
    Motob Formula 3
    Nov 11, 2003
    2,343
    Frederick, Maryland
    Brian Brown
    A California has a DCT transmission with no clutch to protect (like an F1 transmission). It is not normal for it to shift to neutral when stopped at a red light with your foot on the brake.
  5. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,049
    DFW, Texas
    Tom C
  6. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    #6 4th_gear, May 17, 2017
    I imagine leaving a DCT in gear for prolonged period while stopped may increase temperatures inside the mechanism. There is always some friction involved with meshed gears and with metals, higher temperatures increase wear. Temperature management is very important.
    Also not sure if the DCT benefits from air movement while the car is in motion to dissipate ambient hot air but maybe it does.
  7. MalibuGuy
    Sep 18, 2007
    5,815
    We here on FChat cant be bothered to read the manuals that come with our cars! (Joke)
    "Badges? Badges? We don't need no stinking badges!" from the Bandito in the film The Treasure of Sierra Madre
  8. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    LOL! :D
  9. tomc
    Apr 13, 2014
    26,049
    DFW, Texas
    Tom C
    I've read my manual numerous times, sometimes just for the heck of it, and there are many areas where the manual is shall we say lacking in clarity. In such cases, F-chat to the rescue! [emoji3]
    T
  10. RickLederman
    RickLederman F1 Rookie
    2,836
    Swanton Ohio
    Rick Lederman
    It is simple, if you stop and take your foot off of the brake and leave it off of the brake (I think for a minute and can go out and start the Cali to check if needed) then it shifts to Neutral at the end of that time period. If you hold your foot on the brake, or hit the brake every 30 seconds then it does NOT go into Neutral. With 3 Cali's and probably 80,000 total Cali miles, this is how it works.
  11. GRW
    GRW Rookie
    Sep 10, 2016
    8
    Arlington, TX
    Gary Watkins
    When sitting at stop light for extended time in Auto it will shift to neutral. It doesn't shift when in manual mode.
