Car Starting Issue/F1 trans.......HELP! | FerrariChat
Discussion in '360/430' started by Duc5150, Feb 14, 2015.
  1. Duc5150
    Duc5150 Karting
    Jul 12, 2012
    61
    The OC, So CA
    ...OK this is a strange one....I'm lost....my 2008 SCUD cranks over but immediately shuts off (like it's some kind of an immobilzer issue) BUT if I go up a gear from neutral and then back to neutral car cranks over fine......anyone have any input on this?
    My guess is that it's some type of sensor issue?
    Thanks in advance for any help
    Todd B.
  2. F430giallomodena
    F430giallomodena Formula Junior
    Mar 2, 2012
    910
    Lugano, Switzerland
    do you get any gearbox failure warning?
  3. Duc5150
    Duc5150 Karting
    Jul 12, 2012
    61
    The OC, So CA
    Actually yes I did get this warning....thanks for the reminder
    Any clues?
    Thanks,
    Todd B.
  4. F430giallomodena
    Mar 2, 2012
    910
    Lugano, Switzerland
    based on what you wrote I suppose you have either one of these problems:
    - wrong PIS
    - bad F1 sensor (must be replaced)
    In both cases your F1 system cannot start properly, in the first case because your clutch is in the wrong position (PIS) and grabs on the gearbox instead of sliding and therefore not letting your engine turn properly, in the second case the bad sensor (broken?worn out?) sends wrong information of your clutch position even if it's correct and your car is shut down to prevent gearbox damage.
    As told in both cases you'll end up with your car stuck dead.
  5. Duc5150
    Duc5150 Karting
    Jul 12, 2012
    61
    The OC, So CA
    OK got it....yes this makes absolute sense......
    Many thanks for the help!
    Todd B.
  6. gsworld2014
    gsworld2014 Formula 3
    Dec 23, 2014
    1,105
    South Florida
    Greg S
    One of my friends just had this happen. They had to replace the tcu. That fixed it.
