430 - Car starts, but won’t go into gear. | FerrariChat
430 Car starts, but won’t go into gear.
Discussion in '360/430' started by Skywhale, May 11, 2024.
  1. Skywhale
    Skywhale Karting
    Aug 17, 2022
    180
    South Florida
    Carsten
    So I drove my F430 this morning, everything was normal. Parked it in the garage, and walked away for maybe an hour. Got back in the car to take it for another drive, car starts up, but it’s stuck in neutral. Pulling paddles doesn’t do anything, stays in neutral. Reverse doesn’t work either.
    Got these codes from reader:
    P1602 - PERMANENT POWER SUPPLY
    The direct supply from the battery has reached the minimum value for the ECU operation
    and
    P1611 - PERMANENT POWER SUPPLY
    The supply voltage is below the minimum permitted level.
    VALUE TOO LOW
    So I’m hoping this is just a case of bad battery? But wanted to see if anyone else has experienced this or found a different solution.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,900
    Central NJ
    Dominick
    Hmm .. could be the battery is weak .. maybe give it a little test - measure voltage at battery terms while cranking and just sitting
    I am wondering if you have a no pressure in system for the f1 - do you hear pump running ?
    Next step if battery is good and you hear pump come on normally ..would be shut battery off from front trunk, wait 20 mins or so and reconnect - the try it .. always remember to do a throttle body relearn ( just idling after warm up for 10 mins without any electrical drain)
    Qavion likes this.
  3. andrejwolk1975
    andrejwolk1975 Karting
    Feb 28, 2020
    116
    Italy
    Andrea M
    My guess: battery. New one and problem solved. I think there is a "factory threshold" of voltage: under this, electronic still works but starts acting "strange"
  4. Skywhale
    Skywhale Karting
    Aug 17, 2022
    180
    South Florida
    Carsten
    Pump sounds fine. I have the scuding Swiss relay too to hopefully prevent it dying out.
    I am going to start with battery replacement, just picked one up…
    The F1 pump primes and doesn’t run long. I also have the scuding Swiss relay to prevent it from burning out. But yeah, everything was great this morning on my first drive.
    I’ll post again if the new battery doesn’t solve the issue… It’s amazing, with all the dumb error codes, you’d think “your battery is ****” would be one of them.
  5. Skywhale
    Skywhale Karting
    Aug 17, 2022
    180
    South Florida
    Carsten
    Well that didn’t work. I disconnect frunk battery connection. I added a new battery, reconnected battery in frunk, turned on power, let it set until I got the okay. Then I let the car idle for a good 10 min. Still, nothing. The car sounds fine, the F1 pump primes normally, but the car will not go into any gears.
    Any other ideas?
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,900
    Central NJ
    Dominick
    Give me a call in about 90.mins ..sent you a pm
  7. brookliner7
    brookliner7 Formula Junior Silver Subscribed
    May 5, 2018
    839
    San Antonio, TX
    Hans
    Are your brake lights working?
    Qavion likes this.
  8. Skywhale
    Skywhale Karting
    Aug 17, 2022
    180
    South Florida
    Carsten
    Yup. Brake lights good, engine lid, trunk lid… all good.
  9. Skywhale
    Skywhale Karting
    Aug 17, 2022
    180
    South Florida
    Carsten
    Got the answer… and don’t worry, it’s stupid.
    Thanks to @flash32 for his help.
    He gave me a call and we troubleshooted everything related to the F1, and that’s how I realized it’s gotta be something simple because every number related to the F1 system in the diagnostics was looking healthy.
    So a long way back when the car was new to me and I didn’t feel comfortable working on it yet, I had an independent place tackle a few big jobs. One of which was valve cover gaskets, which on a spider, requires quite the bit of disassembly.
    Turns out, the hose that connects to the clutch was just a tiny bit disconnected (it wasn’t snapped on). It’s probably been that way this whole time but something about today’s last drive knocked it just enough loose to finally cause this failure.
    I stuck it back on, and all is better.
    So dumb…
    here’s the culprit:
    Willl, QSA, Mercedes_Benz and 11 others like this.
  10. Mercedes_Benz
    Mercedes_Benz Formula Junior Silver Subscribed
    Nov 1, 2003
    515
    South Florida
    Another amazing save by the one and only flash32!
    Qavion, Plainview and flash32 like this.
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,900
    Central NJ
    Dominick
    Thanks Neal ... but honestly, I just gave Carsten some info and he figured out
    Sometimes just talking about stuff makes the light bulb go on
    That is why I normally take the conversion offline and then either myself or the OP report back the findings
    Although this is not the first time... I had a person where the hose was "on" but not really connected
    The key is to look at clutch plate travel and see if clutch is actually moving and if moving the correct amount - that is a key data point
    Willl, Qavion, sfcarguy and 2 others like this.
  12. FerrfanFL
    FerrfanFL Formula 3 Rossa Subscribed
    Feb 8, 2021
    2,254
    Florida
    Ara
    so happy to hear it wasn't something worse
    flash32 likes this.
  13. swc5150
    swc5150 Formula Junior Rossa Subscribed
    Jan 5, 2021
    721
    Wisconsin
    Scott Calderwood
    You really have to push hard on those fittings in order to connect them securely. I can definitely see how this could happen!
    flash32 likes this.
  14. Johnny*G
    Johnny*G Rookie
    May 20, 2025
    1
    John Glosek
    You just saved me a tow! I removed my engine covers and must have flicked the collar enough to disconnect this little bastard. Thank you!
    brookliner7 likes this.
  15. Skywhale
    Skywhale Karting
    Aug 17, 2022
    180
    South Florida
    Carsten
    awesome to hear. It’s amazing how easy it is to accidentally disconnect that line… sketchy, really. I thought about 3D printing a coupler in carbon fiber that can snap around it just in case. Ha.
