430 - Car storage lifts, any opinions | FerrariChat
430 Car storage lifts, any opinions
Discussion in '360/430' started by Mario Andretti, Jul 7, 2022.
  1. Mario Andretti
    Mario Andretti Formula 3
    1,776
    Boston
    Hi,
    For you out there space challenged like me; who are using a lift for car storage... Anyone has any feedback on these:
    https://www.wildfirelifts.com/car-lifts
    The single one seems to fit in my newly built garage, and I would like the option of having 2 cars in the garage in the winter...
    Any other good options that dont break the bank?
    Many thanks
  2. ttforcefed
    ttforcefed F1 World Champ
    19,256
    anything that goes on a 4 post lift, never comes down. spend the extra money on a single post
    sherpa23, sisiay, Sj_engr and 2 others like this.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,919
    Central NJ
    Dominick
    Although the single post lifts are nice ..from a cost prospective a 4 post lift from atlas is a good way to go
    I have two in my family ..a little more intrusive but i like them ..you can also roll them in position if your garage allows
    one4torque and Mario Andretti like this.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,919
    Central NJ
    Dominick
    That is true ..once on lift it normally isn't the first car to take out
  5. Mario Andretti
    1,776
    Boston
    I can't afford screw them onto concrete, I like the option of being able to move them... as spring hits , I will not use it most likely anymore ....
  6. Mario Andretti
    1,776
    Boston
    What do you mean... I mean it won't come down until spring, I don't drive the Ferrari in winter :) It CAN come down though in spring.
    tonyswfla likes this.
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,919
    Central NJ
    Dominick
    The ideal is having a two car garage with one door with high tracks.. this way you can put on one side when not in use and move to center to work on it
    mx1 likes this.
  8. ttforcefed
    19,256
    4 post lifts are like going to the dentist...
    plastique999 and AtomicPunk88 like this.
  9. chnco
    chnco Formula Junior
    Dec 20, 2014
    464
    Atlanta, GA
    Allen C
    There are many many options for 4 post that don’t bolt down, suggest looking for local installer for guidance
    Would also look into a side Jack garage door opener if you haven’t already
  10. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,970
    Southlake, TX
    Rob Lay
    I like the single post lift for my townhome where space is at a premium, it is out of the way even a small 2-car garage. If I still raced or did more work on my car I would get an armed single post.
  11. DeTomasoGTS74
    DeTomasoGTS74 Formula Junior
    Dec 13, 2016
    391
    Austin
    Eric
    When somebody asks me about a lift, my first question is always what are you going to use it for. Given you are using it solely for storage, a single post is by far your best option. I have both a four post and a single post, and the four post was significantly more intrusive to the spaces next to it. In my new house I put it in the single bay with a sliding jack so that I can use for both storage and work.
    While the single post is by far the best option for storage, it is very limited when it comes to any work that you can do in the car.
    NoGoSlow, rob lay and Mario Andretti like this.
  12. Mario Andretti
    1,776
    Boston
    I can only do a single post ; and only if I do a roll up door , no space if the door is typical space invading inside garage door... you know what I mean.
    I am installing this into a 12x20 garage... only option I had on my property; short of selling and buying a (+.5 mil) house in Newton. I'd rather have upgraded to at 488 instead :)
  13. tmvatlanta
    tmvatlanta Formula Junior
    Mar 26, 2017
    389
    Covington GA
    Tam V.
  14. tstuli
    tstuli Formula Junior
    Jun 12, 2018
    379
    NC
    There’s plenty of brands. The hobby/home level stuff all seem to be the same/similar design and likely are all coming from the same overseas factory. Personally I’d make sure whatever I buy had ALI certification.
    The problem with not bolting it down is I found they tend to “walk” over time. You can bolt and still unbolt when you really want to move it around.
    I’m not sure why folks are saying you’ll never use the car on top. Literally takes a few minutes to move things around when needed.
    Tdfdonuts and Mario Andretti like this.
  15. plastique999
    plastique999 F1 Veteran
    Nov 9, 2008
    8,841
    SoCal
    Edward
    Rob which model is this?
    I’m researching single posts … seems the install is quite hefty.
  16. plastique999
    Nov 9, 2008
    8,841
    SoCal
    Edward
    Same question, which single post lift do you have?
    How was install?
  17. rob lay
    Dec 1, 2000
    63,970
    Southlake, TX
    Rob Lay
    https://aclifts.com
    I had mine installed 2019 and they were even a sponsor for awhile.
    They x-rayed the floor and all bolted in. I had some custom stuff done, they took 4" off the top and the diamond plating.
    It was about $8k plus $2k then, I've heard a rumor they are much higher now. Very high quality, I'm 100% satisfied.
    plastique999 likes this.
  18. Horsin'around
    Horsin'around Formula Junior
    Jun 14, 2017
    255
    Unfortunately, they are insanely expensive now.
    About 20-24k all in.
    They claim their steel costs drove up the prices.
  19. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    I thought about ordering a second one and at the time they couldn't even quote me. Wow $24k
    I ordered mine 2020 during black Friday and was about $10k all-in installed March 2021
  20. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,919
    Central NJ
    Dominick
    #20 flash32, Jul 8, 2022
    That is why I recommended a 4 post lift to original poster ...he mentioned keeping cost low
  21. plastique999
    Nov 9, 2008
    8,841
    SoCal
    Edward
    Thanks Rob!
    I just called ACL and got some numbers: $15k for the single post and $17k for the higher capacity (taller and 6500 lbs). I’ll get a metal drip pan and the Wider lift option (for Lambos and such).
    Install will be about $1-2k (will be quoted) and I need to get a 220V installed.
    Lead time is about 10 weeks.
    Super excited!
    rob lay and Sj_engr like this.
  22. rob lay
    Dec 1, 2000
    63,970
    Southlake, TX
    Rob Lay
    congrats!
  23. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    I put a 240V ev plug on the wall and used an extension cord to power the lift. I just roll up the cord when not moving the lift.
    I highly recommend a Hubbell 14-50R socket and not a cheap dryer version.
    plastique999 and rob lay like this.
  24. mominayal
    mominayal Karting
    Feb 2, 2017
    119
    Indiana
    Very happy with my 4 post atlas. May get a second.
    tonyswfla and one4torque like this.
  25. one4torque
    one4torque F1 Veteran
    5,720
    Houston
    One4torque
    Good to hear pos feedback on atlas 4post. I’m getting the ext tall unit next month.
    Will for storage and service.
