Car wont start when reversing crank sensor plugs | FerrariChat
Discussion in '308/328' started by climb, Oct 7, 2009.
  1. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    In trying to find the cause of my midrange misfire and header glow i tried reversing the plugs on the crank sensors today. That is i sent the front bank sensor to the rear digiplex and vice versa ( at least i think) by reversing the plug harnesses and the car wouldn't start but for a second or two then died.
    Should the car start with the plugs reversed like this? If it should start does the non start give me any useful info for fixing my problem?
  2. Steve Magnusson
    26,854
    No
  3. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    So to change banks i need to switch the big plugs on the digiplex boxes?
  4. Steve Magnusson
    26,854
    Yes -- that works OK because when you switch the big (25-pin) plugs at the ignition ECUs you are switching the flywheel sensors and the coils/power modules at the same time.
  5. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
