Carb balance question | FerrariChat
Discussion in '308/328' started by Kidasters, Jul 19, 2015.
  1. Kidasters
    Kidasters Formula Junior
    Oct 4, 2013
    546
    Houston, Tx
    Ken
    Hey Guys -
    For the past few weeks, I've been struggling with "popping" at low idle after the car gets warm. I've done a lot of searching, and a few things, but I'm now convinced it's a fuel delivery issue.
    I changed both caps, rotors, wires and extenders. No change.
    I tried increasing the mixture on each carb, that just made the problem worse. Total increase was about 1-1/4 turns on each of the mixture screws (which is a lot). Front right "inside" mixture screw is a bear to get to. 10" really thin screwdriver made it though.
    After that - I removed the engine cover. With the car idling, I put a SK synchrometer on each air horn. Both front bank carbs read about 7 to 8 kg/h, and the right rear carb as well. But the left rear carb only read 5 to 6.
    Here's my question: Is this a vac leak? Or could it be as simple as increasing the idle speed of that carb? Thoughts please.
    Thanks,
    Ken
  2. jessup
    jessup Formula Junior
    Apr 26, 2014
    403
    Santa Clara CA USA
    Jessup
    IMO if there is no obvious sign of leak I would increase idle of that carb.
  3. Fairview
    Fairview Formula 3
    Mar 16, 2009
    1,109
    Waynesboro, Virginia
    Jeff Ward
    Ken, the most effective method I found to tune my Webers by ear is to turn one idle screw in until that cylinder quits firing. Then back out that idle screw until it starts firing again, and continue back out almost a full turn. Repeat for each cylinder. If there is no noticeable change in idling as you turn an idle screw all way in, you may have found a dead cylinder, hopefully just a fouled plug. Also you may want to read up on leaky throttle shaft bearings.
    Good luck with it, Jeff
  4. Kidasters
    Oct 4, 2013
    546
    Houston, Tx
    Ken
    Thanks Jeff. I did. I have some of the sealed bearings from Pierce Manifolds out in the garage right now. I hope it doesn't come to that.
    Thanks. Keep the comments coming guys.
    Ken
  5. Steve Magnusson
    26,779
    All of those airflow values are much too high for a 1000 RPM warm idle (and indicates that some cylinders are not actually contributing at idle). All cylinders should be in the 3.25~4 Kg/h range depending on the ignition timing that you are using -- more advance (like 7 deg BTDC R1 only) = less airflow needed; less advance (like 3 deg ATDC stock '78 US R1+R2 = more airflow needed).
  6. Kidasters
    Oct 4, 2013
    546
    Houston, Tx
    Ken
    #6 Kidasters, Jul 19, 2015
    OK Steve. I'm not sure on the timing. Yes - this is a 78 GTS.
    So, what's your advice to remedy the situation? Check timing and start over with tuning the carbs? I also have some new plugs sitting around. I was thinking that - while I'm at it, I could also pull and replace plugs.
  7. Rifledriver
    37,089
    My advice on carb tuning is to be sure everything else is perfect.
    Carbs are adjusted last for good reason. Most carb problems are not carb problems at all.
  8. Kidasters
    Oct 4, 2013
    546
    Houston, Tx
    Ken
    A good friend of mine says that carburetor is italian for "touch once, never again".
    I'm going to replace all of the vac lines before I mess with the carb. Just to eliminate them as an issue. Plus - they look like crap.
  9. Rifledriver
    37,089
    I go through this several times a year, explaining to a client about running problems. If I do a complete, thorough tune up and drive the car until running degrades and it needs attention it will not be the carbs, yet they are the one part people fuss with most when there is a problem. To a great degree your friend is correct.
  10. Steve Magnusson
    26,779
    As Brian said, you need to make sure that the ignition system is healthy and (even if the carb airflow balance at idle isn't yet correct) confirm that the ignition timing is reasonable at 1000 RPM warm idle for whichever ignition set-up that you have (stock R1/R2, R1 only, aftermarket R1 only equivalent). Then you can use Jeff's suggestion to use the mixture screw on each barrel to confirm/deny that you can close it completely to cause the cylinder to miss, then open the mixture screw slowly until the cylinder starts to function, then open it another fixed amount (although I'd try something closer to +3/8 to +1/2 of a turn as the extra fixed rotation addition). Another method to confirm/deny if a cylinder is contributing at idle is to temporarily unplug the spark plug wire to see if the engine RPM/sound changes (and it should if the cylinder was working) -- but you need to be very careful doing this to avoid getting shocked.
    However, since your air flows are already well above where they should be (and unequal), if/when each cylinder is contributing at idle = your idle RPM will be much too high. Birdman has written a good tutorial on how to make the various throttle plate and air bypass screw adjustments -- it's here somewhere...
  11. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    You may want to read the Birdman guide on tuning the 308 webers. I think it covered all you would need to know and how to do it. I did mine after the 1st year I owned it right after I replaced the points and plugs. I would also suggest you go to a hotter plug to prevent fouling during the process. I sold the car 13 years later and never touched the carbs again.
  12. Kidasters
    Oct 4, 2013
    546
    Houston, Tx
    Ken
  13. rkljr
    rkljr Formula Junior
    May 16, 2011
    723
    South of Boston, MA
    Richard
    I am not sure of the exact sound (through the carb/intake or from the exhaust). You may have a small leak on the header, perhaps where the sniffer tubes enter or around one of the plugs if the sniffers have been removed. Sometimes you can see it by running the car in the dark. Just another thought for the mix.
  14. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    You may want to consider re-jetting as well.
    I have just recently re-jetted my 246 by changing the idle jets one size larger and dropping two sizes on the air corrector jets.
    Rolling road tests before and after showed positive results.
    Snapping and popping out of the carb is an indication of lean condition, make sure all the idle jets are clear
  15. rkljr
    May 16, 2011
    723
    South of Boston, MA
    Richard
    +1 on rejetting. There are threads on the correct jets, air correctors and emulsion tubes. The US cars were intentionally tuned to run lean to meet emissions.
  16. Kidasters
    Oct 4, 2013
    546
    Houston, Tx
    Ken
    Update. After a lot of dead time - I replace all of the vac and fuel lines on top of the engine. And - while the problem is better, it's still doing it. It only does it when the car is really warm.
    I don't think this is a fuel delivery issue.
    I'm going to start over. My car buddy has been harping on me that timing might be off. I'm going to bite the bullet and dive into that next. While I'm at it, I think I'll go ahead and convert the car to Pertronix. I thought about Nick Forza's kit, but the Pertronix kit is 1/8 the price, and I can retain the stock dual dizzy look. I'm going to look for a single dizzy to convert, so I don't have to gut one of my originals.
    Very frustrating to have the car run this bad this long.
    Finally - to add insult to injury - I said "well, at least I can change the plugs while I've got it out.". And, the new spark plug tool I bought doesn't fit in the holes. So, after a search, I've ordered a snap on socket. I hope it fits.
    Dang.
  17. bill308
    bill308 Formula 3
    1,224
    Windsor, CT
    Bill Sebestyen
    Hi Dang.
    I think you're going in the right direction now. let me see if I can help.
    Confirm timing at idle and 5k. Ensure advance is smooth over its range.
    Balance using the throttle cable method (off the throttle stops). Set the balance speed in the 1200-1500 rpm range, where it's most important for driveability.
    Ease the throttle cable (still of the idle stops-back off if necessary) to give the desired idle rpm, say 1000 rpm. Check and fine tune balance again. When acceptable, nip up the throttle stops to just maintain the linkage geometry.
    How are you setting mixture?
    Bill
  18. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
    Assuming you get rid of all vac air leaks, any timing issues etc and intermittent plug firing and assuming all compressions are good and that all the carb bowls are full to the correct level.
    Them you may want to think about debris in the idle jets ie take the screw out counting the number of turns, blow it out and replace the adjustment screw. Repeat on all 8.
    Ideally you'd want to clean all the carbs through but you might get lucky.
    A piece of debris the size of a grain of salt will cause the issue you describe.
    Does the issue stop when you raise the RPM, if it does and assuming you've done all your other checks then idle jet screw is a strong contender.
    Regards Bell
  19. Bell Bloke
    Dec 6, 2012
    1,839
    #19 Bell Bloke, Sep 17, 2015
    Diagnosis on the Internet is a very slippery slope but if carbs do give problems here's a quick goto.
    Please bear in mind that I'm writing this on a film set between takes and it's off the top of my head.
    Carb issues.
    First find the carb that's giving issues or just check them all systematically
    1. Popping and spitting on idle= poor adjustment of jet screw or blockage or partial blockage
    2. Popping and spitting or loss of power in the mid range = blockage or partial blockage of the mid range jets.
    3. Popping and spitting or loss of power in the high range=blockage or partial blockage of the main (large) jets.
    4. Hesitatation or audible popping at low RPM when throttle is suddenly pressed for acceleration = accelerator pump bladders split or accelerator jets blocked.
    Note all accelerator pumps are easy to check by removing the airbox
    cover and looking down each choke. As the accelerator is depressed slowly and fully with the fuel pumps on you should be able to see a clear uninterrupted 1mm jet of fuel go straight down the choke.
    If the stream is interrupted or broken ie spluttering then your carb accelerator pumps will need servicing.
    Please note that you should only depress the throttle no more than 6 times with the engine off before a start is required to clear the unburnt fuel, as this test is done with the engine off.
    5. Carb bowls overfilling can be checked quickly by looking down each choke with the engine off and pumps on.
    Any fuel entering the chokes in this condition indicates a problem with the float or carb float fuel stop valve.
    6. Carb bowls underfilling is harder to check since it involves removal of the top of each of the carbs and then visually check the fuel level.
    However with some carbs you can see the fuel level around the immulsion tubes or main jets.
    Ok like I say this is a very rough down and dirty quick guide, I hope I haven't left anything out.
    It's a big subject but this basic approach with get you started.
    Just remember a Ferrari engine is just a single carbed lawn mower X8!!
    The trick is to get all the carbs feeding all of the cylinders at the same rate and with the right combustion ie not too rich or worse not too lean.
    7. Carb adjustment screws are only responsible for engine mixture at IDLE, they do nothing to the mixture once the throttle is operated.
    Throttle open mixtures are controlled by the main jets and mixtures can only be changed by physically changing out the jets.
    So twiddling your idle mixture screw does just that, it only adjusts the Co at idle for better low speed running and emissions.
    Hope this helps, all the best Bell
    dflett likes this.
  20. BigTex
    79,368
    Houston, Texas
    Bubba
    #20 BigTex, Sep 18, 2015
  21. BigTex
    79,368
    Houston, Texas
    Bubba
    Recall that is for "1977 fuel" however....any thoughts, Bell Bloke (or others) on a change to reconcile to modern blends, with ethanol??
  22. bill308
    bill308 Formula 3
    1,224
    Windsor, CT
    Bill Sebestyen
    Hi BigTex.
    Some data points I came across.
    A/F Mixture gasoline E10 (10% ethanol)
    Stoichiometric 14.7 14.1
    Safe full power 12.5 12.0
    You need about 4% more E10 for equivalent performance.
    If the engine was tuned lean for gasoline, one could make a case for a larger jet size.
    Example idle jet, 0.55 increased to 0.57, yields a 7.4% increase in flow area. Probably not a bad approximation for expected mixture results.
    Bill
  23. Bell Bloke
    Dec 6, 2012
    1,839
    You know I run a simple test to see how my cars are running and it works like a dream.
    In the absence of a rolling road I just take the car in question on a run down a 10 mile flat piece of road.
    1. For the mid range jet test.
    First I drive at a constant 40 mph light throttle, at the end of the road there is a pull in. I then pull straight in engine off and pull all the plugs, be careful as they obviously will be hot. Look at them all, photograph them with your phone and note their colour and position. If they look rich or lean then this is the jet you change.
    2. For the large main jet test.
    I do a higher speed run the other way at say 70-80mph. Then pull straight in again and repeat the process.
    Next I do high speed run with lots of hard acceleration, I then pull in again, remove the plugs and note the colour.
    Again, if they look rich or lean then these are the jets you change.
    These tests will show you how the engine is running in a real world scenario under load better than any colour tune system or similar.
    Looking at plug colour is the best way to see how your engine is running and you can make tuning adjustmensts based on that.
    Don't forget though this is done only by swapping out the main jets. The idle screw adjustment only adjusts the mixture at adle, for some reason many folks mistake this as an overall mixture adjustment.
    My 1981 Aston Martin V8 Vantage was a little bit of a dissapointment when I first bought it, it seemed to feel a bit flat all the way through the rev range.
    On checking the plugs I found that the engine was running lean, Bloody hell!!
    Why?
    Because some penny pinching ape had swapped out all the jets for smaller ones in an effort to save fuel! Unbelievable.
    Anyway fortunately being a 'production' engine I got all the correct jets from Aston Martin (yes they were bigger) and the car took off like a scolded cat! Plug colour was restored along with the performance, as for fuel economy? err best not talk about that, but it was par for that car shall we say.
    Regards Bell.
  24. Bell Bloke
    Dec 6, 2012
    1,839
    Excellent post Nuvolari!!
