Carb Flow Meter | FerrariChat
Carb Flow Meter
Discussion in '308/328' started by Sledge4.2, Aug 25, 2014.
  1. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,784
    Marin
    Geno
    I have been using the STE SK flow meter for balancing my carbs like most of us.
    The Jalpa uses 42 DCNF's and that little SK craps out at anything off-idle, making the flow measurement nearly impossible. I bought a four-column manometer and was measuring vacuum below the throttle plates, but that is a chore, the unit is finicky and not good for "pull over and make adjustments" tuning.
    At Concorso another Lambo owner showed me his Uni-Syn carb sync tool, which is adjustable for different flow rates.
    I bought one, its on its way, just curious if anyone has an experience with them? On the surface seems like a better tool than the STE SK and cost effective too.
    Edelbrock Part No. 4025 - Balancing Instrument Kits
  2. Fairview
    Fairview Formula 3
    Mar 16, 2009
    1,109
    Waynesboro, Virginia
    Jeff Ward
    Geno,
    I used one for all the SU and Stromberg carbs on the British cars. Always easy to use and to read. You just spin that inner piece to open and close the orifice to adjust for the volume of air. I hadn't thought about using one on the Webers, though. Hopefully you can get a good seal.
    Jeff
  3. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,784
    Marin
    Geno
    Thanks Jeff, that was my concern. I think I will need to pull off the trumpets.
  4. jessup
    jessup Formula Junior
    Apr 26, 2014
    403
    Santa Clara CA USA
    Jessup
    #4 jessup, Aug 25, 2014
  5. Rifledriver
    36,769
    #5 Rifledriver, Aug 25, 2014
    The unisyn takes away most of the air and really becomes a vacuum gauge effectively killing the cylinder being measured. It also needs a flat surface to seal against. Most of us thought they really outlived their usefulness in the 60's. The STE on the other hand measures air flow and does not disrupt running. It can be left in place as long as you like. I have even seen shops that have 12 and just put them on and leave them while the entire carb tune is done. No way that can be done with a Unisyn.
    I have had an STE SK since the 70's and in all that time I have almost never seen a Ferrari mechanic use anything else except in a rare case when we went to the trouble of hooking up the 12 column manometer.
    What kind of trouble are you having with the STE SK? I haven't used it on a Lambo but I have tuned a lot of Ferrari's with it. Come to think of it, it has been used on several Lambos. I have never felt the need for one with greater air flow but for big displacement motors they make the STE BK.
    If you really need something different I have a 12 column mercury manometer I never use and would sell.
  6. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,784
    Marin
    Geno
    Thanks Brian.
    on the Jalpa its fine at idle, measuring around 3.5-4 kg, but when i get off idle, it almost pegs up in the upper ranges, where its difficult to discern how much air is flowing. I am doing my best, I but its hard to get a good reading due to the diminishing increments as the flow reaches the upper levels of the gage.
    If you try and sync it at 3k rpms forget about it, its pegged out. The only way you can do it is to sync with the plates tipped just a little forward (less than 2k rpm), and even then its hard to get a good reading.
  7. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,784
    Marin
    Geno
    i am curious about the manometers. I bought one (non mercury, some wheat-grass eco crap in the columns), and it gives very uneven readings bouncing all over the place. I would suspect the mercury unit doesn't being a heavier fluid. But i have no experience. I would love the give the mercury unit a shot.
  8. Rifledriver
    36,769
    I have used them a lot. Any fluid, including mercury bounces a lot and you get a headache watching 8 or 12 columns bouncing like that. Also I doubt you could rev it to 3000 without sucking the mercury into the motor. Seen that done a bunch. A million little tiny mercury balls get spit out the exhaust.
    When I am tuning one all I really do is set up the idle resting on the stop screws and raise the rpm via cable adjuster enough to get 8 or 9 kg on the scale to be sure the carbs flow the same on the linkage rather than just the stops.
    Your situation doesn't sound any different that what we faced doing 308's or Daytonas.
  9. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,784
    Marin
    Geno
    The maxes out far more on the Jalpa, but I understand your point. 9 kg happens right off idle
  10. hoverland
    hoverland Formula Junior
    Aug 14, 2010
    265
    Norway
    Harald Ø
  11. Nielsk
    Nielsk Karting
    Dec 8, 2012
    179
    Central Florida
    That looks promising Hoverland, is this your baby?
    Is it available yet?
    A "special" package w/ the exhaust gas analyzer tool for us guys would be sweet!
    If they could be run at the same time tuning would get a whole lot quicker...
  12. Steve Magnusson
    26,542
    For 3.5L displacement, that doesn't seem right (like your real problem is that you have some cylinders that aren't contributing useful work at idle). Can you be more specific about what conditions you do have at warm idle:
    displacement = 3.5L?
    warm idle RPM = ?
    warm idle ignition timing = ?
    average airflow per barrel at warm idle as measured by SK (in Kg/hr) = ?
  13. Rifledriver
    36,769
    Looks very nice but your website says nothing about cost.
    How much is it?
  14. tuttebenne
    tuttebenne F1 Rookie
    Mar 26, 2003
    3,208
    Bay Shore, NY
    Andy
    As DIY I used that Uni-Syn tool on all my carb cars including the 308. I took a piece of large rubber hose and cut off a 2 inch piece of it. I used it between the carb throat and the tool to eliminate the sealing issue. Set my carbs up 27 years ago with that tool and haven't seen the need to do it again.
  15. Rich S
    Rich S Formula Junior
    Nov 30, 2013
    501
    Monterey, California
    Rich Saylor
    The Uni-Syn works fine, but you need the right size- they're not all the same. I have several, including one shaped like a racetrack. The surface that fits to the intake is thick sponge rubber, which if in good shape seals nicely. The real work is to make sure the carbs are correctly set up, meaning floats properly adjusted, butterflies correctly adjusted so all are completely closed at zero throttle, also no air leaks, especially at the ends of the throttle shafts. Of course all the bits (Webers) have to be the same- emulsion tubes, air & fuel jets, pump jet and so on. If someone's messed with these you're in trouble. All the Uni-Syn can do is tell you that the amount of air being drawn into each cylinder is the same- or not. If it's the same- that is, the ball floats at the same spot around the middle of the tube- you can then balance everything.
    I used to set up my Lotus twincams all the time this way, ditto the triple SU's on my E-Types, no real problem other than the lengthy process involved, especially on SU's. But it works.
    Overall a PIA which is why I love FI; the same goes for electronic ignition. I hate setting points.
    Good luck, and remember when tuning a car- "omit no tests".
    Cheers,
    Rich
  16. Rifledriver
    36,769
    That is a lot of air flow. Are you sure the timing is not very retarded or something like that?
  17. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,756
    Atlanta
    John!
    For what it's worth, I use at least two of these things to tune engines, one always on the other bank. This has made it tons easier to see what the other is doing at part throttle to 1500rpm. A person is only ever going to get 90-95% there with these carbs anyway so there no sense beating yourself over the head once you get it close, not that you're doing that by the sound of things.
  18. Jdubbya
    Jdubbya The $10 Trillion Man
    42,322
    PNW
    I saw this... "Salesprice will be NOK 5.500,- (approx EUR700,- GBP600,- USD900,-) ex VAT and ex freight. Boxed content is "Manifold Pressure Tool", software/drivers, Shielded USB cable, sensor hoses, see picture."
    Sure would make things simpler wouldn't it!!
  19. Rifledriver
    36,769
    Less money than the mercury alone for a manometer and much easier to use.
  20. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,784
    Marin
    Geno
    Thanks for all the comments guys. When i get back into the country I will post a video showing the flow rate at idle and off-idle, and will also have the Uni-Syn tool by then and will report those results.
    The timing is set the factory marks, warm idle around 900rpm, and flow characteristics are the same (as close as I can get them) between all barrels (i.e. one isnt flowing much higher than the others). The distributor has a vacuum retard at idle drawing vacuum from below the throttle plates.
  21. tomberlin
    tomberlin Formula Junior
    849
    Bethesda
    tom berlin
    When Honda 750's first came out the Honda manometer was a set of 4 vacuum gauges with
    a little petcock in each hose to dampen the vacuum pulses. The manometer I have has little
    restrictors that look like plastic carb jets. It is a mercury unit but there is no appreciable bouncing. Years ago, not wanting to spend the money on a Honda gauge set, I bought 4 vacuum gauges and 4 radiator petcocks, mounted them on an ali plate, and it worked fine.
    I could close the petcocks just enough to dampen the pulses being careful not to close off the line.
    Tom
  22. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    There was a fellow fchatter that put together a digital carb synchronizer. It was very well done and worked with a laptop. I think he planned on marketing it. When I get a chance I will look it up and post a link to the thread. Good for 2-12 cylinders and neat bar graph display.
  23. BigTex
    79,321
    Houston, Texas
    Bubba
    I don't think the EPA liked THAT!
    :D :D :D
    Dad found me playing with mercury pirated from school, and packed it in sulfur to throw away...I think that's how he did it...
  24. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    #24 Crowndog, Aug 26, 2014
    Search:
    Carburetor synchronizing "tool"
    Very cool project under 365/400 section
  25. Rifledriver
    36,769
    #25 Rifledriver, Aug 26, 2014
    Look at post 10.
    Looks pretty cool.
