Carb Mondial update - a bit technical. | Page 3 | FerrariChat
Discussion in 'Mondial' started by snj5, Apr 1, 2008.
  1. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #51 snj5, May 16, 2008
    Finished the exhaust - plan to start on Saturday or Monday.
    If it sounds good, I really like the way the exhaust turned out with the wider tips; will know soon enough.
    Here are the photos with the pieces tacked - Final welding happening now. It's all stainless, and except for the tips will be ceramic coated to match the headers if the sound is good.
  2. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Now THAT'S a badass look!
    Nice job Russ.
  3. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Thanks - all kudos on welding to James at Norwoods.
    I sure hope it sounds good and not too loud at cruise. It's amazing what a subtle difference the wider exhaust makes. I think we will change a little though and do the mufflers in a flat black with chrome tips.
    It is soooo tempting to run with the open tall carb air horns just for the sound.
    Quick rundown:
    3.2 quattrovalvole
    10.5:1 pistons (JE)
    heads flowed, matched, ported with larger intakes;flow up across the board with peak up 12% with increased velocity
    0.360 lift intake cam (stock durations)
    Weber 44 DCNF (38mm venturis, 145,F24,170,52)
    Tubistyle Euro headers, dual resonant exhaust
    MSD 6AL Unilite, 34 degrees @3200rpm
    Nothing radical really at all - just simple, moderate & reliable.
    Thanks to Mark and everyone.
  4. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Hi Russ,
    Inspiring work, truely gorgeous. I will have to get a sound card for my Dell, so i can hear this car run. No one is saying it, but, i know a lot of guys are massively envious of what you are doing.
    best,
    chris
  5. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Thanks. I hope it sounds good - it will certainly be obvious on the 4 hour drive back to San Antonio. I think what I am doing is actually just a simple basic tuning which has been fun to learn as we go. It is a bit ironic as the whole retrofit thing with the Webers and MSD was almost entirely geared toward increasing reliability and DIY maintenence through simplicity, which was a main guiding parameter. For instance, we could have gone to more radical cams if we had gone shim under, but that would require increased effort to maintain.
    There are also a few little things I've been gleaning from FChat that we also did for reliability - examples being silicon water hoses replacing the long rubber ones to the front radiator, Pierburg fuel pump, uprated alternator to 100+ amps and the geared starter.
    It is probably the world's most expensive Mondial, but to me it is the epitome of understated class in a small Ferrari GT.
  6. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #56 snj5, May 19, 2008
    Here's the exhaust before we send it to the ceramic coat place to be finished. I think it's going to be a bit louder than I had hoped, but hopefully what all the books said about two mufflers of equal volume silence better than one muffler of total equivalent volume will be true (resonant silencing). This is also the first muffler arrangement I've tried with counter-flowing paths, although they do not communicate at all as it is a true dual system to take advantage in theory of the flat crank exhaust pulsing.
    I just hope it doesn't sound like a ricer.
    They will probably start it Monday, or when I go up on Tuesday. Will try to get some pics and video if possible.
    Very exciting and a bit nerve wracking hoping for the best after so much time and effort.
    Here's hoping for the best!
  7. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    It runs.
    Started up and idled at 900 rpm smoothly before anything was done to the carbs. Good oil pressure, runs cool. I will hear it tomorrow, but they say it is much much quieter at idle than they expected, even with the staight through. They said it doesn't really sound like most Ferrari V-8s, but has more of a lower glass-pack rumble. The cams are being broken in today. It will not be ready to drive, but can tinker a bit. Last things to do - new tach and linkage set-up.
    Will try to figure out a sound file for tomorrow,
    thanks!
  8. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Wow Russ...
    I haven't been around here for a while (fire academy), but now I've got some catching up to do.
    Looks terrific, and as I've always said, I've got first dibs on your engine.
  9. Nurburgringer
    Nurburgringer F1 World Champ
    Jan 3, 2009
    11,161
    Texass
    somehow found this neat old thread searching for heater "core bypass", and would just be curious on how everything turned out, the exhaust in particular.
    Everything work out to your satisfaction Snj5? Any sound clips?
    cheers
    Kurt
  10. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #60 snj5, Aug 10, 2010
