Carb Question | FerrariChat
Carb Question
Discussion in 'Technical Q&A' started by jimshadow, Apr 13, 2009.
  1. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,255
    Indiana/North Carolina
    JIM
    I had my carbs rebuilt last year right before I drove the GT4 to Mississippi. It was essentially put up for the winter after that and was only driven once or twice for very short distances until last week when I took a 3hr drive in it. I noticed a slightly stronger gas/oil smell than normal (my wife and kids say my car 'stinks. :) )
    Well, as I looked at the manifold/carb bases, I noticed that atleast 2 are leaking. :( I called the shop that did it and they said , "No problem, bring it right back in and we'll make sure its right." The mechanic mentioned that the "Float levels may be set too high".
    My question is: Would this cause a carb to leak? Though I can do most everything mechanically on my car, I can't do the carbs, nor do I want to at this time. I will someday, but there is enough other projects to keep me busy.
    I'm curious about this. Could someone please explain. (Yes, the entire carbs were rebuilt including the base gaskets, which is where I *think* they are leaking from though I can't get a good look in there without taking stuff apart. )
    JIM
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #2 2NA, Apr 13, 2009
    If floats are set too high the engine will typically flood easily and run too rich. It is possible for them to overflow but usually most of the gas goes inside the motor not outside. There are a few places a fuel leak can come from but the base gasket isn't usually one of them. There you will sometimes see a vacuum leak but not liquid fuel.
    I would check the needle valves. They can catch a piece of dirt or get sticky during storage causing a carb to flood.
    You are describing one of the most common Springtime problems for cars that are stored during Winter.
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,654
    San Carlos, CA
    Mitchell Le
    Jim
    Second on the Needle Valves. Next thing you notice is your exhaust glows red in the night, then your car really stinks when it burns to the ground.
  4. jimshadow
    Feb 19, 2006
    6,255
    JIM
    Thanks for the replies! I got it into the shop quickly so it doesn't burn to the ground! :)
    The car is "stored" right in my garage and gets started occasionally and moved around when its dry out, however, this year is sat for a very long time as we had tons of snow/wet weather. Last week was the first time that I really drove it.
    We'll see what they say. I left the car there today and will pick it up on Thurs. :)
    JIM
  5. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,286
    Black Forest Germany
    Martin N.
    #5 Martin308GTB, Apr 14, 2009
    Hello from Germany,
    when they have ultrasonic cleaned the carbs during the recent rebuild and didn't restake the lead plugs after that, you might have loose lead plugs.
    There are some just above the base gasket which can lead to the mistake, that the fuel comes out of the base. This happens all the time.
    Mine were leaking too - without ultrasonic cleaning - and I restaked all lead plugs after my rebuild....... dry carbs.
    Best Regards
    Martin
  6. tomoshea
    tomoshea Formula Junior
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    Jim
    Had the same problem on one of my carbs, thought it was a leak thorugh the base gaskets, turned out the lower lead bead in the photo above started to weep, common enough apparently, and occurred after a full rebuild and clean of the carbs.
    Mine was fixed with a small drop of epoxy over the lead plug (didn't want the hastle of another engine strip). No leak since the epoxy and a much reduced petrol smell. Fuel efficicency has improved also :)
  7. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,526
    Raleigh
    Kevin
    Okay I will put my ignorance out there. I have rebuilt the carb on my Harley but have not touched the 308. What is the lead plug?
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    During manufacture there are passages that are cross-drilled to effectively allow flow around corners. It is necessary to block some of the openings and frequently lead plugs are inserted and "peened" in place (sort of like a filling in a tooth). Occasionally they become loose and begin to leak.
  9. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    The first thing that comes to mind is the possiblility of a fuel hose leak, either through a cracked hose or insufficiently tightened clamps. Either the accelerator pump body, the cold enrichment device, or the carb top could also be loose/have a bad gasket. Excessive fuel pressure could also be causing a bit of a weep.
    Untill you are absolutely sure it has been fixed, if you must drive it, have a big Halon extinguisher at yoru side.
    a few years ago, I also had some soft, wet, spongy original hoses that had fuel coming through the fabric.
    Good luck,
    chris
  10. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    +1
    It also may be as simple as a hose or hose clamp weeping. I'm sure you've taken off the air box - what I do is start it and just watch it run, feeling the hose connections, gaskets, etc. Also ensure that your enrichment device levers are all full off.
    A common cause of leaking is a stuck float and/or needle valve. If it is not uber-simple like a hose or gasket weeping, this would be my bet.
    Good luck
