Carb question | FerrariChat
Carb question
Discussion in '308/328' started by david bentley, May 8, 2020.
  1. david bentley
    david bentley Karting
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    On my 79 308, when cruising and I step on the gas hard, it stumbles...if I accelerate slowly....all is fine.
    How can I tell if the accelerator circuit is to rich or to lean?
  2. ragtop1
    ragtop1 F1 Veteran
    5,242
    Ontario
    Larry Warren
    I always start with simple tasks. What octane gas are you using and have you changed the fuel filter ?
  3. david bentley
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    Premium...did not notice the octane
    Changed the fuel filter a few years age....so probably 5000 miles or less ago
  4. Steve Magnusson
    26,839
    First diagnostic step is to just visually confirm/deny that each accelerator pump jet is squirting when you quickly open the throttle and that the volume of fuel squirted by each seems about equal.
    2NA and lm2504me like this.
  5. david bentley
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    All squirters are working...I suspect they were size for 100% gasoline...not part alcohol
  6. Steve Magnusson
    26,839
    Unfortunately, that's the only thing in the 308 carb design that comes into operation "when cruising and I step on the gas hard". About the only other simple thing to check is that the distributor advance mechanisms are working reasonably (i.e., at a reasonable cruising RPM, the amount of advance is in the right ballpark).
    BigTex likes this.
  7. BigTex
    79,386
    Houston, Texas
    Bubba
    Yiu are on the track but this will take effort.
    IF your car retains the matching, correct jets and tubes and foat level to original specs, that would be a blessing because it means no one has f&*^&^ed it up.
    Now, there IS a corrective set of jets, emulsion tubes, all that jazz, to run 10% ethanol gas, and it's out there somewhere.
    This is no for the faint hearted obviously.
    I watch that guy in the UK complain about "a whistle" at full throttle and I think "be damn gald you are not hearing an explosion at full throttle!
  8. BigTex
    79,386
    Houston, Texas
    Bubba
    Steve points out a great point on these cars:
    "Nine out of ten carb problems are ignition…." LOL
    Go up two heat ranges on your plugs and report back...
    JuLiTrO likes this.
  9. Streetsurfer
    Streetsurfer Formula Junior
    Dec 16, 2015
    934
    near Chicago
    Ron
    Check for any broken strands in wires to points under the ignition advance plate that could be causing an open or short during spark advancement as the plate rotates.
  10. david bentley
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    Thanks....I will do more looking
  11. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    It could be all manner of reasons but I would say the problem is in the accelerator pump circuit, check the diaphragms have not gone hard and deliver the correct fuel to each barrel, simply looking down each barrel is not enough as you cannot determine the correct volume is being delivered. Each jet must deliver the EXACTLY the same, from memory its about 23cc for the 0.35mm jet
    Rapid opening of the throttle causes a temporary leaning out or enrichment of the mixture due to the sudden change in air volume entering the engine & drop in vacuum, without the correct fuel to go with it your engine is stalling until things can catch up with you :), make sure the small non return valve is working too, any bleed by can cause fuel to be dumped back to the fuel bowl and starve the Acc pump circuit from delivery the right amount.
    Incorrectly set floats or to high fuel pump pressure can cause the same issue
    tony
  12. lm2504me
    lm2504me Formula 3
    1,122
    Nipomo, CA
    Richard
    In order to pass my Smog check in California Jan 2020 for my 1978 308GTS ...
    Rebuilt carbs and replaced the accelerator pump diaphragms.
    Ran a small copper wire through all accelerator jet nozzles. Two were plugged and two needed cleaning.
    Idle Jets from 55 to 65
    Main Jets from 125 to 130.
    Also verified my carb throttle plates were fully opening with accelerator pedal at its stop. They were only opening about 65 degrees, I adjusted to about 85 degrees to minimize strain to throttle cable at full throttle.
    Adjusted idle mixture screws accordingly for the road.
    Runs great, accelerates way better than before and engine temperatures now always run at normal operating temps.
