Carb sync tool for Weber 36 DCS | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by christc, Jul 19, 2020.
  1. christc
    christc Formula Junior
    BANNED Silver Subscribed
    Mar 3, 2013
    470
    Germany
    Hi All,
    I do have SET Synchron testers (see pic) with various adapters but non fit the Weber DCS 36 on the Gte. I in addition have some old Motometer testers (second pic) but would prefer to use the SET. I can not find a suitable adapter for the SET. Before I start to turn adapters on the lathe I would like to now a.) if there is fitting adapter or b.) what you use as tool for synchronising the DCS?
    Thanks a lot
    Christopher
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,416
    romano schwabel
    I only use those from motometer
    or 12 gauges when I have can use adapters in the intake manifolds
  3. TTR
    TTR F1 Veteran
    5,775
    Riverside, CA
    Timo
    I’m not familiar with DCS, but for DCNs I’ve mostly worked on I have STE with couple of different (rubber) adapters, which I had to modify to make them work. Easy and inexpensive solution.
    I also bought several other adapters for STE meter long time ago, but haven’t run across a need for any of them yet.
  4. JimEakin
    JimEakin Formula Junior
    989
    Mountain Living
    Jim
    My Unisyn won’t fit on the carbs on my 330 GTC because of the choke butterflies. So to fine tune the idle I used a small rubber hose from the venturi to my ear.
  5. 1monza
    1monza Formula Junior
    321
    Manhattan Beach, CA
    Norbert Hofer
    Your Sychron tester in the photo looks to have the larger rubber cone adapter. the standard rubber cone adapter works fine on 36DCS Webers.
  6. christc
    Mar 3, 2013
    470
    Germany
    I spoke to SET and they in the past had a special adapter for the 36 DCS. They were so nice to look in their ,vaults‘ and diged out 3 of these old adapters for me. I do now have in addition to my bigger sk 2-40 a set of 3 matched SET Synchro Meters sK 1-30 with additional fitting adapters. Will post photos when I have them. Thanks for all your replies. Always a pleasure communicating here with you all.
    Christopher
  7. TTR
    TTR F1 Veteran
    5,775
    Riverside, CA
    Timo
    STE :rolleyes:
    christc likes this.
  8. christc
    Mar 3, 2013
    470
    Germany
    Timo, absolutly right. They should rename themselves as I seem to always get it wrong... ;-)
    TTR likes this.
  9. turbo-joe
    Apr 6, 2008
    9,416
    romano schwabel
    would be great to post a link to SET
  10. christc
    Mar 3, 2013
    470
    Germany
  11. turbo-joe
    Apr 6, 2008
    9,416
    romano schwabel
    thx, but just under construction
  12. christc
    Mar 3, 2013
    470
    Germany
  13. turbo-joe
    Apr 6, 2008
    9,416
    romano schwabel
    wow great
    thanks so much
    I always make a small hole in the intake manifolds and put in then a 5 mm or 6 mm adapter on all 12 cylinder ( or even less cylinder ) and have then 12 vacuum gauges so I can see all at one sight and not have to switch always from one to the other cylinder. those gauges I have are from boehm ( https://www.boehm-synchrontester.de/ )
  14. 1monza
    321
    Manhattan Beach, CA
    Norbert Hofer
    If you use the standard rubber cone adapter its easy, works fine. Its quick & easy. Why make it complicated?
  15. christc
    Mar 3, 2013
    470
    Germany
    #15 christc, Jul 23, 2020
    The SK 30 has a cone of 39-54mm, the DCS 36 has a intake diameter of 38mm. To get an airtight fit and securely hold the meters an adapter makes a lot of sense, even more as I will have 3 meters working at the same time. Perhaps your meters do have other cones and therefor fit better?
  16. christc
    Mar 3, 2013
    470
    Germany
    ...what series is your Gte? Not all had the 36 DCS...
