Carb Synch tutorial question | FerrariChat
Discussion in 'Technical Q&A' started by Mr Iceman, Apr 18, 2005.
  1. Mr Iceman
    Mr Iceman Karting
    Mar 3, 2004
    101
    Canterbury, England
    Scott
    I have recently been getting quite intimate with my carbs, general inspection and cleaning etc following some of the excellent guide posts on this forum. I am now wanting to check and possibly adjust the synch, I have purchased an airflow meter and have read Birdmans excellent "Carb synch tutorial for 308", However because this was posted before the hard disk meltdown all the pictures have gone.
    I was wondering if anyone had the pics on there hardrive and could repost or email them to me? I am especially interested in pics showing the location of "the air bypass screws" .
    Any help would be appreciated.
    Scotty
  2. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,966
    Melbourne, Australia
    Carl
    Scotty, the pics of the bypass screws are detailed in the workshop manual.
  3. Steve Magnusson
    26,932
    Page C20 Fig 19 -- labeled "D - Screws for depression balancing in the carburettor ducts (by-pass)"
  4. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #4 snj5, Apr 19, 2005
  5. Mr Iceman
    Mr Iceman Karting
    Mar 3, 2004
    101
    Canterbury, England
    Scott
    Thanks very much guys, especially nautique who emailed me the original guide with pics. much appreciated.
    I guess I should have figured that "Screws for depression balancing in the carburettor ducts" was Italian technical English for "Air Bypass Screws" !!
    Thanks again
    Scotty
  6. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I wrote up a more detailed and illustrated version of that tutorial and sent it to Rob. He claims it will be up soon in the new tech section. (STILL waiting Rob! ;)) I'll have to go find those pics and post them again in the thread in the meantime. I didn't realize that they were lost. What a bummer!
    Birdman
  7. F308 MAN
    F308 MAN F1 Rookie
    Jan 19, 2004
    2,907
    Isle of Man
    Dave S
    scott ... i printed birdmans' excellent tutorial prior to the piccy crash .... let me know if you would like a copy in the post, as i have your address.
    cheers, d
  8. Mr Iceman
    Mr Iceman Karting
    Mar 3, 2004
    101
    Canterbury, England
    Scott
    Thanks very much dave, but Nautique emailed me a PDF copy, and Birdman has just reposted the pics on the original thread.
    thanks for the offer though
    Regards
    Scotty
  9. F308 MAN
    F308 MAN F1 Rookie
    Jan 19, 2004
    2,907
    Isle of Man
    Dave S
    no worries, scott .... are you "doing" the valve clearances, as i have spare shims ?
    cheers, d
  10. Mr Iceman
    Mr Iceman Karting
    Mar 3, 2004
    101
    Canterbury, England
    Scott
    Mmmmm, hadn't intended to, How big a job is it? I think I'll leave it be for now, got my hands full with carbs at the moment, thanks for the offer though.
    I'm in the process of checking the float level prior to checking the synch, I was wondering how much tolerance there is in this. the floats are set at the moment from 51mm at best, to 54mm on the worst one, Quite a way off the prescrbed 48mm! what effect would this have on the running? I'm assuming it would mean there was less fuel available in the bowls to supply the jets?
    I'm trying to rectify a flat spot in the power curve that ocurs quite dramatically at about 3000~3500 Rpm. Its always been there , but has become more apparent since I removed the sound absorbing material from the airbox. after I've synched the carbs I plan to experiment with some larger jets (140's) and smaller air correctors (190's).
    I'm hoping to get it finished tomorrow.
    Cheers
    Scotty
  11. Rifledriver
    37,288
    Webers are more sensitive to float height than many carbs. Also remember that the key to multiple carb applications where you have a carb feeding a single or a few cylinders as apposed to an American motor where the carbs all dump into the same manifold, is that consistancy is all important. The specs for float height tolerance is usually 1mm. Also don't be afraid to try different heights within a couple of mm's as a tuning method.
    Also remember that carbs should be the last item on the agenda when tuning or resolving running problems. Compression, cam timing, valve adjusting and ignition all should come first. Those will all effect carburation and carburation will not effect them.
  12. Llenroc
    Llenroc F1 Veteran
    5,559
    Colorado
    Vern
    I am not sure if this has been mentioned before but I have always used two sync gauges seemed to make it easier to balance carbs I didn't have to move the single gauge back and forth between throats and banks.
