Carb Tuning Question | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by blainewest, Nov 15, 2009.
  1. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Blaine,
    I just remembered something...when the motor is cold and I open up the throttle (even a little) I saw fuel squirt out the accel pump jets. When the motor is up to temp, I remember doing the same and fuel trickled out or I could not even see it at all. Have you tried this? What happens in your case? If this still holds true (I haven't checked this out in a while), then when cold the accel pump is working normally and the richness in the mixture is good when motor is cold. When warmed up, fuel is not squirting out (evaporating?) and goes lean, until the main circuit can catch up. What do you think?
    Henry
  2. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Accelerator Pump Back Bleed
    Anyone know what this is? The list that I scanned in list all of these as 0.40 EXCEPT for a US car...it is 0.70. Is this something that can be changed? Is this a pressed in meterd jet? Anyone know what this controls? I can't seem to find it in the exploded view.
  3. blainewest
    blainewest Formula Junior
    Aug 26, 2005
    729
    Kelowna, BC
    Blaine W
    Thanks for the suggestion. Wouldn't this show on your flow meter when measuring airflow at idle? My carbs are now spot on at idle with 8 identical flow meter readings. But I will inspect the linkage to be sure that both linkages are consistantly and freely returning to the stop screws.
  4. blainewest
    Aug 26, 2005
    729
    Kelowna, BC
    Blaine W
    Interesting....I'll check this on the weekend. Airbox is still off so will be easy. Thanks.
  5. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    No. For the best carb synch possible, the idle synchronization process should be done with all interconnecting linkage disconnected. All carb air flows are independently of one another...hence your identical air flow readings.
    This is the key step. If the interconnecting linkage "picks up" one carb, or side before the others, your "off-idle" synch will be off. This will exacerbate any potential stumble issues, regardless of your transition mixture levels.
    Best,
    David
  6. blainewest
    Aug 26, 2005
    729
    Kelowna, BC
    Blaine W
    Ok just an update. I went to 210s ACs and I still had the bog off idle. I've since gone back to a richer idle mix (result was improved) and then today I installed 200 ACs and the bog is almost gone...the best yet. So for now I put the airbox back on. I'm pretty happy now with the way it's running. The other factor here may be the air temperature. It's about 50 f here and so I may have to re-assess and adjust come summer but for now I'm driving.
  7. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    F-36 Emulsion tubes are for US emissions. Try a set of F-24's which are the tubes the engines were originally spec'd with. However, with the changes our fuel has gone through over the last 30 years, someone may need to create a custom tube. The progression holes are also different between US and euro models.
  8. Ak Jim
    Ak Jim F1 Veteran
    9,817
    North Pole AK
    Have any of you guys with mixture issues considered getting an fuel/air mixture gauge? It wouldn't tell you what jets to use but you would know for sure if you were rich or lean and by how much. I was looking in to one of the Innovate Motor Sports LM 2 units.
  9. BillyD
    BillyD Formula 3
    1,840
    Pacific Northwest
    Bill
    I bought the LM2 single input & it helped my tuning. If I had to do it again I'd spend the xtra $$ & get the dual input or some other brand. Theres problems with the tach signal & I'd like to have an adapter to probe each carb individually.
    Bill
  10. 335s
    335s Formula Junior
    Jan 17, 2007
    870
    SF Bay Area
    T. Monma
    I opined the virtues of mercury over water versions elsewhere...
    This tool is the FACTORY specified tool for this job, as it will show problems in progression, balance, cam lobe center syncing, off idle lurch, etc...
    It is NOT an accident that this is a required tool...
    Just remeber, a ported signal, and a filtered line-that is dampened-so you don't let the engine inhale the stuff-tres toxic stuff is mercury...it is the best suited for the job, but requires much respect and experience in its use...
