Carbon Brake Hardware | FerrariChat
Discussion in 'Technical Q&A' started by sherrillt, Apr 24, 2024.
  1. sherrillt
    sherrillt Formula 3
    1,125
    Northern Virginia
    Looking for a source for CCB Hardware (like as pictured). The rotor hat hardware on my California CCB rotors and caliper bleed nipples have unsightly rust and I want to cosmetically freshen them up. I have tried cleaning them up without success/desired results using a toothbrush and rust removal liquids.
    The Brembo website does not list Ferrari and general web searches for CCB Hardware are not yielding much or way of matching the correct generic Brembo parts (if obtainable).
  2. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,439
    Santa Clarita, CA
    Look up Pegasus Racing on Google. I know they have those nuts and sell them individually.
    sherrillt likes this.
  3. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,439
    Santa Clarita, CA
    and the brake bleeders
  4. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,060
    skygeek.com??
    I don't know if they have specifically that hardware, but it looks like aircraft stuff, so they might?
  5. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    They are M6 K-Nuts - available in lots of places. Your difficulty is going to be getting them off the "bolt" as it doesn't have a head.
  6. sherrillt
    sherrillt Formula 3
    1,125
    Northern Virginia
    Do you know the bleeder valve size? I called around and vendors that had parts were asking all types of technical sizing questions that were way over my head.
    all I know is, I want the nuts and bleeder valves That are used on the Brembo Calipers on a California.
  7. fatbillybob
    Aug 10, 2002
    29,255
    socal
    Don't do it! You need to follow protocol for the hardware. All have specific torque. Most use locktite. Most demand new hardware. One of the hardest things to do is properly locktite old bolts. You can't get them factory new clean then they fail and you damage or loose the rotor or worse. Also replacement nuts have to same grade. While you might be just fine you are increasing risk of diy failure on an important safety componant.
