Carbon Ceramic vs. Steel Brakes | FerrariChat
Discussion in 'California/Portofino/Roma' started by Rockman1, Sep 16, 2016.
  1. Rockman1
    Rockman1 Rookie
    Apr 7, 2012
    49
    Orange County, CA
    Just got a new California on Wednesday - so only been driving for two days. Really enjoying the car. Shifting is super smooth. Ride is very comfortable and there are lots of amenities. We already had a 430, and the one big difference I noticed was the brakes -- our 430 was a 2007 and had steel brakes.
    One of my favorite things about the 430 was the braking - it felt like car was sinking teeth into the asphalt to bring you to a rapid but controlled stop. The brakes on the Cali do not feel that way. In fact a couple times that I went to brake, I was "oh sh*t" this car is not stopping as fast as I thought. So have had to make some adjustment to driving style.
    Was just reading about the differences on the internet and it sounds like the main advantage of these is their durability and ability to dissipate heat. However, it said that in non-track conditions, the brakes may seem "squishy" and non-responsive. I don't plan to track the Cali - it will be just for everyday use, so probably not going to hit the temperatures necessary to get optimal performance.
    Just wondered if anybody else noticed this difference? Do they need to warm up first? Or should I just drive more slowly and carefully?
  2. MDEL
    MDEL F1 Rookie
    3,989
    Southern Europe
    Mario
    You probably have the California T and what I can report is about my Cali which is the aspirated version but I believe there won't be a noticeable difference.
    You have to get use to the ceramic brakes because normally they squish more than the steel ones and when they are cold sometimes you get the feeling that the car isn't going to stop, but it ends up stoping. I've tested my Cali's breaks several times at very high speeds and they're absolutely amazing because they really can make the car stop in a much shorter distance than any sports car that I'v driven with steel brakes. I remember the first time I pushed my Cali hard in a motorway straight and I was doing around 280 Km/hour and 100 meters ahead a car changes to my lane and I just had time to hit the brakes. I was so impressed with the effectiveness of the ceramic brakes at this speed and I hardly could believe they've halted the car in such a short distance but they did.
    I think you will get used to the ceramic brakes as you get accustomed to the Cali and soon will see them as a great tool.
  3. good2go
    good2go Formula Junior
    Feb 9, 2016
    939
    I have a California T. The brakes are almost too touchy. The breaks have only been soft after cleaning. Everything in the car works better after its warmed up. Brakes respond better after they are warm. Also downshift a lot to brake.
    I would suggest taking the car somewhere you can accelerate and brake had a few times. Get a feel for the car. I think you will notice a huge difference after the engine, tires and brakes are warmed up.
  4. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    there are quite a few threads on the behavior of the ceramics on the street car....worth a search
    a few high points...
    The CCM's are great, but are very sensitive to how the brake pads are bedded. If bedded properly, the initial bite is better and overall stopping performance is better.
    CCM's also work well/require heat....while "warming up the brakes" on a street car is not practical, when the brakes are applied, they tend to require a bit of heat (i.e. a few rotations of the wheels) to feel like they are working
    Ferrari's current brake system does leave something to be desired in "feel"; good bedding and a fresh brake bleed can help it, but I personally prefer a firmer pedal. Also, seems like the Ferrari's require a bit more brake pedal pressure than other cars for the same braking effect (whereas our Porsche seems to create enough hydraulic pressure to lift a building).
    You might consider a brake bleed (may be overkill), and you can try and bed (or, re-bed) your pads by following the process.
  5. RickLederman
    RickLederman F1 Rookie
    2,836
    Swanton Ohio
    Rick Lederman
    Rockman, they should not feel squishy. I'd have the dealer do a full bleed ... however one of the problems is that potentially they were never broken in. I'm on Cali #3, have a T now, and like was said earlier they are VERY sensitive! Try doing a 'cleaning' by taking it up to 60 or 80 mph and standing on them HARD, into the ABS. Twice is OK. Eventually if you don't drive her hard they will start to squeak & squeal. This procedure will get read of the squeal as well.
    If you replace the pads there is a MULTIPLE stop procedure in the Ferrari maintenance book that starts off at very slow speeds with multiple stops, then a cooling off period followed by more stops at higher speeds, etc. because when brand new the pads almost don't work. I wonder if this is part of your problem. If it is a few high speed stops with hard brake pressure will help right away. You will notice though that when the pads & rotors get real hot it takes a bit more to stop. That quickly goes away. My FF is exactly the same except the brakes are not nearly as sensitive, same as the earlier Cali's.
  6. Rockman1
    Rockman1 Rookie
    Apr 7, 2012
    49
    Orange County, CA
    Thanks for all your thoughts. It is a 2012 California (so not a 30 or T). Only been driving for two days, so will have to do some more experimentation. It did seem like most notable difference was before they had a chance to warm up. If necessary, I will ask the dealer about it. Wasn't terrible - just used to the 430 which really stops when you want it to.
    Thanks again to everyone.
  7. RickLederman
    2,836
    Swanton Ohio
    Rick Lederman
    The '12 Cali the brakes should be perfect. I had a '10 and '12 and they were wonderful. I had to replace the pads on the '10 after 2.5 total hours on the Mid-Ohio race track, making 140 mph by the end of the long straight after a few 30 minute practice sessions. The brakes otherwise don't hardly wear. And you certainly should not have a soft peddle! But, again, after the brake pad swap the peddle was not soft, just very ineffective until doing the multiple stop procedure to wear them in. Good luck! The Cali in any year is an amazing car.
  8. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    I purposely slam on my brakes whenever I get the chance on my country road drives to keep them working smoothly. Just stand on them so hard the ABS kicks in. The brakes in my Cali30 really bites. I also do left-foot braking which IMO tends to result in higher foot pressures, because the same foot is never used on the gas pedal, which requires a much lighter touch.
  9. Brumma
    Brumma Karting
    Jan 24, 2015
    119
    West Hollywood, CA
    Christopher
    Rockman, I noticed the same problem with several different California's while I was test driving cars in my search to purchase--mine included. The dealer re-bedded the brakes before I purchased the car and everything has been fine since. It made a BIG difference in brake feel and stopping ability.
  10. Dicecal
    Dicecal Formula 3
    1,844
    Phoenix, AZ
    Rob
    What he said, re bed the brakes and you will be happy. It's something you can do yourself on a lazy Sunday morning on a quite road.
  11. RickLederman
    2,836
    Swanton Ohio
    Rick Lederman
    Make sure the road does not have a re-tar and stone application on it :). The Cali will peal up the tar and stone and spray it all over your car. Ask me how I know :D
