430 - Carbon engine panels rattling | FerrariChat
430 Carbon engine panels rattling
Discussion in '360/430' started by zsnnf, May 23, 2019.
  1. zsnnf
    zsnnf Formula 3
    Sep 11, 2003
    1,877
    i am hearing a rattle from the back above 5000rpm at full throttle. I am being told it is the carbon engine panals. Has anyone had this issue? The car is a 2009 Scud.
  2. f355spider
    f355spider F1 World Champ Owner Rossa Subscribed
    May 29, 2001
    18,047
    No, but shouldn't be hard to diagnose and fix yourself with the help of a friend, or even by yourself. I would rap on the panels to find where it is rattling and then remove the panel and add adhesive foam to the back or spacers to stop the rattling. I've dealt with this stuff on other cars before. Having a friend, you can rev the engine and listen for where it is coming from and pin point the offending spot.
    LARRYH likes this.
  3. zsnnf
    zsnnf Formula 3
    Sep 11, 2003
    1,877
    Thank you. Yes, they are pretty easy to remove. It is weird that the noise sounds like detonation. But with the sophisticated ECU in the car, it shouldn’t be.
