Carguy or 91TR - I have a question. | FerrariChat
Discussion in 'Boxers/TR/M' started by Flat 12, Apr 17, 2007.
  1. Flat 12
    Flat 12 Karting
    Jul 19, 2004
    72
    Montgomery, TX
    George R Hartigan
    Need to know where the wires go on the coolant temp sensor on the top of the engine on the 89TR. I have the quick disconnects correct but have a question on the other wires. The temp gauge in the car worked fine before the engine out service. Hope one of you guys has the answer. Thanks
  2. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,424
    Alabama (was Mich.)
    Jeff
    Unfortunately I'm not at home so I can't look up the answer to your question. From my faulty memory, there are 2 sensors on top of the goose-neck housing. One is the thermo-time switch and one is the temp. sensor. There are also some other wires secured on a stud, and also I think there is a spade connector on the side or rear of the housing? Was everything labeled before disconnecting for the engine-out job? If Steve-91TR pops into this thread I'm sure he'll have your answers. I'll check in on this thread tomorrow and if help hasn't arrived I'll try and find out as soon as I can.
  3. Steve Magnusson
    BANNED Lifetime Rossa
    26,822
    I'm not sure that I fully understand what the question is, but here are the overall details of the sensors/devices mounted in that large water housing at the front-top of the (US) TR engine:
    forwardmost gizmo pointing up = KE-Jet dual-channel water temp sensor
    2-pin molded connector
    one CB (orange/white) wire and one CR (orange/red) wire
    tells the injection ECUs the water temperature (not used by the water temp gauge)
    2nd from front gizmo pointing up = Thermo-time Switch
    one BL (white/blue) wire and one RV (red/green) wire
    used to fire the cold start injector for a short time during starter motor cranking when cold
    gizmo at the back pointing rearward = water temp gauge thermister
    one H (grey) wire with female spade terminal
    runs the water temp gauge
    horizontal gizmo pointing towards the LH side = bimetallic water thermoswitch
    two separate wires each with a female spade terminal (polarity doesn't matter)
    one R (red) wire and one CN (orange/black) wire
    used to tell the injection ECUs "cold" (closed) vs "hot" (open) and for running the air injection system when cold, etc.
    Obviously, if the water temp gauge is the problem you'd be looking for trouble at/with the water temp gauge thermister, but, since this is a single wire device, I'm surprised there'd be confusion. Also, check/reseat the 9-pin square connector underneath the coolant tank (that H wire from the water temp thermister passes thru this C11 connector on its way to the gauge).
    Anyway, give a shout with a more specific question if this doesn't suffice, or describe the symptom/problem in more detail.
  4. Flat 12
    Flat 12 Karting
    Jul 19, 2004
    72
    Montgomery, TX
    George R Hartigan
    Thanks for responding to my question. Here is what I think happened. I take pictures and label everything on these kind of projects. All the wires were correct including the C11 connection. Didn't know what all these wires did but thanks to you Steve I know now. When I first turned the key on an powered up the car the temp gauge pegged out to the high side. I took the single wire off the thermister and the gauge went to full cold. After reading your response I reconnected the wire and check the C11 connection all correct. The gauge now works the way it should, I ran the car up to temp and the gauge followed as it should. I think the single wire connection was touching the main fuel supply line that feeds the left distribution head and caused a short. Anyway it's great to have guys like you Steve on the chat site your a great help. Thanks George
  5. Steve Magnusson
    26,822
    No trouble and that makes perfect sense (grounding the H wire should cause the water temp gauge to read the maximum value and is the usual first test to determine on a "dead" gauge if the problem is the sender or the gauge itself) -- glad you got it sorted out easily.
  6. Hawaii
    Hawaii Formula Junior
    Jan 28, 2007
    847
    Maui
    Emery
    Steve
    My water temperature gauge isn't working and showing "Cold" pegged left even when the car is hot. I read the above possible fix but not sure where the "H" single wire is. do you happen to have a picture of where I can find that??
    I found the square connector under the coolant tank. Thanks again!
  7. Hawaii
    Jan 28, 2007
    847
    Maui
    Emery
    #7 Hawaii, Feb 23, 2010
  8. Steve Magnusson
    26,822
  9. Hawaii
    Jan 28, 2007
    847
    Maui
    Emery
    Holy crap theres alot of stuff in the way of the thermister
    one H (grey) wire with female spade terminal...I did remove and spray with contact cleaner the 9 pin C11 connector under the water tank but no luck. How the heck to you get to the H wire?? Do you guys stand in the engine compartment some how?? should I remove something to get to it? I can try using smoke and mirrors and a long needle nose to remove and reconnect it. Any ideas? Thanks
  10. Hawaii
    Jan 28, 2007
    847
    Maui
    Emery
    Steve
    Can I ground the grey wire in the C11 9pin connector to see if the gauge goes to full hot w/ the engine running??? Or just key on?? If it goes to full hot..then it means the gauge is working okay??
    Thanks!
  11. Steve Magnusson
    26,822
    #11 Steve Magnusson, Feb 26, 2010
    Yes (just key "on" is fine, engine doesn't need to be running -- but that's OK too -- although engine running might only be possible with C11 still plugged in -- I haven't checked the circuits).
    Also, you don't need to unplug the H wire from the thermister. (Don't know if this is possible or not, but) If you've got a long probe from a multimeter that you can touch to the bare areas on the thermister terminal and/or the female terminal attached to the end of the H wire and touch the other end of the probe wire (that normally plugs into the multimeter) to the engine (ground), that should work too.
  12. Hawaii
    Jan 28, 2007
    847
    Maui
    Emery
    Steve
    I shook around some wires around the H wire and removed and cleaned the 9pin plug again and yee hah! Water Temp gauge is working once again!!
    I appreciate all your wisdom Steve...i'm gonna start calling you the "Guru"
    Thanks again!!
  13. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    I thought we already elevated him to Jedi Master? :)
    Shamile
    Freeze...Miami Vice !
