488 - CarPlay (again) | FerrariChat
488 CarPlay (again)
Discussion in '458 Italia/488/F8' started by Jamflem, May 17, 2022.
  1. Jamflem
    Jamflem Karting
    Jan 29, 2022
    52
    United Kingdom
    James Fleming
    Does anyone have a 488, around 2016, with CarPlay that is working with up to date iPhones? My dealership is telling me even though I have the CarPlay option installed it does not work with modern phones??
  2. Mrpseudonym
    Mrpseudonym Formula Junior
    603
    Sydney, Australia
    Doesn’t sound right. 2018 488 here and carplay works just fine with latest iphone.
    When you say yours “doesn’t work” what are the symptoms? (You do know its not wireless?)
  3. Jamflem
    Jamflem Karting
    Jan 29, 2022
    52
    United Kingdom
    James Fleming
    So I plug in my phone and the phone brings up the CarPlay screen, suggesting it is connecting. If I then press the CarPlay button on the car, nothing happens and the right hand screen freezes until I unplug the phone. Also if you press the CarPlay button on the car with no phone plugged in, nothing happens… the service centre has suggested that CarPlay doesn’t work with newer iOS versions…which I just think feels wrong…
  4. Xrayv8
    Xrayv8 Formula 3
    1,005
    New Jersey
    Xray
    Something along these lines happened in my G wagon. I then went onto the iphone setting and found carplay, tapped it and everything started to work then.
  5. Caeruleus11
    Caeruleus11 F1 World Champ
    11,638
    Two suggestions:
    1. have you tried using a different cable- often times the cable just doesnt mate up well to the connectors/ its gone bad.
    2. have you tried resetting the phone? (on modern iPhones its press volume up, let go, then volume down, then let go and only hold the side button until the screen goes blank)
    Prox likes this.
  6. Jamflem
    Jamflem Karting
    Jan 29, 2022
    52
    United Kingdom
    James Fleming
    Hi…thanks for that. Yep. Tried all that…and 4 different generation of iPhone. Pretty sure it is the car and not the cable or phone..
  7. Mrpseudonym
    603
    Sydney, Australia
    I am not near my car for the next couple of days, but it should be easy for someone else to press the car play button with no phone attached. I am pretty sure there is a message that gets displayed on the screen. That would give you enough to go back to the dealer. Although frankly I’d be changing dealers.
    Jamflem likes this.
  8. Jamflem
    Jamflem Karting
    Jan 29, 2022
    52
    United Kingdom
    James Fleming
    Thanks…yes if anyone could do that then it would be most appreciated!!
  9. Mrpseudonym
    603
    Sydney, Australia
    Couple of other things while we wait for someone to do that .
    On the phone
    1. Siri needs to be enabled
    2. Settings/general/carplay make sure it is set to “allow carplay while locked”
    Jamflem and Caeruleus11 like this.
  10. Caeruleus11
    11,638
    Good ideas! Sorry the tips didnt get you results. Weird.
    Jamflem likes this.
  11. Mrpseudonym
    603
    Sydney, Australia
    Ok here is your answer @Jamflem ..
    with ignition on (but engine not running) and iPhone *not* connected when you press the Apple car play button on the 488 you get a screen displaying the message “please connect your car play enabled device”. So there’s your answer. It’s your car not the phone. Change dealers! Image Unavailable, Please Login
    Prox likes this.
  12. Jamflem
    Jamflem Karting
    Jan 29, 2022
    52
    United Kingdom
    James Fleming
    Thanks for that. Really appreciate it. I will go back to Stratstone with it!!
  13. Mrpseudonym
    603
    Sydney, Australia
    You are most welcome. Its what the forum is for
