Carplay Headunit in 2012 FF | FerrariChat
Discussion in 'FF/Lusso' started by franzapp, Oct 25, 2014.
  1. franzapp
    franzapp Rookie
    Sep 24, 2014
    3
    Hey Guys
    I saw a thread on this from a while back saying that it was not possible to retrofit new to old...
    But looking at the new carplay unit in the FF, it seems like a direct replacement of the current unit. At most there is a different bracket holding the new piece, and any wires going into the glove box should be easy to pass through.
    Has anyone seen the unit out of the car or seen a technical layout of the parts.
    There is no car data coming from or two the screen, so I doubt it requires any updates on the car side.
    I have set my tech friends on it, but I was hoping someone already had an answer.
    F
  2. uhn2000
    uhn2000 Formula 3
    Oct 15, 2011
    2,128
    Toronto
    Joe
    Have not heard anything on my side but I guess it just takes someone to try and buy the unit - then get it installed.
  3. jseoct
    jseoct Rookie
    42
    Westport, CT
    John Seo
    I believe that in a factory installed setup the steering wheel has a dedicated button (for Siri activation?). If true, that would make it more difficult to retrofit a full-blown CarPlay setup in a 2012 FF. Not sure as I haven't read anything clear. Of course, would be terrific if a retrofit were possible.
  4. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    The current wheel has a VR button on the left side/back of wheel, which I assume could be used to trigger Siri. can't recall if there was a dedicated new button, might have to look at
    As for the head unit, a friend who is a tech is just back from factory training. His sense was 1) the head unit has different dimensions, so retrofitting it would require a "heavily customized" piece of work to the dash, trim and behind it (brackets, et al) 2) he said the actual head unit was likely going to be insanely priced as a replacement part and 3) he had no views yet as to what more aggregate software or firmware changes are in place in the car - i.e. the head unit ties into several other car systems so there are likely a set of additional software gremlins that would need to be found, diagnosed and fixed to get it all to work as intended
    If you must have it, I guess you can pay $$ to have a capable custom shop try and do it. Question is going to be cost and aggravation.
    We have a '13 FF, we're going to survive with our iPhones and iPads until we trade up...
  5. NW-FF
    NW-FF Rookie
    Jul 2, 2015
    2
    Central London
    Nils
    I just took delivery of my first FF. Late 2013 (2014 MY)
    Has anybody had any luck with the retrofit of Carplay system? I have come from Bentley and Porsche for the past 10 years and the line system is a real shocker!
    Apart from some battery issues which are being looked at, I am over the moon with the car though.
  6. bobhitch
    bobhitch Formula Junior
    Jun 28, 2014
    324
    Bob
    i asked my dealer if they could retrofit carplay to my 2014 .The answer was no :0(
  7. SSR
    SSR Formula 3
    Jun 14, 2007
    1,134
    I ask 2 US F dealers and one in UK and they said NO!
    Ferrari should offer a retrofit kit for pre 2015 models,every body will change the Chrysler radio is a shame!!!
