CAT bypass pipes with no CEL's ? (5.2) | FerrariChat
Discussion in '348/355' started by Dave rocks, Nov 29, 2013.
  1. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hey Guys,
    I'm in search of facts. I see this topic come up but I don't see hard answers.
    I have a 98 F1 and I'd love to replace the CATs with straight pipes. I see FAB Speed sells these. I also see the mention O2 spacers....
    Are the spacers the only thing needed to keep CEL's off? Do the spacers fake the O2 sensors?
    I appreciate any help on this. Thanks to all in advance!
  2. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Spacers will not work alone, out of range
    Make a box that sends a regulated voltage to the signal I remember about 1.2 volt and a 20 ohm resister on the heater circuit and your good to go no CEL. Basic 02 stuff you can find anywhere on the web :)
  3. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    I've never seen this addressed on FChat, but is the post cat O2 sensor only monitoring cat performance or does it fine tune fuel trim as it does on other cars?
  4. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,741
    The system needs to read different values from the front and rear O2 sensors. The front sensor needs to slowly oscilate between rich and lean as the ECU manipulates the mixture, while the rear O2 sensor sees an essentially constant oxygen percentage. In addition, the read O2 sensor needs to read rich durring warmup.
    This is outlined in the WSM. I'm sure a EE with some meters could figure out how to trick the system.
  5. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    It seems to be more than that. The rear O2 sensor is looking at post cat exhaust gases and is used to further correct the mixture in conjunction with the front sensor. For this reason I have never understood how a car with bypass pipes can run right unless the ECU is reprogramed. The ECU is expecting to see post cat gases and without cats it will be seeing the same mixture as the pre cat sensor. It's not just telling the ECU the cats are or are not working. It would seem you can do what you like to fool the ECU from throwing a cel but if it isn't sensing the actual post cat gases it will not be sending the ECU the correct signal. I.e., you can send the ECU a fake signal that tells it ever thing is in range when in fact the mixture isn't correct. The rear O2 sensor is in the fuel trim loop and bypassing the cats has to make it see wrong exhaust gas composition and throw off the trim. Just another reason to own a 95.
  6. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    Great post John. I've wondered the same thing myself. They sell those "O2 simulators" on various racing-oriented sites, but as you address above, the 5.2 Motronic systems seem too complex for this to provide an actual fix.
    EDIT
    I've only heard of one group that has been able to crack the code on the 5.2 Motronic units for reprogramming purposes.
  7. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    I have a reprogrammed Motronic 5.2, and I am very pleased with the fact that I don't have to play games with it.
    No CEL codes for CATS, Air Injection, SDECU, or the bypass valve, which I don't have. Downside, it was $2,000.
    Mark
  8. XLR8R
    XLR8R Karting
    Feb 14, 2013
    171
    Michigan
    Matt
    Where did you purchase it?
  9. 0.0.1.99
    0.0.1.99 Formula Junior
    Jan 14, 2012
    424
    Carolinas
    Ken
    I am also interested in straight pipes for my 98 but I cannot rationalize the $800 Fabspeed price. As others have pointed out, its just pipe.
    Could an exhaust company create these from stock T304 for substantially less? Maybe we could group buy with a ceramic option, etc. Just having trouble with the price...
  10. Markphd
    Mar 10, 2012
    713
    Had it done through fabspeed.
  11. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Fabspeed sells an ECU that handles this but it's $2k
  12. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    I think Larini has pipes for about 300$ but I can't remember where I saw them.
  13. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    Folks this is so easy to do, grab a couple sections of tube, some flanges from vibrant and weld it up or have your favorite welder weld it up. No thought involved here just get your ass up and do it. You can get a cheap welder and the parts for less then what you would pay for them
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I'd rather pay the $800.00 I own a TIG welder and could do this but It's not as simple as people make it out. Perhaps $800 is a tad on the high side but not crazy IMO.
  15. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    I rather make things but again thats what I do for retirement at the toy shop. Maybe 3-4 hours at most including lunch and a trip to the chronic lounge :)
  16. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I'm not sure why you want to run straight pipes is it not cheaper to just buy hyper flows or something similar and let the computer do its thing.
  17. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Over the last 12 hours I'm 99% sure that I will go with Hyper Flow CAT's. Dennis (theoutcast) convinced me based on the smell of running straight pipes.
    My motivation is to get as much heat out of the car as possible and to not have ceramic elements break down. I already have a no-muffler custom exhaust so hopefully with less restrictive CAT's I can prolong the life of my OEM headers.
  18. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    Guys,
    Here's my take on this. Its just based on my logic so if I'm wrong, please explain it to me.
    Keep in mind, the '95 355's don't use a rear O2 sensor and they work just fine at maintaining the proper fuel/air mixture. But, for the sake of argument, let's suppose we have an original design without any cats at all. The O2 sensor is there to monitor the fuel/air mixture and send appropriate signals to the ECU to adjust the fuel flow through the injectors as needed. Obviously, a second O2 sensor couldn't tell the ECU anything new and would be totally redundant and unnecessary.
    Now we add a cat into the system. The cats only purpose is to oxidize any unburned fuel to comply with current pollution control standards. It serves no other purpose whatsoever. If its new and working correctly, nothing extra would be needed since you can't adjust anything in a cat. The 95 355's are an example of this.
    But, a cat's ability to do its job slowly deteriorates over time so what was needed to guarranty minimum standards was some way to monitor the cat's performance in real time. The post cat O2 sensor was that solution. Its purpose is to measure the exhaust stream and, if its above the minimum threshold set by the pollution control standards, to notify the ECU to throw a CEL.
    If a change in the fuel/air mixture for optimum performance and efficiency is needed, that's done by the precat O2 sensor. Now let's suppose the post cat sensor detected something amiss. Its only choice would be to ask the ECU to further lean out the mixture below what the precat sensor had set for optimum performance in a vain attempt to help a failing cat, not something I would want my car to do.
    Logic tells me this is the only reason for the second sensor. If you don't have cats, you sure don't need one. And if you do (like with the 95's), you still don't need one unless you want to monitor the cat itself. And then, its addition is likely to only reduce engine performance (I'm talking horsepower here, not pollution control efficiency) as the cat nears the end of its useful life.
    OK, guys. Tell me where I'm wrong.
  19. apex97
    apex97 Formula Junior
    Nov 25, 2006
    593
    Stockbridge, GA
    Edward Zabinski
    HJP is correct. The secondary downstream O2 sensors main purpose is to tell the OBDII system if there is an issue in the Cats for the purpose of diagnosis and safety (a plugged cat CAN generate enough heat to burn a car down). If it does no see a reading withing the parameters it is expecting, it will throw a code. If you trick it because you are running test pipes, that is fine, but if you trick it and are still running cats, you are asking for trouble.
    As for the 5.2 systems making any adjustments based on the downstream o2 sensors, I don't know for sure, but in most systems I've seen, the only think they can do is trigger a fixed map limp home mode, not a fine adjustment. (Disclaimer) BUT I DON'T KNOW FOR SURE ON THE 5.2!
  20. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    #20 johnk..., Dec 1, 2013
    Not correct. It's in the fuel trim loop for the 5.2 as indicated by the WSM. {edit} Understand that the wording is typically Ferrari "unclear". The ECU is looking at both O2 sensors all the time. It has no idea how old the front sensor is. It is making adjustments based on info from both, but if the front sensor is working as intended little further adjustment may be required.
  21. junglistluder
    junglistluder F1 Rookie
    Mar 23, 2007
    3,629
    VA
    Brendan
    Spacers alone work just fine for me, but you have to use the "L" shaped spacers not the straight ones. Been nearly 3 years and 5k miles with no CEL. Even passed emissions inspection.
  22. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    With all due respect Johnk, I think this still supports my contention here.
    Not to be argumentative but, since there are two identical sensors, of course the ECU monitors signals from both, just for different purposes.
    Clearly Ferrari is saying the post cat sensor's first and main purpose is to monitor the condition of the cat. Then they say if the first sensor is misbehaving for some reason, the ECU would then correct the mixture from comparable signals received from the second sensor. After all, its just another O2 sensor. But if the front is working fine, the second just continues to do its primary job, monitoring cat performance. In other words, its a redundant check on conditions to help preserve cat performance, not better engine performance.
    I still contend this is all about the cat, nothing else. You don't need to adjust the fuel/air mixture twice if the first sensor is working correctly. Of course I concede there's nothing wrong with having a back up. But I believe that's all its second function is for, just a back up.
  23. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I was all for using a simulator and running straight pipes until I spoke with Dennis (the Outcast) and he stated the smell is bad and it can also burn eyes. SoCal also made mention about the smell.
    Brendan, any issues with smell on your end?
  24. junglistluder
    Mar 23, 2007
    3,629
    VA
    Brendan
    Nope, no issues at all. No heavy gas smell or burning. Just pure exhaust sound and flames :D
  25. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Brendan, do you really get flames? Also, do you have a muffler? I have a custom exhaust with no muffler so I've got a pretty loud sound already...
    My motivation is to get the heat out and not have ceramic elements break down. Additional loudness is just a plus ;-)
