CAT/Slow Down Light Problems with my F355. THEY WERE REPLACED!!!! | FerrariChat
Discussion in '348/355' started by Nikoskevlar, Nov 1, 2011.
  1. Nikoskevlar
    Nikoskevlar Karting
    Apr 16, 2010
    105
    Mid West
    M. squire
    I recently purchased a 1997 F355 with 24,000 miles. Looking into my records the previous owner replaced the cats and ECU at on 2007 and 15,500 miles.
    Now here is my issue. After driving the car today, 70 degree day my SLOW DOWN light would blink at speeds of 70mph and over. And, if I went faster the vehicles SLOW DOWN light would stay on for 10-20 seconds and putting the car into "limp" mode of such.
    My check engine light came on, when I put the OBD2 Scanner I received the following codes.
    PO432: Main Cat Efficiency below thereshold Bank 2
    PO1448: Unknown
    PO139: 02 circuit slow response Bank 1 Sensor 2
    PO133: 02 circuit slow response Bank 1 Sensor 1
    PO134: 02 circuit no activity detected Bank 1 Sensor 1
    P1119: Unknown
    P1446: Unknown
    The Vehicle has TUBI exhuast.
    Its hard for me to believe the CATS need to be replaced this early in their life. The ECU's were also replaced during the same period when the CATS were done. Both at ALGAR Ferrari.
    Any help would be great. THANKS FELLOW OWNERS!
  2. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,673
    San Carlos, CA
    Mitchell Le
    I would start first by changing the two O2 sensors on bank 1 (right side).
    And, check operation of the bypass valve.
    Check the wiring and connectors involved, then reset the car, drive it to see if error codes come back.
  3. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    29,272
    socal
    I would start by agressively cleaning the connections first, reset codes, then see what pops up.
  4. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    +1
  5. Nikoskevlar
    Nikoskevlar Karting
    Apr 16, 2010
    105
    Mid West
    M. squire
    Is there a diagram or a video that shows how to clean the connections correctly? I am 350 miles away from the closest Ferrari mechanic.
    On my former Lamborghini there was a few great websites that showed a full DIY instruction practices for owners to practice.
    Any ideas?
  6. Nikoskevlar
    Nikoskevlar Karting
    Apr 16, 2010
    105
    Mid West
    M. squire
    Also, as my reading I haven't fully diagnosed the problem. Does anybody think this could maybe a problem due to needing header replacement? And if so, is an engine out procedure?
  7. ernie
    ernie Two Time F1 World Champ Lifetime Rossa Owner
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    +2
  8. Docopp
    Docopp Karting
    Aug 28, 2011
    91
    Crosby Texas
    Ed
    the pre O2 sensors plug into the wiring harnesses with blue tape.... I would bet the pre and post O2 sonsors are plugged in backwards.. Also be sure The O2 sensors are correct (a simple check, the pre O2 wires are much shorter than the wires on the post O2's)
    I had same codes on my OBD II and this was my problem, now everything is ...perfect (for now) LOL, ed :)
  9. Docopp
    Docopp Karting
    Aug 28, 2011
    91
    Crosby Texas
    Ed
    your problems are mainly bank 1 (righty side)
    be very sure there are no air leaks where the cat connects to header (may need new donut, very inexpensive but I would jack your car up, pull right wheel off and loosen cat and see if you can tighten it up in a non binding position ( sounds easy.. it is not and it is very important to not have any air leak)....... (I have replaced cats by removing exhaust from above, or removing wheel..... removing wheel is much easier !!)
    good luck, ed :)
  10. f355spider
    f355spider F1 World Champ Owner Rossa Subscribed
    May 29, 2001
    18,055
    +1, I would start with replacing the O2 sensors (pre and post) on bank 1. BTW, what brand and type of catalysts were installed? Oem or aftermarket?
  11. Nikoskevlar
    Nikoskevlar Karting
    Apr 16, 2010
    105
    Mid West
    M. squire
    I have been told they are fab speed cats. That is what the previous mechanic said. Is it possible the slow down ECU is faulty? As the problem only happens when the vehicles speed passes 71mph (slow down light blinks, than stays on completely and car goes into limp mode until vehicle is under 70mph again and light doesn't blink or stay on) than when it's below that speed the vehicle is fine? This is quite the mystery.
  12. The Outcast
    The Outcast Formula 3
    Apr 19, 2011
    1,562
    Royal Oak Michigan
    VERIFY THAT YOUR BYPASS IS FUNCTIONING BEFORE DOING ANYTHING ELSE!!!! DO NOT BUY ANY PARTS UNTIL YOU DO!!!
    First, pull the bypass plunger...it's just under the vacuum dashpot. It should travel smoothly from closed to open position with about 3 pounds of force. If it works smoothly, it's mechanically okay.
    Second, check the presence of vacuum at the dashpot. If necessary, pull the line back to the vacuum tank and inspect it for obstructions.
    It has been somewhat popular for technicians without specific Ferrari experience to plug this line in order to even out the idle...not sure where they got this idea.
  13. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    ELC System 2 Fault
    Manifold Absolute Temperature Circuit High Input
    Evaporative Vac Solenoid Circuit Malfunction
    REMARK ---- These are the "generic" OBDII (not necessarily "Ferrari-specific") DTC definitions
  14. finnerty
    May 18, 2004
    10,406
    +3
  15. fatbillybob
    Aug 10, 2002
    29,272
    socal
