Cat temperature sensors | FerrariChat
Discussion in 'Technical Q&A' started by teamf40, Jul 20, 2004.
  1. teamf40
    teamf40 Rookie
    Apr 12, 2004
    4
    Finland
    Hi,
    Do you anubody knows that can I replace the Cat temperature sensors to
    normally used K-Type sensors (E.G in turbo engines), or must I use Ferrari
    orginal parts ?
    Regards
    Pertti
  2. DGS
    DGS Six Time F1 World Champ
    60,511
    MidTN
    DGS
    If you change only the sensor, you should stick with stock parts.
    But earlier cars have simple (and not very reliable) CAT temperature control modules (CCUs). If you also replace the CCU, you can change the sensor. The replacement CCU would have to be compatible with the car, though. On early CAT equipped cars, the CCU only controls the "slow down" light. Later cars with Lambda loops also have an input from the CCU to tell them when the exhaust is warmed up. EFI cars have the CCU integrated with the engine managment, so you'd have to replace the whole engine control system.
    Updating the cat sensor is not a simple plug-n-play replacement.
    It would help if we knew what model of car we were talking about.
  3. Steve Magnusson
    25,123
    What is driving your need to pursue this project? Is the price of a locally-sourced replacement difficult to accept? Please also give your location.
