CATALYST P0420 CODE | FerrariChat
CATALYST P0420 CODE
Discussion in '360/430' started by MARANELLONATION, Nov 30, 2014.
  1. MARANELLONATION
    MARANELLONATION Karting
    Nov 22, 2006
    133
    North Andover Ma. 01845
    Michael A. Ferrante
    Has anyone thrown a check engine light and pulled this code ? Have there been any Cat failures with the Scuderia ? Code says Cat operating below efficiency on Bank 1. Any thoughts or comments would be appreciated
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,671
    South East
    Jimmie
    Its likely this code has come up before - try a search for previous solutions
  3. bowbells
    bowbells Formula Junior
    Jan 14, 2008
    353
    Guernsey
    Arthur Dent
    How long is this piece of string?
  4. gmani1082
    gmani1082 Rookie
    Nov 4, 2014
    28
    Pickering, Ontario
    Ganesh
    see this code on regular cars all the time at my work, usually just a loose / worn seal - gas cap :) (folks tend to get a code shortly after they filled up) GL
  5. RedTaxi
    RedTaxi F1 Rookie
    3,340
    New Zealand
    Glen
    Same code here but no cats in evidence. Read, clear, drive on!
  6. autowerks9
    autowerks9 Formula 3
    BANNED Rossa Subscribed
    Sep 1, 2009
    1,161
    North Wales, Pa.
    David S.
    P0420 is a catalist inefficency code, Bank One, right side cylinder bank. The ECU is looking for a change in referance from the Fist O2 sensor to the Second O2 sensor, after the catalist. This shows the ECU that the catalist is converting the exhaust gasses. As the catalist becomes less efficent over time the light can illuminate. It can be caused by aftermarket calalist as they have a different efficency rate outside of the ECM profile. Or the catalist itself has deteriorated or is contaminated.
    A "gas cap" error is typically po440 (evap system leak ) or a po456 ( small evap system leak )
    David
