Catalytic converter question | FerrariChat
Discussion in 'Technical Q&A' started by JohnMH, Feb 14, 2023.
  1. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,818
    Bologna
    I have heard of hollowed out catalytic converters, but is there any shop out there who can put the ‘guts’ back in them once they have been hollowed out? Some oem replacements for exotics cost more than $10,000.
  2. mechaniker
    mechaniker Formula Junior
    May 30, 2004
    608
    Germany
    ernie likes this.
  3. INRange
    INRange F1 World Champ
    12,533
    Virginia/Florida/Caymans
    JD
  4. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,818
    Bologna
    Thanks, it seemed possible, but an internet search provided no answers.
  5. RedNeck
    RedNeck F1 World Champ
    12,269
    The CSA
    Me
    Depending on which car, are you stuck on staying OEM? Might be more cost effective just to go with aftermarket cats, tend to keep the heat down in the engine bay also, not to mention valuable real estate as stock Ferrari cats tend to be hot fat pigs...
    Mike Morrissey likes this.
  6. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,818
    Bologna
    Alas, I am not looking at fitting a Ferrari with cats, I need to fit out my 92 Diablo with two units.
  7. RayJohns
    RayJohns F1 Veteran
    7,920
    West Coast
    Ray
    As I always say, "when in doubt, get the die-grinder out"
    Depending on how handy you are with a TIG welder, I don't think it should be all that difficult. I've knocked the cores out of several converters. It's just a big ceramic (?) block looking deal that is basically a honeycomb affair. I'd think if you needed to make one, you could cut that part out, then cut open your OEM cat, stick it in there and weld everything back up. Or search 'catalytic converter core' on Google and you should find plenty of stuff.
    I had Hyperflow cats on my 360; if they are still around, perhaps they have something as well.
    Ray
  8. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,818
    Bologna
    Thanks - it might come to that, but I would need to find some cores which can cope with a 5.7 V12 at 7500 rpm.
  9. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,818
    Bologna
    Is hyperflow still in business?
  10. Aerosurfer
    Aerosurfer Formula 3
    1,878
    Indianapolis
    Nick
    I used Fabspeed to have a set of 456 cats done on my car last summer. They offered both recoring and thier own versions. Someone had already cut out my stock ones and did a really poor job rewelding them shut, so i went with a new setup. Very happy with thier product.
    Likely you would have to send yours to them either way, recore or new build
  11. RayJohns
    RayJohns F1 Veteran
    7,920
    West Coast
    Ray
    All I can say is, "I never met a test pipe I didn't like"
    Ray
    020147 and Mike Morrissey like this.
  12. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,818
    Bologna
    Alas, the car will go to Europe and be registered (hopefully) as an auto d’epoca which means it should be a good representative of its type.
    I did this with my Countach and no objections were raised concerning emissions equipment, but it had all its original components (i.e. none!) The Diablo should have its original bits visible, but I have no idea whether a non-functional catalytic converter will cause an issue at the time of original registration or in subsequent years when it goes for its bi-annual ‘revisione’.
  13. EP328
    EP328 Formula Junior
    622
    Northern California
    Ed
    I believe many states, including California and EPA classify spent catalytic converters as hazard waste. So if cutting one open and knocking out the block, Don’t toss the guts in the garbage.
  14. fatbillybob
    Aug 10, 2002
    28,980
    socal
    No question guts can be replaced.
  15. RayJohns
    RayJohns F1 Veteran
    7,920
    West Coast
    Ray
    Thanks very much Ed. And you know... the EPA is probably hiring:
    https://www.epa.gov/careers/how-apply-finding-right-job
    Ray
  16. Mike Morrissey
    Mike Morrissey Formula 3
    1,143
    Denver, Colorado
    Mike Morrissey
    #16 Mike Morrissey, Feb 17, 2023
    The Hyperflow name was purchased by Scuderia Rampante, Troy, the original owner (Atlanta), retired now, still works on them occasionally. Check with SRI. I had mine re-cored for $1200.00 a few years ago.
    RayJohns likes this.
  17. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,217
    Georgia
    Wade Williams
    I have had FabSpeed recore for me and was very happy with the results.
  18. RayJohns
    RayJohns F1 Veteran
    7,920
    West Coast
    Ray
    I believe Troy is the person I dealt with back in the late 90's. Great guy.
    Ray
  19. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,019
    HJS are excellent cats. Made in Germany. Not all cat quality is equal. If you want to check on heavy metal loading, call a muffler shop to get scrap value. Some cats are worth hundred, and others are just haz waste.
    BTW, I got my HJS cats from Speed Tech in NH (603.856.6618). They set up some welds for me on the HJS cat bodies which were beautiful.
  20. Waggntx
    Waggntx Rookie
    Mar 25, 2022
    36
    Alice Franke
    Aerosurfer likes this.
  21. Waggntx
    Waggntx Rookie
    Mar 25, 2022
    36
    Alice Franke
    After deleting my 456 cats, the CEL appeared. If I were to replace with FabSpeed cats, would the ECU reset and cancel the CEL or would it require a flashing?
  22. Cameron Henlin
    Cameron Henlin Karting
    151
    Roseburg OR
    Cameron Henlin
    You could fix with either new cats or O2 sensor anti fouler. Your CEL is probably an error like "rear O2 out of range". Worst case after you do the new cats or anti fouler, you will need to disconnect the negative battery cable for 10 minutes or use a cheapo OBDII code scanner to issue an all clear to get rid of the CEL. (ANY of them will do, it's a universal standard in this case)
  23. Nino1964
    Nino1964 Formula Junior
    302
    North Georgia
    waymar, JohnMH and Aerosurfer like this.
  24. f355spider
    f355spider F1 World Champ
    18,044
    Sometimes aftermarket catalysts are not as efficient as OEM and you will still get "low catalyst efficiency" codes, requiring some sort of O2 sensor extension or "anti fouler" as you call it, to eliminate the CE light. Just my experience.
