Catalytic Converters for 355s | FerrariChat
Discussion in 'Technical Q&A' started by Aeroengineman, Oct 2, 2004.
  1. Aeroengineman
    Aeroengineman Formula Junior
    Oct 5, 2003
    897
    Maple Valley, WA
    Dave Tegeler
    What are the options
    Which is best
    What is the price difference
  2. Steve Magnusson
    26,932
    I'd always check www.hyper-flow.com as one possible source.
    I can't recall anyone ever posting that they were able to get a cat thru an authorized F source for something less than an arm or a leg ;) (like 2X or 3X the Hyper-flow price, and it's not polished.)
  3. redhead
    redhead F1 Rookie
    Dec 26, 2001
    4,869
    ~Red~
    As an ex-dealer, I would recomend the Hyper-flows as well. They are a great product and we have installed them on 3 cars with no issues.
  4. cinquevalvole
    cinquevalvole Formula 3
    Feb 6, 2004
    1,161
    Germany, Bayern
  5. RF128706
    RF128706 Formula Junior
    Apr 8, 2004
    280
  6. Dave_Car_Guy
    Dave_Car_Guy Karting
    Apr 24, 2004
    130
    Northern California
    Dave
    #6 Dave_Car_Guy, Nov 11, 2004
    My 355 had its 30K service this summer, plus replacement of manifolds and cats. I went with the Tubi manifolds and the Hyper-Flow cats and I could not be any happier. The sounds is great, and by leaving on the stock muffler, it is not too loud, except when you jump on it above 4,000 rpm or so, at which point is produces a wonderful scream. I could always add a Tubi muffler on later, but I like the combo I've got...here is a picture of the workmanship of the Hyper-Flow before installation:
  7. yfc
    yfc Karting
    Dec 23, 2003
    212
    Geneva / Switzerland
    Christophe
    Hi Dave,
    I guess that your picture apply to the main CATs (the ceramic ones). Is it correct?
    Let's assume it's the case. I then guess that the two holes I can see are for the lemba sensor. Was it just a "plug & play" job to put the Hyper-Flow in place with the sensor? Or have you had to do anything special?
    Bye for now,
    Christophe.
  8. cinquevalvole
    Feb 6, 2004
    1,161
    Germany, Bayern
    http://www.fuchs-esd.de/
  9. RF128706
    Apr 8, 2004
    280
  10. Dave_Car_Guy
    Apr 24, 2004
    130
    Northern California
    Dave
    Yes on all counts. It was definitely a "plug and play" exercise, although I didn't do it myself, but had it performed at the shop during the rest of the 30K service and replacement of the manifolds. No special adjustments were necessary.
  11. bartman
    bartman Karting
    May 17, 2004
    127
    new jersey
    Andrew
    My cat died the other day. I was thinking about putting in a Hyper flow too. Is there any downside (other than environmental) to just removing the cat all together?
  12. f355spider
    f355spider F1 World Champ
    18,055
    You may end up with your "check engine" light on all the time. Not good, since it will mask any other problem that would turn on the light...since it is already on.
    Here is another aftermarket cat:
    http://www.hgparts.net/catalog/product_info.php?cPath=10&products_id=32
  13. yfc
    yfc Karting
    Dec 23, 2003
    212
    Christophe
    Why are you expecting the "Check engine" to light on? I can't see why since the Hyperflow is ready to accomodate the "standard" two lambda sensor (before and after the CAT).
  14. Chiaroman
    Chiaroman Formula 3
    1,689
    New Jersey
    I am also in NJ.
    I am guessing that if you have a cat. you need to keep the cat. to pass inspection. (Don't ya just luv it!)
    I didn't have my air pump connected and the private garage doing the inspection would not even start the inspection until it was connected.
    Tom
  15. f355spider
    18,055
    His question was whether there was any downside to "removing the cat altogether"...not any downside to using an aftermarket cat.
    Dave
  16. yfc
    yfc Karting
    Dec 23, 2003
    212
    Christophe
    Hugh,
    You're right. Sorry about the confusion.
    Christophe.
