Catalytic Converters question | FerrariChat
Discussion in '348/355' started by rbellezza, Nov 24, 2009.
  1. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    I red a few scary threads where the Catalytic Converters could be the possible reason for serious engine problems if they break inside. In my knowledge, the cats on my 348 are still the original ones and so I am getting a little paranoid about it. I did the smog test a couple of months ago and the car passed it easily. Does that means my cats are still in good shape ? What are the signs of cats on the verge to go bad ? Any way to check them without taking them down ?
  2. Night life
    Night life F1 Veteran
    7,322
    The city that rhymes with fun in Canada
    Roberto
    The post you read was probably mine :(, unfortunately the only way to check is to drop the exhaust and look directly inside to see the matrix but this will only show exhaust side not the other where damage might have occurred.
    If you passed your emission test you can probably breath a little easier as a failing cat is rare and not as common as you would think. Besides my damage occurred due to my lean mixture, failed cat and high revs that I maintained for a long period of time. If I would of driven her a bit more conservatively my engine damage might not have occurred. Keep your eye on your CEL lights when and if they come on drive conservative and pull the codes
  3. judge4re
    judge4re F1 World Champ
    Apr 26, 2003
    13,477
    Never home
    Dr. Dumb Ass
    You can still most of the conversion without the light coming on with an abraded substrate in the can.
  4. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    Thanks Roberto ...
  5. MaterMech
    MaterMech Formula Junior
    Feb 26, 2007
    476
    Los Gatos CA
    Mark Johnson
    #5 MaterMech, Nov 25, 2009
    Here is a more common problem. Cat monolith is loose and rotating in its can. As it grinds against the thermocouple and rotates it will slowly disintegrate. Unless you have fuel control and or valve problems you can't expect the damage you speak of. Maybe!
