355 - Catalytic Converters | Page 2 | FerrariChat
355 Catalytic Converters
Discussion in '348/355' started by SeattleM5, Jul 5, 2023.
  1. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    The ones I had were hyperflow but no longer available
    New ones are capristo but I feel any 200 with a heat blanket would work better. They do have the 250
    Capristo are expensive but they have very nice heat blankets
    Uberpower likes this.
  2. sfcarguy
    sfcarguy Formula Junior
    537
    Earth
    Capristo cats are overpriced. Tubi retails for 6200 USD. If you still have factory cats it’s a similar result to Fabspeed’s recording service. They use 200cell high flow HJS cats as well.
    You don’t need heat blankets on the cats, particularly on an NA motor.
  3. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,477
    Los Angeles
    $8,500, or $6,200, for a pair of cats, is absolutely insane. What is going on.
    JLF and ShineKen like this.
  4. sfcarguy
    537
    Earth
    Agreed. Quality high flow metallic cats are expensive across the board.
  5. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    These are about 5500 usd
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    As I said you don’t need heat blankets but it helps when passing emissions in cali
    If your cats are cold when completing the rolling road tests you will fail.
    I went to a small shop and they would let me drive right in after I took the car for a hard drive.
    Passed easily under these conditions
  7. sfcarguy
    537
    Earth
    #32 sfcarguy, Mar 4, 2024
    Haha didn’t notice that was in AUD. They retail in the US for 4600 w/o heat blankets and I bet Mike @ yellow compass discounts them.
    I guess the Tubi is overpriced than.
    My solution has always been to make an appointment for a specific time and then get the cats stupid hot before testing. The guy I use knows that the cars I need tested are finicky so he's accommodating.
    taz355 likes this.
  8. Qavion
    Qavion F1 World Champ
    14,682
    Ian Riddell
    Aussies still think they are overpriced :p
    taz355 likes this.
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    That’s what I did before blankets now it’s. It a problem with out doing that.
    But as I said that works everytime
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    So do we up here in the northern hem
    Qavion likes this.
  11. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,303
    CT
    John Kreskovsky
    I would bet that all these manufactures use basically the same core and only fabricate the "container". Whether it's Tubi, Capristo, Fabspeed, ... my bet is all they do is bend tubing and weld pieces together. Making the cores is a specialized process and I can't see where these low volume manufactures would invest in that capability.
    That said, my Nouvalari 200 cell cats ($1100 for the pair at that time) that I bought in 2013 got me trough emissions testing in CT without a problem until testing was no longer required in CT, after 2020, due to the car being more than 25 years old.
    https://www.catalyticconverters.com/construction/
  12. ShineKen
    ShineKen Two Time F1 World Champ
    20,222
    Southern California
    Nostradamus
    Capristo, Kline, and Fabspeed use high quality hi-flow HJS cats and builds around them. Others source cats from god knows where.
    Larini cats are $2300 and come with bespoke shielding.
    f355spider and Qavion like this.
  13. JoeCab
    JoeCab Formula Junior
    493
    Colorado
    Joe C
    I think you're right - many manufacturers use HJS cats which are a high quality metallic core cat.
    Magnaflow has a round 5" diameter 200 cell metallic cat which is OBDII compliant and would work great in this application - and they are made in house with their own cores. They are efficient enough that they usually won't trigger a CEL like most other high-flow cats do. Basically, the only way to do that is to throw a lot of precious metal loading at the core.
    But they have more than tripled in price since 2019, to the point where just the cats are way more expensive than you paid for your complete Nouvalari units. And then you would still have to fabricate the inlet and outlet fittings for them, along with the 02 sensor bungs.
  14. sfcarguy
    537
    Earth
    Magnaflow cats are trash. They won't last 5 minutes on a F355.
    Almost everybody uses HJS cores.
  15. ShineKen
    20,222
    Southern California
    Nostradamus
    I could be mistaken, but I don’t think Tubi uses HJS cats.
  16. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,860
    Lake Villa IL
    While I'm absolutey sure HJS cores are better, I used magnaflow metallic cats on my car for years with zero issues.
  17. A348W
    A348W Formula 3
    Jun 28, 2017
    1,869
    North Wiltshire, UK
    I fitted ones from superformance. £1.4k now Been on for 3 years and fine so far. At that price more than happy.
  18. sfcarguy
    537
    Earth
    They definitely do, but they don't publish that info specifically.
  19. sfcarguy
    537
    Earth
    Maybe MF used to be of better quality, but they no longer have any semblance of durability.
  20. JoeCab
    493
    Colorado
    Joe C
    MF has a lot of different products at vastly different price points, from super-economy replacement cats to high-end metallics. I've had good luck with their high-end stuff on other cars, but have not specifically used them on a 355. Their low-end offerings may in fact be junk.
  21. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    Capristo as said above also have 250 core
  22. CCWillF355
    CCWillF355 Karting
    Nov 14, 2019
    110
    London
    Chris Williams
    My F355 came de-cated and I’m starting to get a little feed up with drone, this is only at idle below 2k revs. So want to get some sport cats.
    My setup already is Tubi manifolds + Capristo test pipes + capristo exhaust back box + Capristo value.
    What sport cats would everyone recommend?
    Here’s my car now:
  23. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,705
    San Carlos, CA
    Mitchell Le
    Fabspeed 200 cats.
    Or Capristo sports cats.
    Beware that cats are getting very expensive lately.
  24. johnk...
    Jun 11, 2004
    11,303
    CT
    John Kreskovsky
    What year? I've had Nouvalari 200 cell cats on my 2.7 car for 11 years w/o problems.
    MIAJK likes this.
  25. audi_328
    audi_328 F1 Rookie
    2,919
    NH
    Audi
    The pair I bought from you around 7 years ago have been great with zero issues since.
