458 - Catastraphic failure of steering rack | Page 2 | FerrariChat
458 Catastraphic failure of steering rack
Discussion in '458 Italia/488/F8' started by 24000rpm, Aug 5, 2023.
  1. 24000rpm
    24000rpm F1 Rookie
    #26 24000rpm, Aug 6, 2023
    Yes, its a totaled car. And it wasn't fixed properly on its frontal body parts.
    and I got it for 50% below what a nice car should ask for.
    :D
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,916
    Isle of man- uk
    Before you test this steering rack, it might be an idea to look at the power steering pump to check it is not putting too much pressure out at end of stroke. When the lock is full on, you would think there would be something to unload the assisting pressure, my thinking being a sudden seal failure that bad has to have a cause.
    My RAV4 power steering changes tone when on full lock as if a relief valve is lifting. in the past it would not supply any pressure sometimes when the engine was started, but if you switched off and restarted it was fine for months, in the end we changed the fluid and no more issues- so the pump did have a loading and unloaded state.
    24000rpm likes this.
  3. Eric C
    Eric C F1 World Champ
    Mar 20, 2009
    10,957
    St. Louis, MO
    Eric
    I was thinking the same. These damn drama queens. Like a bunch of girls around here. Click bait.
    iceblend and ACSATCO like this.
  4. Eric C
    Mar 20, 2009
    10,957
    St. Louis, MO
    Eric
    and there you go.......
  5. 24000rpm
    24000rpm F1 Rookie
    ah, ok, lesson learned.
    thank you.
    Eric C likes this.
  6. Linetta
    Linetta Rookie
    Jun 2, 2022
    4
    Manila Philippines
    Leo
    Excellent diy
  7. Linetta
    Linetta Rookie
    Jun 2, 2022
    4
    Manila Philippines
    Leo
    do you have the actual sizes of all 4 seals?
    thanks in advance
  8. 24000rpm
    24000rpm F1 Rookie
    u want me to measure them?
  9. Linetta
    Linetta Rookie
    Jun 2, 2022
    4
    Manila Philippines
    Leo
    If you can please and thanks again
  10. 24000rpm
    24000rpm F1 Rookie
    Willl likes this.
  11. SD455TA
    SD455TA Formula Junior
    Again great job and well presented even if it scares me, love that pipe wrench! Also, really liking that complex mathematical worksheet the seals were on.
  12. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,938
    Thanks for the excellent photos and description! Great job.
    I also like the BA pipe wrench and the ingenuity
  13. Linetta
    Linetta Rookie
    Jun 2, 2022
    4
    Manila Philippines
    Leo
    Thanks a lot and keep it up
  14. hrk
    hrk Rookie
    Dec 21, 2020
    5
    Heikki RInta-Koski
    Great write up and photos. My contribution for this could be the two bearings on the pinion shaft. Lower one at the pinion end NTN 6001, and upper one by the universal joint INA F 65769.
