Cats or not? | FerrariChat
Cats or not?
Discussion in '365 GT4 2+2/400/412' started by markcF355, May 31, 2007.
  1. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    Hypothetically speaking of course, if I lived in a state that required catalytic converters, lets just say NJ, and an Italian car a friend of mine owned didn't have them, would that be a problem?
    I can't find anything that states a car in NJ MUST have them. In the state guide for performing inspections they use the phrase "if equipped with catalytic converters... bla bla bla... test them". So if not, don't?
    I tried calling Dick Merritt but I get a message machine so I don't know if the number is correct.
    The guy doing the inspection can't get the machine to accept the cars parameters and I'm afraid of him calling the state to ask why.
    The car is in perfect tune and will easily pass without cats so I really don't want to install them if I don't have to.
    Any thoughts?
  2. dstacy
    dstacy F1 World Champ
    11,998
    GMT -5 & GMT +1
    Dave
    A 400i tuned to the factory specs will fail emissions in almost every state in the US.
    The factory specs call for CO levels to be in the 1 to 2% range. Way too high for most states standards.
  3. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    The federal law as well as most states' law requires that whatever emissions equipment a car came with cannot be removed...EVER. So, even if a car is exempt from emission's tests or requirements, the emissions equipment that came on the car OEM or part of a gray market conversion still cannot legally be removed. Of course if the car is old enough to be exempt, the chances are you would not likely be caught...but, it is still illegal.
  4. Fritz Ficke
    Fritz Ficke Formula 3
    2,266
    Tucson, AZ.
    Fritz Ficke
    This is a fact. At idle, yes it will pass but not loaded, CO is way to high if it is running right.
    By year the car will fail the visual inspection in AZ with out Cats.
    My "friend" just went through this here.
  5. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    In Pa., if a vehicle 'registers' under 5,000mi/yr., it is exempt from emissions.
    In Fl., the state stopped emissions testing because over 95% passed from yr. to yr.(5 yrs. ago).
    Some states exempt emissions testing on vehicles 25 yrs.+(figuring that for its age &/or collectability, it won't be driven enough to make much diff. or burden owners of the expense).
    If you have cats, & can get around the emission exemptions w/o cats, 'save the cats' for a future owner who would have to get the vehicle tested.
  6. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    In NJ if you register your car as historic it does not have to pass ANY inspection, emission or safety, but their are restrictions on driving it. Cars with historic plates do not have inspection stickers in NJ. Go to a show and check them out.
    In NJ at a private inspection station will enter all the parameters but the primary one is year of manufacture. Based on that year it must pass a hydrocarbon (HC) and CO test. As other posters have stated, even in tune a 400i will not pass. An early 400 might because of looser regs.
    My '74 Lotus Europa with Stromberg carbs came real close to passing. It needed to be below 300 ppm and it would miss by 20 or 30 ppm but "we have the technology" to get a sticker.
    ON the other hand my '69 Lotus with a Cosworth BDR and 45 mm Dellorttos, passes the 300 ppm test by raising the idle to about 1200 ppm and going a 1/4 turn lean on idle screws. The '69 is exempt but we test it anyway.
    My 400i has an air pump which I reconnected. I will let you all know how much difference it makes even without cats. I will set the idle mixture to spec without the pump connected and then retest with it connected. The exhaust gases are hot enough to burn off some of the CO which is a very reactive chemical. (I'm a Chem Eng.) My exhaust is set up in such a way that I could install a cat' if and when needed. There are some specialty vendors that can supply a good one with low back pressure at a "reasonable" cost. Modern cats do not need air pumps in most cases. They have a dual catalyst system and low back pressure.
    Ken
    p.s. Hopefully, we are all friends out here reading!
  7. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    I didn't remove the cats. It never had them. I checked into the standards and at idle, it'll pass. I don't know about at 2500 rpm. I've got some more reading to do, but frankly right now I'm too drunk.
  8. KraigG
    KraigG Formula 3
    May 25, 2006
    1,501
    Willow Springs
    Kraig
    #8 KraigG, Jun 2, 2007
  9. Razzer92
    Razzer92 F1 Rookie
    Aug 4, 2006
    4,496
    if i could i would murder that cat ;)
  10. RoWis
    RoWis F1 Rookie
    Apr 19, 2006
    4,845
    Vancouver, B.C.
    #10 RoWis, Jun 2, 2007
  11. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    OK, here it is.
    In NJ if the car didn't come from the manufacturer with cats, you don't need them. As per 7:27B-5.6 Emission control apparatus examination procedure:
    "The procedure for examination of the emission control apparatus of a gasoline fueled motor vehicle, required at N.J.A.C. 7:27-15.5(f)3, shall, if the motor vehicle had a catalytic converter as original equipment, consist of a visual check to determine whether a properly installed catalytic converter is present on the motor vehicle."
    HOWEVER, the emissions standards are so high that you would burn up your engine trying to meet them without one. (way too lean, .74% CO...)
    So, I'm going to add cats to the car. Before I can, I have to stabilize the fuel system so it runs at a constant 14.7 stoich. To that, I'll covert the K-Jetronic to a K-Jetronic with Lambda. I'm thinking I can use a Frequency Valve on the control pressure circuit like the Bosch Lambda system, but with my own controller.
    I found a company in CA that makes such a system and I'll be calling them on Monday. If their price is acceptable, I'll use theirs. If, not, I'll make my own.
    As for the cats, I'm looking at the Magnaflow 94008 universal dual port to replace the first muffler. I can't find any dimensions on the web so I'll have to call them too.
    At this point my main concern is the how to handle the vacuum triggered enrichment. Will thickening up the mixture hurt the cats?
  12. Steve Magnusson
    26,766
    I don't think that you would absolutely HAVE to do this. It is true that if you are going to run K-Jet without Lambda with cats you need to make darn sure that the mixture is not tweaked overrich and everything related to "fuel delivery" is working OK, but prior F models do this (e.g., '83 US 308QV). The added complexity of Lambda functionality wouldn't be a plus for a 400i IMO.
  13. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    I can't find a Ferrari that came from the factory with cats that had an open loop fuel system. All the ones I looked into have a sensor and frequency valve.
    Besides, having full control over the mixture at all loads and rpms seems better than the vacuum control on the warm up regulator.
    As of now, I'm using a MegaSquirt for my ignition control with the thought of going full blown EFI someday. I don 't know if I want to switch completely over using electrical fuel injectors or simply control the control pressure of the existing K-Jet system.
  14. Steve Magnusson
    26,766
    As I said, 1983 US 308QV is one example with cats that has an open loop fuel system, so is 1983 US MondialQV and 1980-82 US 308i-2V. Also at WOT, even the F models equipped with frequency valves run "stupid" (and a little rich intentionally). Sounds like you know what you're doing so not trying to dissuade you -- just noting that usually on resale, less deviation from stock is an easier sell, and I'd have to guess that most 400i and BB512i in the US with added cats didn't have Lambda functionality added.
  15. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    Maybe as a starting point I'll install just the 3-way cats and sensors. I'll use the sensors to manually adjust mix. If I don't get passing NO levels, I'll add the feedback.
  16. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    I'm installing Magaflow 94008 cats without feedback. I've been told to set the CO to 1.2% and all should be fine.
    Now my question is, how many mufflers do I remove? For fit, I can get away with removing one, but for back pressure I think I should remove two.
    For those of you who have cats, how many mufflers do you have?
  17. 400iGuy
    400iGuy Formula 3
    1,076
    Central Florida
    Al
    The center muffler section that came on my '84 400iA has the cat replacing the front 2 mufflers leaving only the last muffler. It also had a closed loop system with O2 sensors. I've replaced them with OEM from Ansa. No emission checks in FL :)
    Al
  18. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    So you have 1 cat and two mufflers on each side? One muffler in front of the rear wheel and one behind.
    What is the O2 sensor connected to?
  19. 400iGuy
    400iGuy Formula 3
    1,076
    Central Florida
    Al
    #19 400iGuy, Jun 7, 2007
    Here's what mine looked like when it was on the car. Sorry I don't have an actual photo but they're burried in the garage where I can't get to them. On each side there is a single cat with 2 inlets and 2 outlets that very closely match the headders and mufflers. I recall when I first looked at them long ago they were manufactured by a German company and I've seen the same name on mufflers/cats on recent Ferraris (360s). Of course this cat was acquired back in the '80's when the car was federalized. The O2 sensors were hooked up to Bosch electronic boxes, one for each sensor, that were under the rear seat cushions. All in a box now.
    Al
  20. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    Great. Thank you.
    I was going to use the MagnaFlow 94008 but I found out that they're not stainless. Its a shame because, like yours, they're a nice 2 x 2" design. It looks like I'm going with four 4" spun stainless units.
  21. kevinGTB1
    kevinGTB1 Rookie
    Sep 12, 2009
    3
    Hello everyone just new here hope to stay long. Thanks
    By the way I need help. I was confused if the magnaflow catalytic converter is pretty good?and also where to buy? I do searched and I tried it here for some queries Magnaflow Catalytic Converter. Anyone tried it here.? Any suggestions, please let me know. Thanks.
  22. kevinGTB1
    kevinGTB1 Rookie
    Sep 12, 2009
    3
    #22 kevinGTB1, Sep 12, 2009
    Hello everyone just new here, hope to stay long. Thanks
  23. kevinGTB1
    kevinGTB1 Rookie
    Sep 12, 2009
    3
  24. ArtS
    ArtS F1 World Champ
    Nov 11, 2003
    13,285
    Central NJ
    Welcome aboard Kevin,
    I recall reading that some of the 308 guys have built up exhausts using Magnaflow mufflers but I don't recall any mention of their cats.
    Do you have a 400 or a 412?
    Regards,
    Art S.
