Cats | FerrariChat
Cats
Discussion in '348/355' started by hkbrandt, Jun 7, 2008.
  1. hkbrandt
    hkbrandt Rookie
    Oct 30, 2007
    29
    Henderson, NV
    Hello Gentlemen,
    I am a fairly new owner of a nero 355. In my opinion the 355 is without question one of the most beautiful automobiles ever created. Then throw in the nero. Wow. Sorry Rosso people. Just an opinion. All 355s are beautiful.
    Now time for the 'I am an idiot' portion of my first post.. I don't understand the primary and secondary cats. This is what I think I know. I have the Hyperflow cats. I have the original 2ndary cats. Am I right in assuming the Hyperflows pass the exhaust after the bypass vales have opened under higher rpms resulting in the roar? If so then the 2ndary cats are mainly for idle? Do the bypass valves perform a perfect function and flow ALL exhaust through the hyperflows under the higher rpms? I would guess so. So my question is .. is the only reason people change the 2ndary cats is to change the idle and low rpm sound? If so, just how much can this change due to the cats? Would it be worth it to change to a Kreissig or Fabspeed 2ndary cat set up or is this just a waste of $$. BTW- I have Capriso 2 exhaust. Nothing I have ever heard sounds like the 355. Unfortunately the 360s and 430s sound like pale imitators. Again just my opinion.
    Thanks to anyone willing to put time into my ignorance.
  2. f355spider
    f355spider F1 World Champ
    18,053
    The exhaust bypass opens up under wide open throttle, over 3500 rpm or so. At that point, a good portion of the exhaust is then running through the Y-pipe or "secondary cats" as you call them (could be a 50/50 split). The main cats (hyperflows in your case) are where all the exhaust runs through during idle, and during part throttle opening, the majority is still running through the main cats (hyperflows in your case). At wide open throttle, it is split, between the two.
  3. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,973
    MD and NE
    Robbie
    #3 285ferrari, Jun 8, 2008
  4. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Well For starters........... welcome to the 'nero alleanza' ....... the exclusive fraternity of 'nero ferrari owners' ........ :cool:
    As f355spider said the hypers are flowing 'full time' and the secondaries flow when the 'bypass' opens.
    285 what size tubes are on your new burns secondary pipe? Are you going to coat that as well?
  5. 285ferrari
    Sponsor
    Sep 11, 2004
    20,973
    MD and NE
    Robbie
    Not sure the exact size, yes I am eventually going to get it ceramic coated also
  6. hkbrandt
    hkbrandt Rookie
    Oct 30, 2007
    29
    Henderson, NV
    Thanks guys for the input. That clears it up. So maybe I will do the secondary bypass upgrade. This gives me a chance to tinker with an otherwise perfect machine. I have the fabspeed headers as well. The person who owned this car before me has done just about every upgrade possible so this doesn't leave much for me to do other than just drive it.
  7. hacker-pschorr
    hacker-pschorr Formula Junior
    Sep 27, 2006
    584
    Land of Lambeau
    So the secondary O2 sensors are after the main CATS, not the smaller WOT CATS, correct?
  8. 285ferrari
    Sponsor
    Sep 11, 2004
    20,973
    MD and NE
    Robbie
    #8 285ferrari, Jun 8, 2008
    yes---if you look close in the above pic, you can see the second set at the rear part of the cat..
  9. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    Yes. No sensors to monitor the secondary cats.
  10. FullChat
    FullChat Formula Junior
    Jan 1, 2007
    339
    San Antonio, Texas
    Just drive it - what a shame!! Sounds like a great 355!
  11. TRScotty
    TRScotty F1 Rookie
    Oct 12, 2006
    2,505
    Tyler, Texas
    Scotty
    #11 TRScotty, Jun 8, 2008
