Cause of Triple Seals Failing in 94 348 | Page 3 | FerrariChat
Discussion in '348/355' started by Brewman, May 1, 2017.
  1. MLX_1
    MLX_1 Rookie
    Dec 27, 2021
    46
    London
    That’s what I thought. Any ideas or suggestions on how to define the issue? Unless the newer Hill engineering units are slightly smaller than the old ones? They told me that they are a direct replacement, although the part number is very slightly different. The old part is CRB355 and the new bearing is CRB355 ms
  2. m.stojanovic
    m.stojanovic F1 Rookie
    3,314
    Serbia - Niš
    Miroljub Stojanovic
    #52 m.stojanovic, Jan 22, 2024
    I bought my Hill TO Bearing in 2016 and it was called "CRB-355MS" on the invoice but it had "CRB-355M" etched on it (see pic). I had no problem pushing it onto the flanged piston. In any case, you can easily measure the slave cylinder diameter that engages the larger diameter of the flanged piston and compare it with diameter on the old one and with the diameter of the piston. Both of your shown bearings appear to be CRB-355M.
