CD magazine will not eject 06 430 spider | FerrariChat
Discussion in 'Technical Q&A' started by LabDoc, Aug 5, 2010.
  1. LabDoc
    LabDoc Rookie
    Jan 23, 2009
    17
    Springfield MO
    Dallas W Johnson
    Just purchased a 06 430 spider with 2K on the clock still in warranty but do dealer within 225 miles. When pushing the eject button nothing happens with no whirring sound from the motor.. I was told by the dealer that there should be a reset hole near the gray eject botton. no such hole exists.There is a dimple near by but no patent
    hole . Incomplete perfration at manufacture? I perferated the dimple with a pin but made not contact with any reset switch. Fuse not likely without display indication ,right? help
    Dallas
    Spfd. MO
  2. sclja
    sclja Formula Junior
    392
    San Diego Ca
    Scott Cairncross
    I would pull the radio and make sure it is plugged in first. I install the becker auxillary / ipod connection on a lot of stock becker radios and they plug in in place of the cd changer at the back of the radio on the green and blue plugs are used for the cd changer so check to see if they are connected... If you have any questions let me know.
    Scott
