CEL 1/4 light and rough idle | FerrariChat
Discussion in '348/355' started by 360DUSTIN, Dec 12, 2009.
  1. 360DUSTIN
    360DUSTIN Karting
    Oct 21, 2009
    151
    Mckinney Tx
    Dustin Helms
    I am a new ferrari owner as of 2 weeks ago. I have read all of the posts regarding this and i dont really understand what is the best way to find the solution. is it possible for someone to post some pics of the steps necessary to diagnose. Also i am reading that it may be a good idea to ground the o2 sensors to the frame using a hose clamp. Is that safe, and does it go directly on the sensor itself? Any help would be greatly appreciated because having a 348 with cel light on bugs the $#!* out of me.
    91 348 ts w/ 23k miles
    Thanks,
    Dustin
  2. OhioSooner
    OhioSooner Formula Junior
    Mar 11, 2009
    468
    Ohio
    Mean Median
    I had this problem with my 348 when I first got it. I would get the slowdown light and the car seemed like it would lose about 100 horsepower. Then about a minute later it would die. It would start up immediately and be just fine for about 20 miles and do it again. I switched the cat ECU's and it actually ran fine for awhile. After about 300 miles it started doing it again but it of course had switched to the other side of the engine. I then changed that ECU and there have been no problems since then. I do not have any pictures but I found some on Ferrari Chat when I was trying to figure this out. I know that Miltonian has some posts concerning this problem.
  3. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    Did you pull the codes? Get those and it might get you closer to the issue. Don't get to stressed with CEL's, most are nothing and it could be just bad electrical connections. If your 02's are old I would think about replacing them. I had a similar issue and new Bosch Universal 02's solved the problem. There are threads here with the proper part numbers.
    --Mike
  4. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Hi, Dustin. Congratulations on your 348!
    The "slow down" lights and the "check engine" lights are not the same thing, just to clarify. If you are getting "check engine" lights, you need to download the stored codes, find out what they signify, then clear the memory from the Motronic self-diagnosis system. You can do that at home yourself. One of the problems you may be encountering is a bad ground on the O2 sensors, as you have said. It's pretty straightforward to just make up a wire that can be clamped onto the sensor body and grounded on the frame. There are all kinds of things that might be triggering the CEL, most of them being pretty minor. It's also possible that you just have old codes in the memory, and if you clear them, they won't reappear. At this point, just don't worry that a "check engine" light means "immediate danger". It just means that one of the monitored systems has shown a reading outside its normal range. Don't ignore it, but don't panic.
  5. 360DUSTIN
    360DUSTIN Karting
    Oct 21, 2009
    151
    Mckinney Tx
    Dustin Helms
    how would i clear the codes in the computer? I wouldnt even know where to start to be honest, but one of the things that attracted me to the 348 was the thought that maybe i can do some of the work on my own. If grounding the o2's cant hurt anything, then i'll give that a try. can autozone pull the codes or is it more complicated than that. Also, how will i know if it is safe enough to drive to where i can get the codes pulled? The light is a check engine 1/4. i have read that that is referring to only one side of the engine. which side is it, the left or the right? What would be the best way to remove the o2's and check em out? I am embarrased to ask so many questions, and i can afford to take it to the dealer, but i think it would be gratifying if i can fix it myself.
  6. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    #6 mj_duell, Dec 12, 2009
    Disconnecting the battery will clear the codes. To get the codes you need to remove the panels behind your seats. There is a button on the ECU that will allow you to get the codes on the dash for each bank of cylinders.
    Go here and follow the procedure:
    http://www.my348.com/348.html#ECUcodes
    You can do most of the work on a 348 yourself. By the way that page is a great reference for anything 348.
    --Mike
  7. 360DUSTIN
    360DUSTIN Karting
    Oct 21, 2009
    151
    Mckinney Tx
    Dustin Helms
    you guys rock, i really appreciate the help. im gonna see if i can figure it out tomorrow.
  8. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    I suggest, after you unplug the battery, to use a contact cleaner and spray both ECU's connectors, MAF's and anything else with connectors in then engine. This is very easy and .... works. It really helps !
  9. 360DUSTIN
    360DUSTIN Karting
    Oct 21, 2009
    151
    Mckinney Tx
    Dustin Helms
    ok, i'll do that too. i will let you guys know what codes i pulled soon as i get them.
  10. sdiamond
    sdiamond Formula Junior
    Mar 25, 2009
    304
    Kildeer
    Steve
    Dustin,
    Sounds like me 6 months ago. Take a deep breath and relax, we ALL have had similar issues and ALWAYS at first it seems a huge problem, but these are great cars and quite simple to do the work yourself on many items. No really, it's a lot of plug and play items (remove the old one and put in a new one) sort of thing. I replaced the two O2 sensors in mine in about 20 minutes absolutely no big deal and it now runs great with no warning lights. cheap and easy fix. Next is the fuel pump regulaotrs so it starts back up right away after being off for 15 minutes. That's another "everyone" issue with these cars. Go to the my348 page noted in the forum and you can download instructions and pictures for doing just about anything!!! send me an email if you need help reading the codes, again, really really simple to do on your own, don't get too anxious about it.
    Steve
    btw, your profile is still empty so we don't know where you are
  11. 360DUSTIN
    360DUSTIN Karting
    Oct 21, 2009
    151
    Mckinney Tx
    Dustin Helms
    i pulled the codes this morning but got a 4444 which means no problem but its because i shut off the battery while i had it in the garage for the last couple of days. it runs great now and if the code comes up again i know how to fix it. i am still going to ground the o2's just for peace of mind tho. thank you for all the advice and i'll make sure to update my profile. I am also going to take some pics of my new ride for all to see hopefully this weekend.
  12. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Have you "re-initialized" after having your battery unhooked?
    Glad the car seems to be running well!
  13. Night life
    Night life F1 Veteran
    7,291
    The city that rhymes with fun in Canada
    Roberto
    Ditto, did you let the car idle without touching the gas pedal till both fans came on or roughly 15 min? this resets all parameters.
  14. 360DUSTIN
    360DUSTIN Karting
    Oct 21, 2009
    151
    Mckinney Tx
    Dustin Helms
    yes and i drove it to work today and its running better than ever! i am a 348 guy for life. i still cant believe that its that easy to fix. im just....... in love!
  15. 50hdmc
    50hdmc Formula 3
    Oct 10, 2006
    1,211
    Michigan
    mark s
    Best of luck with your car Dustin. I think if you try to search most ANY issue you have with your 348, you will find a wealth of information from this forum.
  16. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    +1
