CEL and loose gas cap on 430 | FerrariChat
Discussion in '360/430' started by john0719, Apr 10, 2009.
  1. john0719
    john0719 Rookie
    Feb 8, 2007
    23
    Taipei & Cupertino
    John L
    #1 john0719, Apr 10, 2009
    I know this was the infamous problem on 360s, but I seem to have this problem as well on my 2007 430. When the light came on the first time around, I had tighten the gas cap and CEL went away the next time I started the car. Recently, the CEL came back on again after I refueled, so I tighten it again. However, this time it stayed on, even after 3 cycles of starting and shutting off the engine. Does any other 430 owners have this problem? Btw, the car drives perfectly fine.
  2. Ricambi America
    Sponsor Owner
    I assume it is like most OBDII systems in that simply starting and shutting off the car is not sufficient. It requires a full drive cycle (or 3?) with the cap closed properly.
  3. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    I had a CEL once after refueling and thought it was probably a loose gas cap but continued driving didn't make it go out. I continued to drive it for months since the car ran fine and I'm about 125 miles from the dealer. When I got finally got the car in the codes were: PO464, P2069 fuel level sensors and U0142, U0144 communication with control module errors. The tech cleared them and I've had no recurrence so far (about 1 year).
    Dave
  4. 360racer
    360racer Karting
    180
    Carlos
    How about trying to disconnect the battery for 60secs let the systems reset and connect it again... i Did just that 2 days ago cause my engine light came on for no reason and drove the car tonight and so far nothing..
  5. Barrister
    Barrister Formula Junior
    Aug 11, 2008
    709
    The OC
    "Big D"
    #5 Barrister, Apr 10, 2009
    Make sure that the rubber gasket on the inside of the gas cap is still in place and not corroded. Some times it can even fall out without you even knowing it if it has deteriorated badly enough. That trips the sensor and will keep the light on even after you tighten the cap. The gasket can get damaged by overtightening too.
  6. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    In other words always make sure your rubber is on and working properly!
  7. Barrister
    Aug 11, 2008
    709
    The OC
    "Big D"
    D'Oh! I set it up again didn't I!
  8. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Thank you very much (done in the Elvis tone)!
  9. JOEA2
    JOEA2 Formula 3
    Feb 2, 2006
    1,225
    Staten Island, N.Y./ Sea Girt,N.J.
    Joe A
    They claim that they just fixed mine. They said that it was a loose O2 sensor. Time will tell.
  10. Barrister
    Aug 11, 2008
    709
    The OC
    "Big D"
    I also had a bad connection in my evaporation system that they corrected. Who knows . . . .
  11. RobD
    RobD Formula 3
    Nov 10, 2003
    1,182
    If it's bad, can you buy just the gasket or must you buy the whole gas cap? TIA
  12. john0719
    john0719 Rookie
    Feb 8, 2007
    23
    Taipei & Cupertino
    John L
    The CEL finally went out this morning. Keeping my fingers crossed......................
  13. Derek Trotter
    Derek Trotter Formula 3
    1,790
    Cambridge, UK
    There's no tiring of GCalo is there! :)
  14. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    No and I am not going to stretch my luck either!!!
  15. Derek Trotter
    1,790
    Cambridge, UK
    AAAAAAAAAAAAHHHHHHHHHHHHHHHH.................. *Slits wrists*
  16. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    You could do it easier with some form of gas!
  17. CSISNEXT
    CSISNEXT Karting
    Dec 19, 2007
    67
    Had the same exact problem on my 07 F430. Brought it in to my dealer who took care of it - once and done. Not sure if it's an official "campaign", but it seemed to be a well known issue at the dealer; involved a sensor adjustment or replacement (not sure which). Hope this helps.
