CEL Light on with new hyper flow cats!! | FerrariChat
Discussion in '360/430' started by 360spidermancalgary, Jul 17, 2013.
  1. 360spidermancalgary
    Sep 29, 2012
    35
    Calgary, Alberta
    Jerry Troha
    I just got a pair of new hyper flow 200 cell cats installed on my 360 and must admit I love the additional power and sound!! On the second day of driving the car, the CEL light has come on. I have read many threads indicating that this is a common occurrence with install of new cats.
    I would like to find out what is required to eliminate the CEL. Install new cat ecu's, o2 sensors?
    Thanks in advance.
  2. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    Give it some time and the ECU might get used to them and eventually accept them. To determine if the issue is from the post O2 Sensor take it for a very spirited drive, ideally a high performance track session. If the CEL light goes out then it is due to the post O2 Sensor thinking your Cats are not working because they are so efficient. I have purchased O2 Extenders which place the O2 Sensor further out of the path of the Cat which is supposed to cure this. Since I do take my car to the track once and a while and the CEL clears itself I am not too concerned and am too lazy to put the O2 Extenders on during the summer driving season.
  3. HighandDry
    HighandDry Formula Junior
    Jul 24, 2012
    447
    Seattle
    Steve
  4. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    Plenty of reports that the big daddies mini cats don't work either. I've got extenders to go with my de-cat pipes and don't really expect them to work. But my F-shop says no big deal we can sort it if it happens. If it happens I will hopefully report back with a fix. But they were not concerned.
  5. IDriveM5
    IDriveM5 F1 Rookie
    Jul 2, 2012
    2,675
    Central Ohio
    Raj
    #5 IDriveM5, Jul 18, 2013
    I'll let you know what my mechanic does. He's installing new headers from Fabspeed and new cats from Hyperflo. He said something about also buying the "cheater" parts that will eliminate the CEL issue, because he knows I absolutely HATE the CEL.
    EDIT: Here's what my mechanic said he's doing for my car:
    Normal installation and proper tuning there 'should' not be any CEL but once in a while there is..to virtually eliminate the CEL (for catalyst reasons ) we install extenders which go on the front probe on the cat system..cats work because of variance of what goes in and what goes out..the extenders (cheaters) simulate more variance and insure no light..
  6. HighandDry
    Jul 24, 2012
    447
    Seattle
    Steve
    Extenders by themselves won't work. Bigdaddies by themselves won't work.
    Need them both.
    Highly doubt that changing headers and cats are not going to trigger a CEL. Proper tuning? What does that have to do with an emissions CEL?
  7. IDriveM5
    IDriveM5 F1 Rookie
    Jul 2, 2012
    2,675
    Central Ohio
    Raj
    While I can't comment on the technicalities of the discussion, I'll be happy to report on any changes of condition after I have my car back, and have a few miles on the new system.
