CEL on 550 Maranello | FerrariChat
Discussion in 'Technical Q&A' started by dennis_maine, Sep 12, 2019.
  1. dennis_maine
    dennis_maine Karting
    Sep 11, 2007
    204
    ME
    Dennis Haines
    My 2000 550 Maranello has a check engine light. I can't get any readings with any of my scanners. Pin 16 of the OBD connector has 9 volts on it. It should have battery voltage. There are only 9 volts with both ECUs connected, or with only one of the ECUs connected (either one). Something is loading down pin 16. I can't find a decent wiring diagram anywhere, so I'm at a loss. Has anyone ever seen this condition, or have any insights? I could sure use the help. Thank you.
  2. Qavion
    Qavion F1 World Champ
    14,356
    Ian Riddell
    #2 Qavion, Sep 12, 2019
    Fuse 21 powers the OBD connector. I also believe it powers the following:
    Luggage compartment light
    Dome Lights
    Cigar lighter
    Trunk release (solenoid?)
    I would try disconnecting them one by one if that's possible (to see if the voltage changes).
    Check to see if you have 9 volts at the fuse also. Maybe the fuseholder has dirty/corroded contacts? (EDIT: might be a good idea to try this first). Leave the fuse in place and check both sides of the fuse (There are normally holes in the fuse to allow a multimeter probe)
  3. Qavion
    14,356
    Ian Riddell
    #3 Qavion, Sep 12, 2019
    Here's the diagram showing the fusebox link to the OBD connector:
    550 Alarm System Diagram
    I have other diagrams, but none show dome light and trunk release wiring. I believe the wiring for the cigar lighter will be similar to the 456's. I've added the (hypothetical) wiring to this diagram:
    550 Lighting Diagram
  4. fatbillybob
    Aug 10, 2002
    29,071
    socal
    have your scanners worked on this car in the past?
    Qavion likes this.
  5. Qavion
    14,356
    Ian Riddell
    Now that I think about it, that won't tell you if the downstream side of the fuseholder is corroded. Also pull the fuse and see if both contacts on the fuseholder are ok.
    Are you using the cigar lighter socket for anything at the moment (like running the garage lighting on it?) :p
  6. Qavion
    14,356
    Ian Riddell
    I forgot you already have them.
    Bouquets one day, brickbats the next? Perhaps you're not looking in the right spot?
  7. Qavion
    14,356
    Ian Riddell
    Here's the information I extracted from the diagrams I gave you on the 550 forum:
    Fuse 21 systems
    Power for the fuse comes from the battery terminal board above the passenger footwell fuse/relay panel.
    The fuse numbers I've shown in these diagrams are taken from the owner's manual which most owners have access to (Fuse 1 is on the far left, fuse 24 is on the far right of the footwell fuse/relay panel). This is contrary to how the fuse numbers are shown on the original black and white Ferrari wiring diagrams.
    Fuse/Relay Panel connector numbers are probably imprinted on the plastic of the panel.
    I don't know if connector "H" on the panel feeds things like the luggage compartment light, dome lamps and trunk release, but you may be able to pull this plug to see if your voltage changes.
    Connector C feeds the OBD plug and the cigar lighter (as far as I know) via splice [216]. Ferrari doesn't tell us where splices are, unfortunately.
    Let me know if you need further information.
  8. Qavion
    14,356
    Ian Riddell
    Looking at an online photo of a 550 fuse panel, I'm not sure if connector "H" is used at all. This might make faultfinding a little more difficult. Look for additional wires on connector "C" pin 7. These may feed the lights and trunk release.
    Here's a graphic which I think represents the fuses, relays and connectors on the fuse/relay panel:
    Relay panel graphic (theoretical)
  9. dennis_maine
    Sep 11, 2007
    204
    ME
    Dennis Haines
    Qavion, I didn't mean to throw any brickbats. I'm just very frustrated. Your diagrams are still better than Ferrari's own.
    Qavion likes this.
  10. dennis_maine
    Sep 11, 2007
    204
    ME
    Dennis Haines
    Some other comments. The CEL was on when I bought the car (cheap). I assume it worked at one time, but not for me.
    I'm not using the cigar lighter for anything. In fact, I have the ashtray, radio, HVAC panels out to de-sticky them. I can't imagine this would make any difference.
    Qavion likes this.
  11. tazandjan
    39,196
    Not too many SD2s in Maine, eh?
  12. f355spider
    f355spider F1 World Champ
    18,048
    Has this car had the recall performed to add the ground wire to the OBDII port? All Ferraris from 1996 to 2005ish are missing the ground. The feds required a recall when states could not conduct emission tests through the OBDII port due to the missing ground. It also prevented many independent Ferrari specialists from diagnosing the cars ;)
    Qavion and zstyle like this.
  13. Qavion
    14,356
    Ian Riddell
    Good to know, but I don't think a missing ground would explain a low voltage on pin 16.
    Dennis, what were you using as a ground for your voltage checks? A chassis earth or pin 5 on the OBD port? How healthy is your battery? With the car ignition on, it can put a drain on the battery.
    Not unless the disconnected plug pins are shorting to something.
  14. dennis_maine
    Sep 11, 2007
    204
    ME
    Dennis Haines
    There are NO SD2's, Ferrari dealers, or Ferrari experts in Maine. The ground wire has been added. I generally use chassis ground when making voltage measurements. I keep a battery maintainer connected at all times. The battery is new. The voltage on the two ECU fuses (I forget the numbers just now) is 13.8 volts.
    f355spider and Qavion like this.
  15. Qavion
    14,356
    Ian Riddell
    Could you pull plug C on the relay panel and see if you have 13.8 volts coming out of the relay panel? (pin 7).
    If the volts are ok, the problem will be downstream of that plug. Do your dome lights, trunk release and luggage compartment light work?
  16. Qavion
    14,356
    Ian Riddell
    Note that the ECU fuses and OBD2 fuse use a different relay panel battery contact. The battery feed connector (plug "K") on the relay panel has two (positive) pins. It would be better to check the power on fuses 13~24 on the right hand side of the relay panel.
  17. dennis_maine
    Sep 11, 2007
    204
    ME
    Dennis Haines
    Fuses 13 - 24 have 13.8 volts on them.
    I can't find any document showing connector lettering. Are the connectors lettered A - K, starting from the left side and proceeding clockwise?
    The dome light and trunk release work.
  18. Qavion
    14,356
    Ian Riddell
    Refer to the link in post 8 for the relay panel plug numbers. I've incorporated the graphic in some of my diagrams which I'll upload later.
    Thanks for the feedback on the fuses, dome lights and trunk release. It could still be a fuse panel problem. These other devices will probably run on 9 volts without a problem. Unfortunately, if the problem is outside the fuse box, it will make finding the problem a little harder because there are no disconnect plugs between the fuse panel plug and the OBD port.
    Since your cigar lighter is disconnected, could check the voltage on the lighter plug?
  19. dennis_maine
    Sep 11, 2007
    204
    ME
    Dennis Haines
    Thanks for the information regarding the relay panel plugs. I missed that one,
    There is 12+ volts on the lighter plug.
  20. Qavion
    14,356
    Ian Riddell
    Just to confirm, all your measurements, including the one on the OBD2 port were made with with the ignition off and battery conuditioner on?
    13.8 is a little high for battery only. I'm not sure why the voltage is lower at the cigarette lighter. At least not until measurements are made at plug C with the plug off. If that is lower than 13.8, you could also check the voltage at plug "H" as a comparison (with plug C off). i.e. the unused plug.
    This should confirm if you have an problem in the fuse box or outside the fuse box.
  21. dennis_maine
    Sep 11, 2007
    204
    ME
    Dennis Haines
    My measurements were made with the key ON and the battery conditioner connected. There is no voltage on obd connector pin 16 with the key off. I also discovered that even the headlights do not work unless the key is on. Is this normal?
  22. Qavion
    14,356
    Ian Riddell
    #22 Qavion, Sep 17, 2019
    According to the diagrams, the headlights do need the ignition key (this is typical Ferrari), but the diagrams show power for the OBD port coming directly from the battery. Seems that the diagrams are wrong (or your car is wired up differently from other cars). I'm not sure I can give you much help from here if this is the case.
    You do normally need the ignition on and the immobiliser off to interrogate the Motronics ECUs (using the OBD2 port), but that's only because the Motronic ECUs themselves need ignition power.
    Maybe someone here or on the 550 forum can see if they have voltage on pin 16 (without ignition)? I don't have access to a 550. By the way, does your cigar lighter require the ignition to be on? My late model F355 does (but earlier cars don't). It also uses a different fuse from the earlier cars, despite what is printed on the fusebox cover. This may be the case on your car. Perhaps you could try pulling fuse 21 to see if you still get that voltage on pin 16? (ignition on)
