CEL P0410... | FerrariChat
CEL P0410...
Discussion in '348/355' started by huzilulu, Nov 25, 2011.
  1. huzilulu
    huzilulu Formula Junior
    Apr 20, 2011
    340
    Houston
    Huzi Husain
    I got P0410 this morning - Secondary Air Injection System...
    A search on the forums dictated looking for a blown fuse - question: where is the fuse? I could go through the entire fuse box in the engine, but would REALLY prefer if someone pointed me in the right direction.
    Thanks!
  2. Labman
    Labman F1 Rookie
    3,803
    Long Island, NY
    Steve
    I had this code once. It was a hole in the air hose above the headers. It is connected to a valve. A small hole is all it takes. You may have to remove the hose for a better inspection. Mine was just rotten out do to heat and age. A simple fix.
  3. f355spider
    f355spider F1 World Champ
    18,055
    Passenger foot well. Check the one for air injection pump. It is a 15amp fuse, and known issue that they should be a 20amp. The dealers all install 20amp, and it will never blow again. Good luck.
  4. F355steve
    F355steve Formula 3
    Apr 9, 2008
    2,089
    Honolulu - Seattle - Okinawa
    Steve
    What if it does blow again after changing it to a 20 amp? In searching I came up with this thread:
    http://www.ferrarichat.com/forum/showthread.php?t=104117&highlight=p0410
    Brian Crall says to just replace it with a 30amp. Has anyone done that? Any danger in trying that? Can anyone lay out the technical reason for the fuse blowing? Is the airpump motor getting old and drawing more power to run or something else?
  5. sws4re
    sws4re Formula Junior
    Jan 28, 2006
    281
    Olathe Ks
    Scott Sweat
    Brian is WAY smarter than I am on this stuff, but I was always told to never go up. I could see maybe going from 15-20, but to go to 30 would make me a little nervous. I have seen the fuse box melt on a couple of 355s under that fuse. I think Helms has a fuse block to help with this.
  6. F355steve
    F355steve Formula 3
    Apr 9, 2008
    2,089
    Steve
    Exactly what I was thinking. Brian is way smarter than myself on this stuff but I would be very nervous putting a 30amp in there without knowing exactly what the cause of the problem is and hearing others first hand experience with such a "fix".
  7. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Clean the road debris and gravel out of the gauze filter and the impeller, that is causing the motor to bind up, replace the fuse and go on your way. Its part of a REAL major service but often needs to be done in between services.... 90% are Never done.
  8. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    What he said ^^^ ............... :) .............. also make sure the the gauze filter is intact and in place ......... that little blower motor can suck in a lot of bad things, if the filter has migrated out of place.
  9. F355steve
    F355steve Formula 3
    Apr 9, 2008
    2,089
    Steve
    Thank you Dave! Your help here in invaluable. Whenever I hear about "fixes" to problems without addressing the cause of the problem it makes me think of what Dave Helms would say. Fix the cause of the problem rather than treating the symptom.
  10. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    What I say falls on deaf ears these days so I no longer waste my time flapping my fingers on a key board. It is a shame when I sit back and watch History repeat itself. When it gets bad enough and these cars are thrown out like dirty bath water.... maybe then owners will listen.
  11. f355spider
    18,055
    Well, I am happy to say "thank you" and glad you are still around to keep us straight Dave. :) Please stick around and keep posting!
  12. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I have this code pending. What is the "gauze filter" ?
    Thanks in advance
  13. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I assume these are the intake filters?
  14. Labman
    Labman F1 Rookie
    3,803
    Long Island, NY
    Steve
    It's the air pump motor. Lower right side rear of engine behind right side rear wheel. It's where that whining noise comes from that you hear when you start your car up when cold. There is an air filter element that gets filthy as it is rarely serviced. Also check all your air lines and see if any holes. This is an old thread I'm still subscribed to even though I no longer have my 355. But I remember about this issue.
  15. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #15 Dave rocks, Aug 12, 2014
  16. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Thank you for the reply. My intake filters are very clean. I'll clean this one tomorrow.
  17. Labman
    Labman F1 Rookie
    3,803
    Long Island, NY
    Steve
    That's it! See if the fuse is blown too. It should be whining when you start it up first time when cold. If not...change fuse. Clean filter first!
  18. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Much appreciated, Steve! :)
  19. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    #19 bcwawright, Aug 13, 2014
