CEL P1630......help | FerrariChat
CEL P1630......help
Discussion in '360/430' started by kzsport, Aug 9, 2011.
  1. kzsport
    kzsport Karting
    Feb 23, 2008
    112
    china
    BRIAN
    #1 kzsport, Aug 9, 2011
    Hi
    I got the CEL P1630 due to lose HP after replaced F1 pump....Delete by OBD reader.
    Driveing for 30 mins then F1 pump gone.
    Any advice??
    Brian
  2. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    #2 Trent, Aug 9, 2011
    On a F430 :
    P1630;
    Malfunction Source: RH-B ECU CONFIGURATION CHECK
    Malfunction Description: Wrong bank configuration
    Malfunction Type: Value not plausible
    Diagnostics: Wiring and system intactness check.
    Sounds like a wiring harness error. If you just changed your F1 pump, maybe verify any connections you disconnected/reconnected for a solid connection and clean connectors. Also make sure hydraulic fluid did not drip down to other harnesses.
    You could try and reboot your car. I know I suggest this a lot, but please note I am a software engineer! See attached reboot Guide.
    Can you elaborate on what exactly happened, your description is cryptic and lacks details, etc.
    See attached code list PDF
  3. kzsport
    kzsport Karting
    Feb 23, 2008
    112
    china
    BRIAN
    Thanks for your support...of course will post exactly fault detail after done.
  4. kzsport
    kzsport Karting
    Feb 23, 2008
    112
    china
    BRIAN
    The CEL P1537&P1573 comes on this F360 F1 after I'd clear the wires of engine,susp bay.
    The vehicle couldn't start while P1573 come with but NO error light on dash???
    I knew P1573 was ABS&ASR system fault of wires or connect..but check all ground,connect looks no broken wire ....etc
    Any advice about this???
    KZ
  5. kzsport
    kzsport Karting
    Feb 23, 2008
    112
    china
    BRIAN
    Find the result of P1630,P1573,P1537 below this.
    The vehicle Security horn had leak and all over the fulid in the pins and connacter also burn 1 pin so CEL fault come with while bad connect.
    Will cause vehicle no start due to imm working.
  6. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    Thanks for posting, the siren is notorious for leaky batteries. Good reference.
