Cell Antenna Removal? | FerrariChat
Discussion in '308/328' started by gonzo350, Mar 3, 2010.
  1. gonzo350
    gonzo350 Karting
    Apr 3, 2004
    207
    Lafayette Indiana
    Myles
    #1 gonzo350, Mar 3, 2010
  2. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    I would suggest going to a Automotive Window shop and paying the removal fee. They certainly will have tools and chemicals for a safe job. Cable removal should be easy.
  3. gonzo350
    gonzo350 Karting
    Apr 3, 2004
    207
    Lafayette Indiana
    Myles
    Probably money well spent...
  4. 308 GTB
    308 GTB F1 World Champ
    11,722
    New Jersey
    Barry Wolinsky
    You got to know when to hold 'em, know when to fold 'em....
  5. t3thomas
    t3thomas Formula Junior
    May 9, 2008
    427
    North Carolina
    GThomas
    I've installed and removed them before. Both components just have an adhesive backed foam on them. Work a single edge razor blade around the edges and they will both pop off. Or you can go to a windshield shop, pay them $50 to do the same thing and then feel like you've been taken driving away.
  6. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    I would call that a period appropriate accessory that may make your car more valuable in the future.
  7. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    I'd go at it with 3M Adhesive remover and dental floss. Use the floss as a "cable saw" to cut through the, softened, adhesive.
  8. BigTex
    79,386
    Houston, Texas
    Bubba
    That's what I did to the one thru my ENGINE COVER!! LOL!
    Have to weld that up, one of these days.....
    A glass shop would probably have the suitable plug for it, tho.....it'll leave a hole.
  9. gonzo350
    gonzo350 Karting
    Apr 3, 2004
    207
    Lafayette Indiana
    Myles
    Hmmmmm now I'm really on the fence.....does everyone think the glass is drilled or not? I cant imagine it is.....but I have ZERO experience with these things.
  10. TTom
    TTom Rookie
    May 28, 2008
    4
    Coral Gables, FL
    Tom Young
    I installed several of these; none ever required drilling a hole in the glass.
  11. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,274
    Seattle Area
    Dave
    Not drilled. Those things were capacitively coupled - the signal passes from a metal
    plate on one side to a plate on the other side. It's simply held on with glue. You
    should be able to safely and easily remove it by applying heat (blow drier or heat
    gun) on each side and gently prying on the side you're heating using a putty knife.
    Jedi
  12. BigTex
    79,386
    Houston, Texas
    Bubba
    Good to know!
    Thanks guys.
    It's been a long time but I recall a base that did need a hole, I think the one on my 1977 has a hole thru the metal....
  13. t3thomas
    May 9, 2008
    427
    North Carolina
    GThomas
    What he said..........or what I said earlier. I think the earlier (more valuable) ones did require a hole, but that was before our marvelous and never ending technology progression solved the dilemma.
    I wish it was as easy to repair the holes on my center console where the PO mounted their bag phone............and we used to think we were so cool talking to people on a telephone the size of a brief case while driving around!
  14. Dr Tommy Cosgrove
    36,437
    Birmingham, AL
    Tommy
    Blow dryer plus razor blade.
    I had the exact same antenna on the exact same spot. Took it right off no problems
  15. GrayTA
    GrayTA F1 World Champ
    15,130
    Deep South
    PDG
    Screwdriver and a hammer outta get that right off....then plug the hole with some duct tape. You can probably find some black duct tape that will cover that right up and not look too far out of place.
    Good luck!!!
    PDG
    j/k
  16. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Being both an amateur and professional radio guy I have placed and replaced a bunch of glass mount antennas. There will be no hole in the glass and both the dental floss and razor blade methods will work fine. The tape holding them on is, as mentioned, unexciting foam tape, comes off with some sort of adheasive remover like Goof-Off. Have at it.
    My car has a hole in the console from either a phone or that silly stalk-mount Blaupunkt radio. Who thought either one of those were a good idea? I put a cigarette lighter in the hole. Now I have power for GPS or charging the phone, but really, I'd rather have untouched leather.
  17. Yamaric
    Yamaric Karting
    Apr 7, 2007
    199
    West Palm Beach, FL
    Richard Dalgleish
    Just remember to always use a new razor blade straight from the pack, as a blade with even a very slight nick can/will scar the glass.
    Richard
  18. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    This is why dental floss, is the better "tool".
  19. Jdubbya
    Jdubbya The $10 Trillion Man
    43,210
    PNW
    I've got one in the middle of my rear deck lid. Unfortunately they did put a hole in to mount mine. I cut the curly antenna off but still need to pull the base and get the hole fixed one of these days.
    I would use the dental floss and hair dryer trick. Safest way to go with the glass!!
  20. JV's89
    JV's89 F1 Veteran
    7,300
    Pittsburgh, PA
  21. GrayTA
    15,130
    Deep South
    PDG
